Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
My electralog fireplace {model 6904890100} works on low an will run on hi for a min or two an then shuts off an will not come back on? can you help me???
2 Suggested Answers
  • 3287 Answers
SOURCE: I purchased an Electralog Electric
Hi Ron,
I found a manual for Electralog Fireplaces here. It seems to be rather generic, but hopefully answers your questions about the appliance.
As far as your remote control device goes (and possibly a model specific manual) , the manufacturer's info in the manual provides this for contact:
Dimplex North America Ltd.
1367 Industrial Road
Cambridge, ON N1R 7G8
Canada Customer service:
1-800-668-6663
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Technical specialists:
1-888-346-7539
Monday - Friday
I hope this helps & good luck!
Posted on Nov 15, 2010
My vented gas firs place keep gping into flame lift off. Hos do i fix this flame lift off. My gas log pro says i have to take the box out.??
I would suggest looking under the bottom louver of your fireplace as you have a b-vent or direct vent gas fireplace. From the looks of it alone it appears as its an early model Heat-N-Glo fireplace. If you flip down the bottom panel, where the two gold strips are at, underneath the gas valve you will find a sticker or a plate that has the model, manufacturer, and serial number. I work for a manufacturer that has been in the fireplace business for over 30 years and I'm betting $10 to a donut that is a Heat-N-Glo fireplace. Once you get the model, manufactuer, serial number, and date code sometimes you can search at www.heatnglo.com for AUTHORIZED dealers who can service your fireplace properly instead of a chimney sweep who may or may not be qualified to "trouble shoot" what is going on with the fireplace. It looks like an 8000GDV to me.
Best guess is a new pilot assembly if its a direct vent. If its a b-vent then a high limit switch might be needed as well with it cutting off that fast. It also could be a flue disconnect. Long story short I would find out the model, manufacturer, and then get on the manufacturer's website or call them to find out an AUTHORIZED servicing dealer for your fireplace. I hope this helps.
Apr 08, 2014 | Home
Heat stops working after a few minutes
A manufacture name and what type of heater would be helpful.
Mar 30, 2014 | Electralog Home
Not working
There is a thermostat on the unit. it is probably set too low.
So the heater quickly hits the low temperature and shuts the heat off, then when the temp drop it will come back on.
Feb 15, 2014 | Duraflame L Electric Stove with Remote
Heater fan on electric fireplace not working, so heat shuts off and won't come back on. The manufacturer is Southern Enterprises, Inc., model no. FA515500TX.
Was having same problem, found the fan needed a little oil on bearings. Was not spinning up to full speed so heater was cylcing on high limit
Jan 21, 2013 | Southern Enterprises Luxembourg Ivory...
I have a Dimplex Small Electralog Stove Fireplace CS1205, it's two years old but barely used until this winter. A couple months ago, the flame stopped working and now the heat keeps turning off after 5...
More than likely, the interior of the unit needs to be cleaned. When it's in operation, it sucks dust and link into the fan and heater elements. When it's not, spiders love to go into and build nests. If badly clogged, it can cause the heating element to over heat and shut off. Carefully, removing the back panel of the stove will give you access to just about everything. As far as the flame is concerned, the bulbs may need replacing. Although, it's unusual for all of them to go bad at one time. You or your nephew can replace them after the unit is cleaned. A vacuum that has a hose, brush attachment and crevice tool, will work well in the cleaning of the interior. Be sure to turn the Master ON/Off Switch to OFF & Unplug the unit, before attempting and maintenance on it.
If after performing all of the above, the unit still doesn't work properly, contact Dimplex USA, Technical Service 888-346-7539, for further advice.
Hope this helps to solve your problem. Please let me know.
Mar 17, 2011 | Dimplex Compact Electric Flame Stove...
I have a electralog fireplace model #cs 3311. It doesn't stay on very long. Even if i turn the thermostat up it doesn't turn on
It's probably the Temperature Cut Off Switch. It turns the heater off if it's overheating. To reset the switch turn the Main On/Off Switch to OFF . Wait 5 minutes and turn it back ON.
If you need to continuously reset the heater, unplug the unit and call Dimplex North
America Limited at 1-800-668-6663.
Hope this helped to solve your problem.
Mar 08, 2011 | Heating & Cooling
I turn my fireplace on and it works fine until I turn on the heating system it stays on for 5 minutes and then shuts off after a while it comes back on and then turns off again. Who can I call for HELP it...
try to find the thermostat in the fireplace, it's obviously got one that's turning it off when the room temp rises.
Thanks
Adam
please leave me some feedback
Feb 18, 2011 | Leisure HOMEPRIDE Electric Fireplace...
I have a cs1205 electralog heater. after 5 minutes we hear a pop and the heater stops working. we shut it off and will hear a pop then turn it back on. it will work again for about 5 minutes. what is wrong...
I have an electralog cs1205, when i turn it on, although it works , after about 10 seconds it makes a strange noise. It never did this before. Any ideas on whats wrong?
Nov 27, 2010 | Dimplex Compact Electric Flame Stove...
Heating & Cooling Logo
307 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
