Question about Dewalt DC011 AM/FM Radio
Switch on no sound
Power ok switch clicks on no function
    Problem Solver:
  • 11 Answers
Radiometer fils and stops working
Posted on Feb 13, 2012
No sounds from my yamaha HTR6030 Display is OK. All function keys working.Relay clicks. But no sounds.
Try connecting different sources to different inputs or fm source if nathing produces sound I would recommend to have it check by a tecnitian
Aug 19, 2016 | Yamaha Audio Players & Recorders
I replace my machine for fuser flim unfortunately the screen shows 'E000000' How do I correct this error code?
  1. Try first to clear the error
    clearing the error may not fix the fault
    Press the *with a circle around it then press 2 and 8 at the same time then press *again /press copier touch button/function/clear/error/ok button then switch off m/c on hope it works
    also:
    Additional Functions: Click the Additional Functions button once. Do not hold down.
  2. Two and Eight Buttons: Click the 2 and 8 buttons at the same time once.
  3. Additional Functions Revisited: Click the Additional Functions button once again. Do not hold down.
  4. Copier Button: The System Management screen will open. Click the Copier button on the screen.
  5. Function Button: Click the Function button at the top of the screen.
  6. Clear Button: Click the Clear button on the screen.
  7. ERR Button: Click the ERR button to highlight it.
  8. OK Button: Click the OK button at the bottom of the screen.
  9. Power Off/Power On: Power the unit off and back on using the switch on the side of the unit. The error will be cleared.
  10. Restart eCopy:Once the unit is back up, restart the eCopy machine.
    https://www.question-defense.com/2008/11/10/canon-imagerunner-error-code-reset
Apr 14, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
How do i fix the error 000003-0000 on ir 3320?
Hi
Whilst looking through the web I found this procedure for clearing errors from ir series Canons. You might like to try it first.
  1. Additional Functions: Click the Additional Functions button once. Do not hold down.
If this doesn't work, I found a complete list of error codes here:
Error Codes Canon iR3320
There are 12 pages of them but yours appears to be on the first and related to the temperature of - or lack of - the fixing unit. From this site you can also buy a service manual which may also be helpful to you rather than the User Manual/Guide.
Cheers
Nov 14, 2014 | Canon Office Equipment & Supplies
How to fix a problem when the machine report e000001 error?
follow these steps: (with machine powered on)
1. press adittional function
2. press number 2
3. press number 8
4. press adittional function again
5. with the left arrow search for "clear" and click ok
6. with the left arrow search "engine" and click ok
7. select " ERRCLR and press ok
8. turn the machine off for about 5 seconds from the main switch.
9. power on the machine and try to make some copies.
10. if problem persist replace the fixing heater assembly
May 02, 2014 | Canon Office Equipment & Supplies
Makes clicking noise
the dial type timers normally make clicking sounds,, i wouldn't be too worried about it. it's just its way of telling time
Mar 30, 2014 | Intermatic T101 - 24 Hr. Dial Time Switch...
Powers on but no video
Guessing HP? Sounds like your video. Chip is cooked. New motherboard is required
Nov 16, 2013 | Computers & Internet
I want to clear the memory of the copier, cause it's keep getting me the same old papper and beside that it doesn't allow me to print nothing else.eventually i would like to reset the whole...
First of all you enter in the service mode with addisional function 2 8 addisional function then go clear and lick ok then all click ok,
switch off the machine after few munite switch on main power
your memory is clear.
May 19, 2011 | Canon iR 2016i Black and White Copier
Respected sir my ir400 canon xerox mashin masage is switch main power off and on.e001 i have machin switch main power off and on but problem not a solve pls discription this probem and solve. thanking...
it is related to fing unit.
you can go in service mode by pressing (additional function +2 +8 + additional finction)
touch on copier then go in function after that touch on clear
Err -then press ok
dcon then press ok
rcon then press ok
if then after problem not solved you have to replace fixing unit thermistar
because it is related to fixing temperature.
Apr 12, 2011 | Office Equipment & Supplies
Error code E00247
Well first of all you may try to reset your Image Runner by following the steps below -
1. First of all click the Additional Functions button once. Do not hold down.
2. Click the 2 and 8 buttons at the same time once.
3. Click the Additional Functions button once again. Do not hold down.
4. The System Management screen will open. Click the Copier button on the screen.
5. Click the Function button at the top of the screen.
6. Click the Clear button on the screen.
7. Click the ERR button to highlight it.
8. Click the OK button at the bottom of the screen.
9. Power the unit off and back on using the switch on the side of the unit. The error will be cleared.
10. Once the unit is back up, restart the eCopy machine.
Most of the time it works if not then post further comments for further help or information......
Good Luck!!
Thanks for using FixYa!!
Mar 27, 2011 | Canon imageRUNNER 5000 Copier
I have sony vaio S. but the wirelees is not working no wireless host shown. how can i fix it?
Selecting the wireless function Follow the steps below to select the wireless function to be activated when you set the WIRELESS switch on your computer to on. Double-click (wireless switch icon) on the Notification area at the bottom right of the desktop.The Wireless Device Switch dialog box appears. Hints The appearance of the wireless switch icon changes depending on the selected wireless function. Point to the wireless switch icon to display the selected wireless function. Alternatively, you can right-click the wireless switch icon and select "show Wireless Device Switch settings" to display the Wireless Device Switch dialog box. Select the desired wireless function from "Wireless LAN" or "Bluetooth Device". Notes 5 GHz Wireless LAN is available on certain models only. You must select at least one wireless function to perform wireless communications. The 2.4 GHz and 5 GHz Wireless LAN functions employ different frequency bandwidths, thus are not compatible with each other. Checking the check box for both "Enable 2.4 GHz Wireless LAN" and "Enable Bluetooth Device" may cause poor communication performance or a connection loss due to electromagnetic interference. Click OK. The message "Setting up the wireless devices. Process may take several minutes. Please wait." appears first, then the Wireless Device Switch dialog box is closed, and finally the dialog box that describes what to do with the icon on the Notification area appears. Note While the message "Setting up the Wireless Devices. Process may take several minutes. Please wait." is displayed, do not: place your computer into power saving mode. turn off Windows or log off from the current user. turn on and off the WIRELESS switch. Confirm the settings and click OK. The dialog box about the icon on the Notification area closes. Hint If you check the "Don't show this dialog in the future" check box, the dialog box will not appear next time you close the Wireless Device Switch dialog. To analyze the network condition You can analyze the network condition if you select either or both of the wireless functions under "Wireless LAN" in step 2 above. Click the "Diagnose" button to start Windows Network Diagnostics. When the network analysis is complete, the result is displayed. If any problems are found, follow the on-screen instructions. Hint Windows Network Diagnostics is the function to identify problems the network has and present solutions to them.
Mar 01, 2011 | Sony Computers & Internet
Dewalt DC011 AM/FM Radio Logo
120 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rani wadia
Rani wadia
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
