Canon pixma mp800 error 5110
How to fix this problem?
SOURCE: Canon Pixma MP600r - error code 5110
i took the printer into a service center and they have replaced the board and the paper feed. seems to be common
thank god its still under warranty!!
Posted on Jun 15, 2008
Binary Bob
  • 91 Answers
SOURCE: I have an error code
Issue: ERROR LCD: Error code (5xxx through 9xxx) appears on the display
1. Press ON/OFF switch to reset the multifunction device 2. Press Stop/Reset and ON/OFF to reset the printer 3. Removing paper jams MP500 / MP800 / MP950 4. The MP800 may require repair 5. Unlock the scanner lock switch (MP800 / MP950)
Posted on Nov 06, 2008
komguy
  • 2306 Answers
SOURCE: canon pixma mp800 error code 6A00
6A00 means you need a new purge assembly. That's the unit that cleans the printhead. Part number is QM2-3032-000 around $30.00 but a shop should install it.
Posted on Jul 24, 2009
SOURCE: Error code 5110 Canon Pixma MP500
Error 5110 = Kann den Schlitten nicht anheben. (mechanischer Fehler)
Posted on Sep 13, 2009
bschilz
  • 2049 Answers
SOURCE: Canon Pixma MP800 error code 6A00 - what does it
6A00 is a problem with the sheet feed unit.
Canon says you need to send it to them to fix.
Before you do, turn the printer off and try moving the carriage back and forth a few times. At the same time, look for any debris in the area that could be jamming the sheet feed unit.
Turn the printer back on and see if the error goes away. Several other people with this problem report solving it this way.
Posted on Oct 05, 2009
How do i fix error code 5110 on the canon iP4200
According to the following link, it pertains to the carriage lift mechanism. Perhaps something has gotten jammed or its not seated properly. Canon iP4200 PIXMA Photo Printer Service Manual Page 13
May 29, 2014 | Canon PIXMA MP530 All-In-One InkJet...
Cannon mp800 will not print. Shows error 5110
I had the same problem but fixed myself.
What I had to do was open the lid and turn the printer on. While the printer is going through its startup GENTLY push the print head and cartgridge tray to the right.
What I think happened with mine, was it was turned off while the lid was open and an ink cartridge was out. When turned on it could not test or clean, hence the problem. So gently pushing to the right it was able to shift everything back into place for startup test. Hope this helps some of you.
Mar 08, 2011 | Canon Pixma MP500 All-In-One InkJet...
Error code 6A00
Step by Step troubleshooting canon pixma MP800 error code 6A00
The Problem Canon PIXMA MP800 Error 6A00
1. The print head cartridge keeps locking itself up on the right hand side.
2. Frequent 5100 errors even when the printer is on standby
3. Even when I wipe up the print cartridge, the next print will
mess up the bottom of the print cartridge with ink again.
Step for troubleshooting canon pixma MP800
1. Opening the cover and wait for ink carriage to center
2. Pull out power cord
3. Pushed carriage to far left (should slide easily)
4. Used paper towel and wiped purge unit a lot of times
(press down to soak paper towel with ink). Repeat until the paper towel is relatively clear.
5. Used diluted napisan (oxygen-based cleaning agent in the
ratio of 1:3 with powder:water) and soaked paper towel
6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white.
7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down
8. Slided carriage back to original position
9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
Mar 01, 2011 | Canon PIXMA MP800R All-In-One InkJet...
Error code 6A00
Hope this helps.
Feb 10, 2011 | Canon Pixma MP800 All-In-One InkJet...
Canon Pixma MP810 Error messages 6A00, 5110, 5C20, 5100
Pixma pro 9000
service error 5110 after paper jam.
BEST QUICKEST WAY TO FIX THE PROBLEM!!!!
DUST BLOWER ALL OVER THE AREA INSIDE
AND TURN IT BACK ON U SHOULD HAVE SOLID
GREEN LIGHT FOR SURE!!!!!!!!
DAMN I CAN'T BELIEVE I BROUGHT THIS SAME PROBLEM
TO SERVICE CENTER THE FIRST TIME!!!
NO MORE WORRIES!!!
Oct 25, 2008 | Canon PIXMA iP5300 InkJet Photo Printer
Sep 28, 2008 | Canon Pixma MP500 All-In-One InkJet...
5110 ERREOR is carraige cant life. this can be down to a few things, carriage is stuck on the purge unit or the logic board is at fault. best to take it to a Canon dealer for repair or contact a supporter dealer who can do a chargeable call for you. in the uk i have few contacts . hope this helps
Dec 23, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon Pixma IP8500
Take it to a different service centre. Also, ask them what the 5110 error is. I don't have access to my service manuals at home, so I can't look it up.
You can also look around on the web, often you can find the service manual and download it for free.
I would really recommend taking it back to the service centre. If you can't get any satisfaction from them, call Canon, they should be informed about that service centre.
Sep 23, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
201 people viewed this question
jasbo
jasbo
