Wilding electric typewriter TW1500E
There is load squeaking noise when switched on (perhaps something's jammed or requires lubricating ). How do I remove the bottom cover? I've unscrewed the 4 feet but it still can't be removed. Or does the top cover need to be removed, if so what holds that on? Label at rear of typewriter reads "Model SP8700" and "Made in Japan"
  • Hal Anthony Feb 13, 2012
    Ooops typing error for 'load' read 'loud'.
    Think SP8700 may be type designation for Silver Reed typewriter, so perhaps Wilding TW1500E is a re-badged equivalent Silver Reed model.
jsrock516
  • 5911 Answers
SOURCE: Electric bottom oven element, part
Just follow this link for step-by-step instructions on how to replace a heating element in an electric oven:
http://www.fixya.com/support/r469407-replacing_bake_or_broil_element_in
This write up is for MOST electric ranges. It is a simple repair if you follow the steps. If your range configuration is different from what I have provided to you, please let me know. I hope this helps you.
Posted on Jun 30, 2008
SOURCE: rear differential axle removal
remove the 'locking bolt', once the pin is out the c-clips shoud fall out unless this is a floating axle in which the axles are attached at the hub.
Posted on Sep 12, 2008
Geno111
  • 183 Answers
SOURCE: Remove sticky label from paper guide
depends on what kind of machine, they are all a little different.
Posted on Nov 22, 2008
mdavinci
  • 20 Answers
SOURCE: CMOS Battery dead, No Post, No System Beeps
bloody hell! All the ones I have used (IBM, Compaq and Dell) have clear access to the battery!
That sounds very frustrating!
My Solution, drop kick it out the window if you have to replace another!
Posted on Mar 18, 2009
SOURCE: Eureka model 4335 - belt removal (top cover)
loosen two screws on either side on top of the housing lifts off the top. exposing the roller and the broken belt.
Posted on Mar 25, 2009
We have an old IBM Selectric typewriter and when you type it squeaks. (this is the only time it squeaks) What can we do short of sending it out for service.
Actually there isn't much you can do because there are many things that can cause it to squeak. There are gears, clutches, pulleys and more that may require grease or oil or just cleaning. Only a qualified service technician can tell you which is necessary to resolve your issues. I know it isn't what you want to hear but that is the best way to get it done and done right.
Jul 07, 2014 | IBM Correcting Selectric III Electric...
My bosch Nexxt WTMC 3300 dryer makes a squeaking sound when the load is light -- drying a larger/wetter load less likely to make the noise.
I had a similar problem with a different model Bosch dryer. First I made sure the dryer was unplugged. I found, after taking the front and rear panels off, that one of the front wheels that supports the drum was broken. I replaced the wheel and it works fine with no squeaks.
Jan 01, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
Carriage wont move on underwood 565 typewriter
Belt is slipping or broken..When it sits for awhile the belt stretches.
Dec 17, 2012 | Underwood 1980s 565 Cr Electric Portable...
Dryer has started a squeak, squeak, squeak noise as the drum is turning. What could it be?
Hi kitchen nich...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers are in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear they will make a thumping type of noise.
If your drum rollers have too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove the rollers and clean the shafts that the roller rolls on, remove any hair,dust,etc from roller and shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
Please take time to rate me
Aug 06, 2011 | Dryers
The dryer squeaks loudly. How do I stop the squeaking? Thanks
Hi nicksue182...
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
This is a FREE answer, Please take time to rate me
Jul 25, 2011 | Maytag MDE6000 Dryer
I have a maytag tumble dryer, & it squeaks loudly when it's running
Hi killlerrrbee....
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vasoline.
Jun 01, 2011 | Maytag Dryers
Squeaking/Moaning noise coming from passenger front wheel
Wow that sounds like a wheel bearing about ready to be replaced. Have a service tech check your bearings.
May 17, 2010 | 1995 Lincoln Continental
My maytag neptune dryer thats electric when it is drying makes very load squeaking noises. Its sounds very bad, but it is still drying the clothes? what might be the issue?
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Check your rollers for flat spots, if they have flat spots on them replace them.
If the rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Nov 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a loud squeaking noise from a GE electric dryer drum..
I am not sure what plastic part you have, but there should be no small plastic parts in your dryer drum or at least not the ones I have worked on before.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Oct 28, 2009 | GE DBXR463EBWW Electric Dryer
Squeak when running the dryer
It's the roller axles and/or the motor shaft. Remove the front of the dryer and lubricate same.
May 27, 2009 | Hotpoint NBXR463EBWW Electric Dryer
79 people viewed this question
jasbo
jasbo
