Question about Canon PC-1080F Plain Paper Laser Fax
Getting lines on paper when I copy
I am getting a line in my papers when I fax
    Genius:
  • 2,120 Answers
Open the document feeder and clean the scanner glass.
Posted on Oct 26, 2008
Tip
Get rid of the line in your faxes or copies from your copy machine
If you are getting one of those black lines in your copies from the copy machine/fax machine, it may not need a new drum.
Most likely the scanning glass is dirty if the line appears from copies that are fed through a feeder, clean the little glass strip area (usually to the left) just before the scanning area where you manually place a paper to be copied. In most cases there is a spec of something on that glass. Don't scrap it with anything abrasive because if you scratch the glass you will have a line that will never go away. In most cases a damp klenex, paper towel or soft cloth with water will work. For stubborn specs dampen your klenex, paper towel or cloth with a little rubbing alcohol. This will also work well for getting rid of any greasy smudges on the glass strip and the larger glass area on the copy machine. Most of the thime the spec is from liquid paper or white out.
If you are getting calls from people you send faxes to saying your copies have a line on it and you use a dedicated 'fax machine only', look for the glass strip and clean it as directed above. If you are receiving faxes with a line, call the sender and give them the above tip.
If this tip works, it sure beats paying for a new drum you don't need.
on Aug 25, 2010 | Office Equipment & Supplies
Line appears down right side of paper when copy is made?
If the line only appears when making copies but recieved faxes come out ok, then the scanner glass needs to be cleaned. Water and a lint free cloth should do the trick.
Sep 15, 2010 | HP 1010 Plain Paper Inkjet Fax
Big black line on paper
clean the scanner, lift the auto doc feeder and underneath is a scanner, look to see if there is white out or some other obstruction and clean with a rag soaked with alcohol
May 21, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Unwanted verticle line on fax copies
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 560 Plain Paper Fax
I get lines and can't read the right side of copies that I make with the 1270e. How do I fix this?
You have not specified why you can't read the right side of copies and I am assuming that the reason is because the 'lines' are covering the text. I can offer a solution to the lines issue.
Feb 22, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Black line down paper
Pull the doc feeder open and clean the scanner glass
Feb 11, 2010 | HP 1040 Plain Paper Inkjet Fax
I have a black line showing up on my faxed documents. I have opened it up, changed the film and re- set it, but the problem persists. The machine is about 5 years old.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 07, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
Black line down one side of paper
Lift the auto feeder cover and clean the narrow glass that the originals are scanned across...sounds like you have some dirt there -maybe correction fluid? That's the most common.
Please rate me :)
Jun 23, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Faxes I send are reduced in size and have series of black line down right hand side.
If its reduced in size during transmit or copy then simply place a letter size document in the feeder and close the two sliders up to the sides of the paper. If you don't close the slider up to the paper it will go into auto reduction
Apr 27, 2007 | Canon LaserClass LC 8500 Plain Paper Fax
Canon PC-1080F Plain Paper Laser Fax Logo
69 people viewed this question
old marine
old marine
