Question about Home
Shower switch is on permanently it is not stuck just permanently live
    Top Expert:
  • Home Master
  • 76,164 Answers
What is the make and model of the shower control
Posted on Feb 13, 2012
How do I wire up a fan which has permanent live , switched live. I don't want it on a switch , I want to work when it's humid
humid is the amount of water vapor in the air ( humidity)
fans are wired --switched live -- and permanent neutral.
there is no fan unless it is very expensive with a humidity setting in its controls that can be wired to do what you want
Dec 05, 2015 | Dryers
My car radio is not turn off when the car is turn off
This could be an issue with the ignition wiring. Most radios have 2 feeds. A 12v permanent live (often a red cable) and a switched 12v from the ignition (often a yellow cable). If the switched 12v is wired the wrong way round or linked to a permanent 12v then the radio won't switch off when you remove the key. Could be the ignition switch itself stuck on all the time also.
Jun 09, 2014 | Pac LAN11ON Gm Lan 11-bit Radio Turn-on...
How danze shower lever which changes the water flow from the permanent shower head to the removeable freehand shower has fallen out. How can it be repaired?
Don't try to repair it. Replace it. All hand held showers use 1/2" hose fittings so any brand divertor should fit. Bring the part with you as there are different styles.
May 07, 2014 | Danze Home
Headlights flicker when the car is off
The headlight relay usually has one wire that is permanently live and switches that power when operating. Try another relay in case the contacts in the relay are stuck and there is some element of power being transferred.
Mar 11, 2014 | 2004 Pontiac Grand Am
Wiring a 2 gang light switch
Okaaay, but which is the permanent live from the lighting circuit, which is the switched live back to the ceiling light, which is the neutral from the lighting circuit?
You may need to open the ceiling rose to see how the red/yellow/blue are wired.
On the switch the terminals are usually diagonal, ie L on the top matches with L1 and L2 on the bottom. L1 and L2 on the top match with L on the bottom.
So you want permanent live from the lighting circuit to go to L and a short piece of wire linking that to the other L.
One of the L1 is switched live back to the lighting circuit.
Other L1 is switched live to the cabinet light. (Red?)
Presumably you also need to connect the neutral from the lighting circuit to the neutral to the cabinet light. (Black?)
bedroom lights
Jun 04, 2012 | Electrical Supplies
Shower was working now its not only had it a few months no water coming out no light on but pull cord light is on
Check the electrical output from the pull cord switch to the shower. Both live & neutral
Mar 31, 2010 | Home
Everytime i turn my engine off i have to input the code for my cd player how do you set it
Did you fit the radio yourself? Or did it come with the car?
Normally each radio has two 12v supplies - one permanent, and one switched with the ignition. The first keeps the 'memory' - radio stations and security codes, the second provides the power to run the unit. It could be that your permanent live is connected to a car live that only comes on with ignition.
Check to make sure that you have a permanent live when the unit is switched off, and your keys are not in your ignition. If you don't then you need to find one.
May 16, 2009 | Car Audio & Video
Can not control oven temperature
Sounds like the oven control module is defective. replace module. Can order part online or from a local appliance parts supplier.
Mar 30, 2009 | Stoves 800DFDOm Dual Fuel (Electric and...
Triton T80si shower will not switch off
its the water solenoid valve stuck in the open position so when the shower is turned off the shower stays running
Dec 09, 2008 | Home
Home Logo
29 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
