Question about LG Cell Phones
My moblie won't switch on it just keeps flashing on the keypad
    Problem Solver:
  • 11 Answers
Problem is with the software of your mobile
Posted on Feb 13, 2012
Dropped dodge avenger keypad off roof while working now car won't start security light flashing
keypad or remote on keys? if remote, pop it open and make sure the battery is still properly in place.
May 17, 2013 | Cars & Trucks
What does this mean? My machine is very new & won't drain it won't go through a full cycle & won't spin properly now it's bleeping with this flashing up on it!
Turn off machine and check water waste filter to see if blocked should be at front at bottom of machine or at back,not sure this is the cure but hope it helps
Apr 06, 2013 | Washing Machines
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
Touch won't work
My Dear your phone keypad ic default so please change keypad ic
and keypad problem will solved
Aug 15, 2012 | Vizio Tablet VTAB1008
Phone keeps turning off and messages won't open.
hypagirl, your device has a software error, so you need to hard reset (by code or keypad) or soft reset or factory settings (by device settings), if your device is samsung try *2767*3855# for full reset, and if is nokia try *#7370# and default code is 12345, this both process will delete all data so first make a back up.Best of Luck. if my answer was helpful please rate it.
Jul 18, 2012 | Cell Phones
Microwave won't set clock
It is most likely the keypad control board has been damaged, first! unplug the microwave oven for 5 minutes, if this works the micopressor will reset, if it fails the control board will need to be replaced, a costly venture.
Apr 14, 2012 | Danby DMW1153 Microwave Oven
My kitchen aid washer stoped at my rinse cycle and ligth keeps flashing
The keypad interface on your dishwasher is faulty, It may be as simple as a broken solder joint, they recommend replacing the unit but it's worth trying to solder the connections to save some money and the worst case is that it won't fix it.
Mar 12, 2012 | KitchenAid Dishwashers
My nokia 3110c wont switch on.
PHONE IS DEAD WON'T COME ON
If the mobile phone does not switch on, it is called a dead mobile.
It can be due to many reasons
1. Water damage
2. Fall down
3. Not used for a long time ( Mostly battery is down)
(1) Check the Battery. It should show 3.7 volts or as written on the battery.
(2) Check the Battery Connector
Check two things (a) Voltage coming or not (b) shorting
Note : If there is shorting then clean the circuit in ultrasonic cleaner (Remove display, camera, etc before putting it in ultrasonic cleaner )
Clean the circuit with a soft brush and make it dry with a hair dryer or ****er.
If the shorting doesn't go it may be due to shorting in an ic,capacitor or circuit. if shorting is in ic u can check it by attaching a battery then press the on-off switch keep the battery for 10-15 seconds. after that remove the battery and check which ic becomes hot. Reball or replace that ic. If shorting is in circuit it must be removed by ultrasonic cleaner
Note - The circuit is made of three layers. if there is shorting in the middle layer it cannot be removed
(3) Check the On/Off switch & voltage at on-off switch
Note - Connect a charger. If charging is shown on display then the problem is with the on/off switch or software problem
(4) Try flashing the mobile.
(5) If flashing cannot be done then there is hardware fault we first dry solder the Flash IC & RAM IC and check in the Software. if flashing cannot be done then we dry solder/reball/replace flash ic & RAM ic.After that dry solder/reball/replace Power IC, Network IC, Crystal, CPU :D:D
Sep 21, 2011 | Nokia 3110 Cellular Phone
My Nokia E63 is not turning on, I've changed the battery, charged it with a desktop charger, on other phones it will on but on my e63, I won't just turn on. what am I to do.
1. Water damage
2. Fall down
Jul 05, 2011 | Nokia E63 Cell Phone
Cell Phones Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
