Question about Epson Stylus R265 InkJet Photo Printer
Clone cartridges stop epson r265 working - Epson Stylus R265 InkJet Photo Printer
5 Suggested Answers
SOURCE: epson r265
The ssc does not support the r265 but the latest version has the r270 which will work with r265download and try
bgh
Posted on May 28, 2008
SOURCE: Epson R265 Ink pad full
I have problem with r265 Epson. I installed new ink cartridge from epson but the printer could not recognize it. I installed SSC Service utilitry, but the programme could not recognize printer at this status. What can I do?
Posted on Nov 13, 2008
aicaxz
  • 511 Answers
SOURCE: 2 red lights are flashing on my printer epson R265(END OF LIFE TIME SERVICE)
U can find resetter (SSC Utility or R265 Adjusment) at indoreset.blogspot.com. Reset the waste ink counter.Good luck.
Posted on May 29, 2009
  • 5603 Answers
SOURCE: epson r265 keeps printing purple pictures I have
You probably need to purge the yellow ink channel. Use the cleaner found in refill kits and gently force the cleaner through the channel where the yellow ink cartridge attaches.
After cleaning, you will need to "charge" that ink channel either by many cleanings or by forcing the yellow ink into the channel before installing the cartridge.
Posted on Nov 03, 2009
Epson printer CX9300 error B73 cannot recognise ink cartridge
A clone cartridge is a type of third-party ink cartridge that uses an identical chip to the original ink cartridge. People buy cloned cartridges to save money, since original cartridges are more expensive. However, sometimes the Epson printer does not recognize the cloned ink cartridge. After you install the cartridge, you might receive a message that says "An ink cartridge cannot be recognized." In this case, you will have to disable the Epson printer monitor.
Read more: How to Make an Epson Printer Recognize Clone Cartridges ' eHow.co.uk http://www.ehow.co.uk/how_6163069_make-printer-recognize-clone-cartridges.html#ixzz1YgKjqw42
Instructions
    • 1
      Install your cloned ink cartridge into the Epson printer.
    • 2
      Go to "Start > Control Panel" on your computer.
    • 3
      Double-click on "Printer."
    • 4
      Right-click on the icon of your Epson printer and choose "Printer Preferences" at the bottom of the dialog box.
    • 5
      Click on the tab entitled "Speed and Progress" and see the Epson printer monitor box.
    • 6
      Check off the box that says "Disable Epson Status Monitor" to turn off the ink monitor.
    • 7
      Click "Save" and close the windows. Your cloned ink cartridges should now work.
Epson may also display an error message if you refill the ink cartridges.
Mar 26, 2011 | Epson Stylus Multifunction Inkjet Printer/...
My r265 wont accept compatable ink cartridges is there a setting to change this so i can use them?
mcdevito75 here, Best Bet type in Epson inkjet printer in search and ask the computer if these compatable cartridges can be used and how.
Jun 23, 2010 | Epson Stylus R265 InkJet Photo Printer
I have an Epson Stylus R265. It is telling me all
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 05, 2010 | Epson Stylus R265 InkJet Photo Printer
Hi, I have just changed the yellow cartridge on my R265 with proper epson ink cartridge and it is saying that it is incompatible. Can you help please?
Hi If you are using compatable inks try taking the ink cartridge out and put it back in again try this three or four times to see if it will accept it if not try a different cartridge you can sometimes get a duff one The earlier models have a different cartridge than the later models epson altered them and changed the chip
Oct 25, 2009 | Epson Stylus R265 InkJet Photo Printer
Ink tanks on my Epson R265
Did you refill them or buy refilled cartridges? Epsons all have a chip on the ink tank. once that chip registers a certain count it renders the cartridge dead. If it gets refilled it has to be reset, which 99% of the refill places don't do. It's also possible that the contacts on the carriage have worn down or been punctured. Also look in the back of the carrier and make sure you don't see any small holes in the white ribbon cable.
Jun 14, 2009 | Epson Stylus R265 InkJet Photo Printer
Epson Photo R265 stopped working
this means your printer needs to be reset let me no and i will see if i have the reseter
Feb 02, 2009 | Epson Stylus R265 InkJet Photo Printer
Nov 03, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson R265 printer
ive had this problem too try putting the pollystyrene that holds the top of cartridge during transit back in when inserting cartridge into printer i found this worked for me
Feb 01, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson r265
Check status monitor if empty or low:
Replace if empty ect:
Soak the cartridge nozzles upright in Flush Solution for 6 hours dry and retry , make up a A4 Paper colour printing page with each colour band about 1" high x 8" wide and print out 4 - 6 pages checking which colour band is poor:
Keep printing if improvement noticed:
if not
Resoak the offending cartridges and repeat:
also can
Use cleaning cartridge on offending colour slot/s then retry:
Dont use the head cleaning utility to much as it is programmed to disable your printer after a pre-set number of cleans and will have to be serviced:
cx3200@tiscali.co.uk
Dec 21, 2007 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus R265 InkJet Photo Printer Logo
65 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
