Question about Gigabyte GA-7N400 Pro2 Motherboard
Ga gigabyte mainboard trouble
My freind's old ga_... gigabyte mainboard(ddr,agp,amd cpu :support)without any beep starts and i dont have any graphic in monitor.
i removed the battery for clr-cmos and nothing happaned.i removed the ram and mainboard still without beep.also i removed all hardware except cpu and computer still without any beep.cpu fan works and mainbord have nothing even beep.
i m confused and i dont know what to do.thanks and please help me
  • 59 Answers
Just because it doesnt beep doesnt mean the vid is not gone
place board on a non metal surface hooked to
monitor
keyboard
mouse
powersupply UNPLUGGED RIGHT NOW
cpu with heatsink and fan attached
ram
plug power supply in (will not shock you just dont lick it ok)
if board does not come on take a small flat head screw driver look at where the power wire would slide on cross those two pins should come on. again will not shock you.
still no video try pci (most basic video mobos support) card
still no video could be cpu I have had several of these be bad caouse no video also
try anouther cpu same setup
still no vid mobo shot sorry
Posted on Oct 24, 2008
VGA Support?
Hello here is the homepage:
http://www.gigabyte.com/products/product-page.aspx?pid=2358#sp
Your mainboard supports 1 x AGP 8x slot ( the green slot )
The new PCI-e express does not fit the socket.
When you add a bigger graphic card, you will probably need a bigger power supply.
I recommed a 500 watt or bigger.
Most external graphic cards uses 150 to 250 watts, depending of the size of the card.
I also recommed ATI/AMD graphic cards.
Such graphic card, can be bought online, or in a computer shop.
Good luck
Feb 07, 2013 | Gigabyte GA-8I865GME-775-RH Motherboard
I have a Gigabyte GA-K8VM800M Motherboard with 2gb ram. I want to disable the onboard graphics card and add another VGA card. Which card should I go for?? Will adding VGA card, show physical memory as 2gb...
Hello you can download the manual, and drivers here:
http://www.gigabyte.com/products/product-page.aspx?pid=1810#manual
You can add a graphic card 1 x AGP slot (8x/4x-AGP 3.0 compliant), supports 1.5v display card only.
And Max capacity: Up to 2GB DDR400 RAM by 2 DIMM slots.
ATI/AMD makes very good graphic cards.
Adding a graphic card on the mainboard will not slow the physical memory. It has it`s own ram.
Good luck
Jun 18, 2012 | Gigabyte GA-K8VM800M Motherboard
Nead to replace my motherboard ga-k8vm800m
http://www.newegg.com/product/product.aspx?item=N82E16813128262
So you need a motherboard that has a Socket 754 processor socket, supports AMD socket 754 processors with up to an 800MHz FSB, uses DDR Sdram 400MHz ram memory, (PC3200), and has an AGP graphics slot.
From a quick search just now I see a lot of them listed on Ebay.
NOT advertising for Ebay.
I saw other listings on the internet also. (GA-K8N51GMF-RH - Way too pricey!)
Regards,
joecoolvette
Aug 07, 2011 | Gigabyte GA-K8VM800M Motherboard
Do you give me a list of gigabyte ga-81rm memory suppor ?
307_sub.jpg GA-7N400 (rev. 2.0)
  1. Supports AMD Athlon™ XP 400MHz FSB processor
  2. Supports Dual Channel DDR400 memory architecture
  3. Supports AGP 8x interface for outstanding graphics performance
  4. Integrated 6-channel AC'97 audio with S/P-DIF function
  5. Provides 6 USB 2.0 for high-speed connectivity
Oct 12, 2010 | Gigabyte GA-7N400 Pro Motherboard
I have a problem with my board Gigabyte GA-G31M-ES2L, encounter no display & no beeps even though I remove the RAM in the board please help me to solve this problem?
Do the fans still start spinning ? And did you do a CMOS clear ?
You should also try booting it without a graphics card and/or any other audio/network card, etc, so you only have the CPU and motherboard (and also try it with 1 RAM bank and without). When it beeps, it's probably alright (implicating other failing hardware).
When you hear no beeps at all (but the fans spin), it's pretty likely that the board is gone. You might want to doublecheck the powersupply and CPU nevertheless.
Aug 18, 2009 | Gigabyte GA-G31M-ES2L Motherboard
Gigabyte MB no boot ga-ma790fx-dq6
did you replace the battery on the mainboard if its weak it will not beep
Aug 04, 2009 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Graphic card for GA-8IPE1000 series
HI there.
There are loads of makers of memory and graphics cards out there to choose from.
For the ram i would recommend Corsair or Kingston, you can get this ram as a matching pair so the both run at the same speed, the best ram to get is DDR 400.
As for the graphics card, i recommend ATI radeon X1650 Pro 512MB graphics card.
These upgrades will make your machine purr like a kitten with an excellent gaming experience.
Good luck and thanks for choosing FixYa!!
May 27, 2009 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
Graphic card for motherboard
Looks like you have a AGP 8x (3.0) slot. You can find a multitude of AGP cards here, and at a low price.
Jan 24, 2009 | Computers & Internet
GA-MA790FX-DQ6 Mobo not POSTing Should i reset the bios??
no beeps, indicates you have faulty CPU or mainboard.
  • remove all components even RAM and CPU.
  • insert only CPU and Speaker (without RAM or any other componet).
  • Boot and try to hear, there must be long beep for missing RAM, if not then try to re-insert the CPU or change the CPU/Mainboard.
Thanks and Good Luck
Iqbal
May 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Gigabyte GA-7N400 Pro2 Motherboard Logo
200 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
