Question about Dynamo MartinLogan Subwoofer Speaker
Martin Logan Dynamo subwoofer - power supply module fried. Need service manual to fix. It is not fuse, it is some internal short circuit. Factory Id: XMSH Serial: DYUA0343 Other numbers: 12345678AB Thanks in advance.
2 Suggested Answers
SOURCE: I own a used Martin
Did you get the sub fixed? I know someone with the same problem - won't turn on, fuse is fine. May be due to different underlying problem, but wondered if you discovered what it was and if you got it fixed.
Mike
Posted on Oct 29, 2010
I have a Martin Logan Abyss subwoofer. It has a volume control that when touched explodes the volume. How do I fix this?
Actually the most likely answer is that the volume control knob (potentiometer ) needs cleaning internally or replacing
Aug 16, 2017 | The Audio Players & Recorders
The lowest 20 amp fuse is burned out. every fuse I put in burns out immediately. what is it too,and how do I fix it?
You have a short circuit in the wiring or the mechanism that it goes to on that fuse line
So you will need to follow the wires on that fuse to check for dead short from a bared wire first then the items that it powers for damage or internal failure
Aug 16, 2015 | Cars & Trucks
Chevy code P1682?
P1682 Chevrolet - Ignition 1 Switch Circuit 2
Possible causes
- Faulty ignition switch
- Ignition Switch harness is open or shorted
- Ignition Switch circuit poor electrical connection
- Faulty Engine Control Module (ECM)
What does this mean? What does this mean?
When is the code detected?
The ECM has detected a voltage deifference between two circuits
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Possible no crank or start
P1682 Chevrolet Description
There are 2 ignition 1 voltage circuits supplied to the Engine Control Module (ECM). The first ignition circuit is provided by the powertrain relay, through a fuse. This ignition 1 voltage circuit supplies power to all the internal ECM circuits associated with the throttle actuator control (TAC) operation. The second ignition 1 voltage circuit is supplied by the run/crank relay through a fuse, and is used to power the remaining internal ECM circuits. If the ECM detects a voltage difference between the 2 ignition 1 voltage circuits, DTC P1682 will set
Read more: http://engine-codes.com/p1682_chevrolet.html#ixzz3dr4CYBUT
Jun 22, 2015 | Cars & Trucks
How can i connect my dynamo 700 w using martin and logan transmitter to my marantz sr5008
You just need one of these though all the sockets would need to be male:
Jul 06, 2014 | Audio Players & Recorders
No sound from speakers has a fuse blown
If fuse has been blown means power capacity of the subwoofers exceeded the actual power transmitted.Subwoofers capacity cant hold on to the actual power transmitted.If you replace a new fuse check first if internal circuit was not damaged .When a fuse blown out its an indication that something wrong happened within the circuit.Check first subwoofer line if there was short circuit using a tester.Select OHMS mode and try to check both lines.If no movement it means you have it check to a service technician to fix.
Jun 21, 2011 | Car Audio & Video
I have a 2003 Ford Explorer Sport Trac. My automatic headlights and auto dimming review mirror are not working. No fuses inside the cab of the truck are blown and dont know which ones under the hood...
The autolamp system, controlled by the vehicle security module, supplies voltage to the same circuits used by the headlamp switch to power the exterior lamps when low light conditions are detected.
Anyone else have or have fixed this problem some help please???? What fixed someone else's vehicle probably won't fix your's .Electronic's involved . Using service repair info. , wiring diagram's an testing the electrical circuits is how professional Technician's fix electrical system problems , not guessing or looking for magical fixes on web sites or forum's.
Visual Inspection Chart Mechanical Electrical
  • Headlamp switch
  • Battery junction box (BJB) fuses:
    • 1 (60A)
    • 16 (15A)
    • 22 (20A)
  • Central junction box (CJB) fuse 20 (5A)
  • Circuitry
  • Photocell sensor
  • Vehicle security module
Plus hooking up a factory scan tool an checking for DTC'S - diagnostic trouble code's .
Vehicle Security Module Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1695 Autolamp On Circuit Failure Vehicle Security Module Go To Pinpoint Test J . B1792 Autolamp Sensor Input Circuit Short to Battery or Open Vehicle Security Module Go To Pinpoint Test J . B1793 Autolamp Sensor Input Circuit Short to Ground Vehicle Security Module Go To Pinpoint Test J . B2661 Parklamp Relay Output Short to Vbatt Vehicle Security Module Go To Pinpoint Test R . B2662 Parklamp Relay Output Open Circuit Vehicle Security Module Go To Pinpoint Test I . B2663 Headlamp Relay Output Short to Vbatt Vehicle Security Module Go To Pinpoint Test F . B2664 Headlamp Relay Output Open Circuit or Short to Vbatt Vehicle Security Module Go To Pinpoint Test H . Symptom Chart Condition Possible Sources Action
  • No communication with the vehicle security module
  • Circuitry.
  • Vehicle security module.
  • REFER to Section 418-00 .
  • The autolamps are inoperative
  • Circuitry.
  • Headlamp switch.
  • Photocell sensor.
  • Go To Pinpoint Test G .
Electric Testing Techniques You Need to Know
Sep 19, 2017 | 2003 Ford Explorer Sport Trac
I own a used Martin Logan Dynamo (older series) and just today found out there is no sound coming out/no led light (at the back) either. I opened up the back and saw the 110V power is getting in but no...
Mike
Aug 28, 2010 | Dynamo MartinLogan Subwoofer Speaker
Brookstone Wafer-thin CD with MP3 player circuit failure...why?
sure, ur power amp section is completely shorted. meaning it is totally fried. get it repaired. it was a stupid idea to jump the fuse. u cud fry the whole thing!!! i sincerely hope it is only the power amp. if it is more than that u have only urself to blame. remember looks can be deceptive.
Apr 13, 2010 | Brookstone Wafer-Thin CD System with MP3...
Subwoofer blows internal 1.25A fuse when plugged in.
Any fuse blowing is caused by an overload in either the power section or the amp part. Look arond for burnt or damaged parts first. It could be caused by a shorted transistor, but your best bet is to follow the circuit from the fuse on the PC board.
Feb 18, 2010 | JBL PB10 Subwoofer
Bought a used Martin Logan Dynamo subwoofer a couple days ago and have a very loud hum when the ac cord is plugged in, even if the speaker is not connected to an audio source. The "hum" can be heard in any...
Neither the amp or the sub have grounded power cords.
I have discovered the ML Dynamo takes about 30 minutes to switch to standby in auto mode.
With speaker level inputs connected to the Onkyo A807 amp, both units powered from the same wall outlet, Dynamo sub on Auto, the sub hums for about half an hour after the Onkyo is switched off, then the sub goes quiet. Not so good.
I connected a bonding wire between the two units on 3_7_09. If I smoked some old audio gear I could just look at that as an opportunity, right?
Works fine. Now I have the ML powered from the wall and working normally.
Jun 30, 2009 | Dynamo MartinLogan Subwoofer Speaker
Dynamo MartinLogan Subwoofer Speaker Logo
223 people viewed this question
Top Dynamo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Dynamo Audio Player and Recorder Expert? Answer questions, earn points and help others
