Question about Sony Handycam DCR-TRV33 Mini DV Digital Camcorder
Usb streaming with vista
Vista (64 bit) will not find my sony handycam when cinnected thru the usb for streaming
Go on the sony websitehttp://support.sony-europe.com/dime/camcorders/dv/dv.aspx?site=&m=DCR-TRV33E&site=odw_en_GB&odw_model=DCR-TRV33E
you may need the picture package cd that came with camera
Posted on Jan 14, 2009
    Sergeant:
    Champion:
  • 293 Answers
Driver for dcr hc 62e
Windows 7
* Drivers:
o The drivers needed to connect your Sony camcorder to a computer and transfer files are already included in the operating system.
* Not Supported:
o The USB streaming feature is not supported with the Windows 7 operating system.
o The Windows 7 Starter edition is not supported.
Windows Vista
* Drivers:
* Not Supported:
o The USB streaming feature is not supported with the Windows Vista operating system.
o The Windows Vista Starter edition is not supported.
* View Detailed Windows Vista compatibility information.
Windows XP
* Drivers:
* Not Supported:
o The Microsoft Windows XP 64-bit operating system is not supported.
o The Windows XP Starter edition is not supported.
Mar 09, 2011 | Sony DCR-HC28E Camcorder
Cant connect my dcr-hc24e to my windows vista 64 bit. Have my camera set to stream usb but drivers will not work with 64 bit os
upgrade the latest driver compad with vista 64 bit
here is the link to download it
http://www.sony.com.au/section/support?SR=Global%20Choice:Oceania:AU:Regionalsite:get_support
best of luck
Dec 28, 2010 | Sony Handycam DCR-HC24E Mini DV Digital...
I need a dcr-hc85 driver for windows Vista where can i get it
  • Windows Vista Starter edition is not supported.
  • The USB streaming feature is not supported with 64-bit Windows Vista operating systems.
  • The drivers required to connect most Sony® cameras and camcorders to a computer are already included in the Microsoft Windows Vista operating system.
    Note:
    In some instances, the camera or camcorder may not be recognized by the computer when connected. In this case, check to see if there is an updated driver available for your model.
    If the above link doesn't work, you can check to see if there is an updated driver at this address:
    http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRHC85
    Hope this has helped you.
    www.austintelstarservices.com
    Sep 03, 2010 | Sony Handycam DCR-HC85 Mini DV Digital...
    Sony Handycam DCR-HC42 Mini DV not recognized by Windows 7
    win vista and win 7doesn't support usb streaming. the usb driver for this model would not be compatible with your computer's OS. although, you were able to download PMB still this wouldn't work, it's basically an alternative software that you can use with the newer OS. still the device driver would not be installed. and you would get a message that "ilink connection is not detected". the reason you get that is bec the camcorder and the software is intended for use with the dv (ilink or ieee1394) connection. so if your computer has an ieee1394 card and you have a compatible ilink cable,then your good to go,it should be a plug-and-play connection (no drivers required). all you need then would be a video capturing software (like win moviemaker) to transfer videos from tape to PC. hope this helps. thanks :)
    Mar 28, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
    I want to take video from handycam and put on my mac
    Option 1:
    If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
    (Applicable for Vista Operating System Only.)
    This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
    You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.
    Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
    http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
    NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
    Option 2:
    (Applicable for Windows XP Operating System only):
    If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
    Check this Link for the instruction to transfer video to a Computer using USB Streaming.
    http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
    If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
    Good Luck!!!!!!!!!!!!
    Sep 26, 2009 | Sony Handycam DCR-TRV22E Mini DV Digital...
    Need drivers for using sony handicam digital as streaming webcam on windows vista
    If it is Sony DCR-TRV250 camcorder then it can be used with Windows XP through USB Streaming port and no driver update is available so far for Vista. Check further details on Sony Support.
    Thanks.
    Sep 18, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
    How to save videos from sony handycam to my home pc
    you need to put the camera into playback mode
    then go into the menu and go to the setup menu
    Then USB streaming and turn it on
    That should enable the computer to recognize the camera
    May 29, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
    I need dirver Windows Vista 64 bits for Handycam TRV-740
    This was taken from Sony's Website....
    Driver information for Microsoft® Windows Vista® and Windows® XP
    • The drivers needed to connect most Sony® cameras and camcorders to a computer are already included in the Windows Vista and Windows XP operating systems. With these drivers, you should be able to connect and transfer files to a computer.
    • The USB streaming feature is not supported with the Windows Vista operating system.
    • Detailed Windows Vista compatibility information is available for Sony Cameras and Camcorders.
    • The Windows Vista Starter edition and Windows XP 64-bit operating systems are not supported.
    So as you can see...the 64 bit OS is NOT supported.  The only luck you are going to have is either go to XP, Vista 32 bit...or see if there is a 3rd party driver someone made on the internet.  Try google....but I would have to say due to the complex nature of the drivers, it is highly unlikely that anyone has made a driver that is compatible.  It just has to do with how the 64 bit OS is made.  There might be a way to use 32 bit drivers, however you might run into some issues with processing and streaming.  To my knowledge of 64 bit systems, they are backwards compatible with 32 bit applications, so you can use wither 32 or 64 bit drivers....the only downside is by using 32 bit on a 64 bit machine, you are going to suffer a little bit of performance loss.  I hope this answers your questions.
    Feb 22, 2009 | Sony Handycam DCR-TRV740 Digital Camcorder
    Driver for sony dcr-pc101e
    Check Sony Support Europe web page and see downloads.
    I'm afraid Vista 64 bit has no support for DCR-PC101E yet.
    Oct 28, 2008 | Sony Handycam DCR-PC101E Mini DV Digital...
    Capturing Footage with Camera
    USB streaming does not work for Windows Vista. Use the firewire/ilink connection instead.
    Roger
    Feb 08, 2008 | Sony Handycam DCR-TRV250 Digital Camcorder
    Sony Handycam DCR-TRV33 Mini DV Digital Camcorder Logo
    915 people viewed this question
    Top Sony Video Cameras Experts
    Larry Stiles
    Larry Stiles
    Are you a Sony Video Camera Expert? Answer questions, earn points and help others
