Question about Sony CDX-L400X CD Player
Cdx-lx400 Cd working fine ;but no output radio fm,mw;lw....automatic seek works;capture some stations;bu no sound in radio mode ...
4 Suggested Answers
KaeZoo
  • 156 Answers
SOURCE: Sony CDX-SW200 AM/FM/CD unit
I'm not completely certain about yours, but on most Sony decks you can get to a manual tuning mode by pressing and holding the seek buttons. In other words, if you press and release the tuning button, it will automatically jump to the next channel. If you press and hold the button for a second, it should beep and possibly start flashing an "M" on the screen. After that, it should stop scanning when you release the button, without jumping to the next station.
Posted on Aug 10, 2007
SOURCE: Sony CDX-GT310. Installed by
Called a shop in VA and their opinion was that the tuner section of the unit failed. Cost of the part, $80. Then, labor and shipping. I can buy the new model (GT320) for about $95. I opted for buying a new unit.
Posted on Aug 12, 2008
SOURCE: sony cdx ca650x has no audio output from tuner, CD is OK
Tuner might be defective , check to see if tuning voltage varies
Posted on Jun 11, 2009
While my FM setting works perfectly, I can't pick up any stations in MW or LW. Any Advice?
Check with an Audi Dealer. There are some stations that went Digital along with the TV stations. Your receiver may be outdated.
Oct 22, 2011 | 2004 Audi allroad
Unable to tune in to programmes on LW, MW and SW bands. FM working fine
If you are experiencing bad or NONE AM (MW) reception ,if your receiver has an external antenna connection point here is the solution... It should also have a ground connection as it is rare such a point does not accompany an external antenna connection.
The problem with MW reception is the vast frequency range of the MW band as" 540-1760kHz "
means nighttime fade out, and even heavy static and distortion..( less than SW )
in order to receive a station on LW and MW bands you need to have a "Loop Antenna " that normally supplied by manufacturer..if you cant locate it ,you can buy it in any electronic store..it is a very cheap accessory..additionally both LW and MW works good in daytime with powerful radio stations in your vicinity ..espacially LW..not much stations on these days..except in Europa..MW works better and more stations come after sunset ..
SW band is a little bit different.if you really want to listen SW in depth ,and if your receiver has multiple SW bands as well ,you then need special SW antenna to be attached to your receiver..otherwise it is not worth to listen it due to heavy static and distortion on the band..,unless you want it..just for testing and to see what is available in your area pls attack a plain wire (about 1 meter ) to ext antenna plug and try to search it..if you desire to learn shortwave -Listen To The World please visit the URL below.
http://www.hamuniverse.com/shortwave.html
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote for us
to continue f
or Helping out the Community :)
Jul 07, 2011 | Audio Players & Recorders
Cannot get any sound from fm. i have stations and aerial is ok just have sound on mw/lw any suggestions? gail
seems the fm tuner is blown, did you check antenna and connections? if ok then contact service for fm tuner problem.
regards
Feb 19, 2011 | JC Whitney SONY XPLOD 10-DISC CD/MP3...
I can t figure out how to connect my radio up like i got the cd player to work just fine but the radio doesn t work
Press the source button to select fm, press and hold BTM button until Btm flashes. This will automatically store stations for you. Page 8 in this users guide covers same as well as manually setting stations. You do have the antena connected?
http://www.docs.sony.com/release/CDXGT20W_200.pdf
Oct 23, 2009 | Sony XPLOD CDX-GT200 CD Player
Cd player works but not radio
No, it uses the same source.
Have you checked which band you are selecting? It has 3 FM bands, LW and MW, right?
It may not be a relay, but an untuned station.
Aug 19, 2009 | Sony CDX-GT210 CD Player
Pioneer premier deh-500ub presetting stations
Storing the strongest broadcast
frequencies
BSM (best stations memory) lets you automatically
store the six strongest broadcast frequencies.
1 Use MULTI-CONTROL to select BSM in
the function menu.
2 Press MULTI-CONTROL to turn BSM on.
The six strongest broadcast frequencies are
stored in the order of their signal strength.
# To cancel, press MULTI-CONTROL again.
Tuning in strong signals
Local seek tuning lets you tune in only those
radio stations with sufficiently strong signals
for good reception.
% Press LOCAL repeatedly to select the
desired setting.
FM: OFF—LEVEL1—LEVEL2—LEVEL3—
LEVEL4
MW/LW: OFF—LEVEL1—LEVEL2
The LEVEL4 setting allows reception of only
the strongest stations, while lower settings let
you receive progressively weaker stations.
You can also perform this operation in the menu
that appears by using MULTI-CONTROL.
Selecting alternative frequencies
When the tuner cannot get a good reception,
the unit automatically searches for a different
station in the same network.
1 Use MULTI-CONTROL to select AF in the
function menu.
2 Press MULTI-CONTROL to turn AF on.
# To turn off, press MULTI-CONTROL again.
! Only RDS stations are tuned in during seek
tuning or BSM when AF is on.
! When you recall a preset station, the tuner
may update the preset station with a new frequency
from the station’s AF list. No preset
number appears on the display if the RDS
data for the station received differs from that
of the originally stored station.
! During AF search, sound may be temporarily
interrupted.
! AF can be turned on or off independently for
each FM band.
Apr 20, 2009 | Car Audio & Video
Sony CDX-GT310. Installed by Circuit City about 15 months ago. CD works fine. No sound from radio (both AM & FM). I've manually tuned through the range of stations with no reception. Checked...
Aug 11, 2008 | Sony CDX-GT310 CD Player
Ford 6000 eon radio unit - unit has no volume on fm stations, or occasionally the vlume comes on when first turned on and then fades after about 20 - 30 seconds. It finds stations on automatic search but...
Alas
This is a very common fault with these units, repair is a little expensive, as it's the FM tuner unit. It's an ebay job I'm afraid, pay around £45 for a second hand 6000 with code.
Aug 03, 2008 | Audio Players & Recorders
Aug 10, 2007 | Sony CDX-SW200 AM/FM Compact Disc...
Pioneer cdxfm35
how to hook up pioneer cdx-fm35
Jul 02, 2007 | Pioneer CDX-FM687 6-Disc CD Changer
Sony CDX-L400X CD Player Logo
48 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
