Question about Dyson DCO7 Upright Vacuum
Dc07 belt different - Dyson DCO7 Upright Vacuum
Where is the brush belt on a dyson 07 upright vacuum?
Hi there, it's Jack at Dyson.
The type of belt mechanism will depend on which model of DC07 you own. If you have a DC07 machine without the brush control feature, the user-replaceable belt is located within the cleaner head:
http://www.dyson.co.uk/support/dc07/dc07-standard/maintaining-your-dyson-machine/change-the-belt1/belt-fitting-preparation
However, if your DC07 includes the brush control feature (you should see the Carpet/Hard floor dial on the cleaner head), your machine will use a clutch mechanism with belts engineered to last for the lifetime of the machine in normal use.
If you have a DC07 with brush control and would like some help with it, please contact us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 25, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
How to remove clutch on dyson dc07
This service is hard to explain. Try googling it so you watch a video of how it is done. You can purchase belts and rebuild the clutch with the new belts or you can purchase a new clutch with belts already installed
Mar 27, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
My DC04 showed signs of motor belt broken. This has been confirmed by following the dismantling video for DC07 for my DC04(with some differences). Have got to the clutch removal stage but cannot get it to...
Assuming you have removed the 3 screws that cover the clucth cover and removed the clutch cover, and assuming yo have taked the clutch knob off, all you need to do is grab the rubber belts and give it a good tug
Feb 02, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My manual says it is DC07, but it is pink and silver in colour. I have 2 problems, firstly the brush has stopped spinning, but belt appears intact. Secondly there are tiny holes in suction pipe near...
The DC07 came out in a few different variations so the colour only indicates that yours has a hepa filter. The first problem can be caused by a few different things
1. the brush roller bearings are worn or siexed.
2. The clutch to motor belt is brocken or off the drive shaft (this model has 2 belts but only one is visible without pulling the head apart.
3. The machine is set to hard floors (check the dial on the front)
4. The clutch is faulty.
I have made a video called
How do I check the clutch or brush roller of my Dyson DC07?. (video)
Folllow the link to my website and choose that video, it will show you how to fix all these problems. The same video will show you how to replace the internal tube as well.
If you need to purchase any parts for your dyson check out nelson vacuums or vacuumspot.
Finally if this is a helpful answer please rate it or better still leave a testimonial.
Jan 09, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hi my dyson dc07 animal has suction but the brush bar wont turn. If I turn it on there is a horrible noise. The belt is still fine
The belt is probably worn or stretched. When this happens the belt won't turn the roller brush when it is against the carpet. Here is a link for the manual and links for the belt you need:
DC07 Manual
Replacement belts for DC07 w/ clutch system
Replacement belts for DC07 w/out clutch system
Nov 12, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
DC 07 beater bar won't turn when on carpet setting. Filter has been washed.
The belt(s) need to be replaced periodically. If the belt is worn, stretched or broken it will not pick up the way it should. You can get DC07 replacement belts here:
Nov 09, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Seems like the belt may be getting old and not picking up as much as it used to.
Belts need to be replaced periodically. If the belt is worn it will not pick up the way it should. You can get DC07 replacement belts here:
Oct 30, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Doesn't rotate roller
Yes, There is a belt on the DC07. If you have the DC07 with the clutch system you need this belt:
http://vacbelts.xps.convina.com/dyson-clutch-system-belt.htm
If you have the DC07 without a clutch you need this belt:
http://vacbelts.xps.convina.com/dyson-flat-belt.htm
Oct 13, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DCO7 Upright Vacuum Logo
27 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
