Question about Cycling
I have a problems with my 125ttr 2003 I removed the screw that was near the crank and now there is oil leaking and I try to screw it back in but it didn't work I need help.
    Problem Solver:
  • 11 Answers
You have to remodify it
Posted on Feb 13, 2012
How do you repair leaking transmission oil on 2003 road king?
Take out the screws, drain the oil, remove the gasket and use brake cleaner to clean the thread holes and screws. Then put sealer like permatex on the gasket and the screws and put in back together.
Jul 26, 2014 | 2003 Harley Davidson FLHR Road king
Tip
Skyjet SJ-125-23 Common Problems/Solutions
Neutral light Never showing
  • This could be a simple shipping issue, Which if you look on the left hand side of frame in centre below seat and just under petrol tankthere is a GREEN wire, Which is normally not-connected or dis-lodged when riding, Connect wire back to other green wire near it heading towards gearboxIssue will then be sorted and electric start will now work.
Oil leaking from Left hand crank case near gear shifter
  • This is caused mainly by wear and tear on the gasket for the left crank case, just remove start motor cover carefully without loosing anything, Then Remove old paper gasket replace with new Copper gasket And/or Gasket sealant/maker bought from any HALFORDS shop for about £5
Oil pours out when I remove screw for manual turning of piston on left crank case
  • Unlike normal engines which this part would remain dry at all times, The skyjet engine which is basedof a Old CG-125 push rod engine, Oil pouring into that side and out the screw when un-screwed is commonso don't worry about anything breaking, However its recommended to empty oil from the main oil empting screwunder engine which is a 17MM Bolt and draining fully before removing any of engine casings.
Where can i buy the cheap parts for Skyjet Motorbike
  • However due to skyjet is no longer listed, Buyers must look for the kasiar parts they are exactly the same, However may be colour differences for some engine parts but the difference is instead of normal black parts which sky-jet engine has there Silver instead
on Jun 21, 2010 | Motorcycles
2003 Passat 1.8T smeills bad, using a lot of oil!
check engine for oil leaks and crank case ventalation pipes, and filters clean if nesasery remove induction pipe from turbo to inlet manifold, if oil presant check for play on turbo turbine shaft, if movement is felt replace turbo check for oil in air filter and i exceive then carry out compresion test to chech for exesive crank case presure
Dec 30, 2013 | Cars & Trucks
Cam or crank shaft sensor
It depends on which sensor and how it is designed. Some sensors are designed to function in an oil bath. Generally speaking, the sensor picks up a magnetic swipe of a gear or object as the cam or crank turns. I doubt an external oil leak would matter unless it gets into the wiring harness.
Jul 07, 2013 | Cars & Trucks
Help please
There is a dip stick screwed into a tube on the side of the crank case or a screw plug directly into the crank near the bottom (normally coloured red) If it is a screw plug then unscrew and correct oil level is near top of thread Replace plug when finished. If it is a dip stick remove the dip stick--- wipe clean ---and replace screwing it all the way I. Remove again and check oil position on dip stick Should be on top mark or top hole if there are holes.
Apr 26, 2013 | Cell Phones
Hi. I just bought a micra 2003 with 66,000 miles, but have had a tensioner on the timing chain fixed and an oil seal nearby fixed. I took it back to Charles Hurst and they spotted 2 more oil leaks one...
Hard to say, it depends on how trustworthy you think they are. From what you say, it appears to be oil seals leaking, you can take a chance and add a Wynn's product to you oil that swells and softens oil seals and stops them leaking. It would be a lot cheaper than a day in the shop and could fix the problem.
Mar 02, 2011 | Nissan Versa Cars & Trucks
Oil leak from tube
you need to replace the o ring on the oil drain dolt that should stop the leak
May 24, 2009 | 2003 Harley Davidson FLSTF Fat boy
Crack in my yz 125 2001 crank case
some jb weld shouls work fine on it just get it good and clean no oil or paint on the crack. or find a tig and weld it.
May 10, 2009 | 2003 Yamaha YZ 125
Can not start
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the two screws, ( idle and air screws ), on the outside throat of the carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine.
Change gearbox oil. 10w40 is what is needed. Also install a new stock NGK spark plug. This process should get you back on the road.
Please rate this solution. Thanks!
Apr 17, 2009 | 2003 Yamaha YZ 125
2003 Volvo S40 1.9T where is the thermostat located?
Its really easy... open the hood... looking back toward the car, its at the front of the engine, left hand side near the top... you'll see the hose coming out.. its held in with 2 large torx screws... make sure you change the rubber seal around the thermostat when you remove it.. also be aware some antifreeze will leak out.. so take proper precautions.. don't do it when the car's hot.. difficulty 1/10.. easier than an oil change.
Dec 13, 2008 | 2003 Volvo S40
Cycling Logo
18 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
