Question about Sony Walkman Audio Players & Recorders
I try to reset player then after they connot back the menu it was now hang?
I am using Firefox the latest version and connot get Adobe Flash, the latest version, to function. What am I doing wrong?
Uninstall your flash from the Add/Remove Program menu in the Control Menu. Try installing flash again. Sometime the flash player have issue installing correctly. Make sure you download the flash player directly from Adobe's site. Normally, if the player is installed correctly it will play a very short video on Adobe's site to verify the player is working properly.
Nov 24, 2013 | Computers & Internet
My nano apple ipod is hanged
Reset iPod nano (if it isn’t responding) Slide the Hold switch to HOLD and back again. Press the Menu and Center buttons at the same time for about 6 seconds, until the Apple logo appears.
Mar 07, 2010 | Apple iPod nano
My SANSA e260 froze up. I can't shut it off. Has a blank screen was trying to charge it.
Make sure the player is fully charged. 1. Connect the player to your computer. 2. Make sure the computer detects the player. NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary. To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player. If that does not do it, re-seat the battery: Then try and see if it will come on with out the battery hooked to your computer, which I see you have done but did you change modes MSC to MTP . next delete the song it keeps hanging on and re-copy it back on to the player from a different folder or re-rip it from the CD and copy it into a new folder then re-copy to the player.
Feb 03, 2010 | SanDisk Sansa e260 MP3 Player
Zen Xfi hanged-up
Use the reset button by pushing in with a needle. This is on the bottom of the unit.
Sep 04, 2009 | Creative Labs Zen Micro MP3 Player
Hang
Try to reset the ipod, it should solve the problem.
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Jul 09, 2009 | Apple iPod MA446LL/A MP3 Player
30gb apple ipod hanging proble how to reset
Generally, you hold in the Menu and center buttons to reset it. If that doesnt work, try Restoring it from iTunes.
Jan 07, 2009 | Apple iPod MA446LL/A MP3 Player
IPod hang
if your ipod is hanging just press the menu and the center button at the same time for about 10 sec and it should reset the ipod.hope thi one helps!
Dec 20, 2008 | Apple iPod MA446LL/A MP3 Player
My nano hang!
If your ipod just hangs, have you tried doing a reset by holding the menu and middle buttons?
If that doesn't work, before you connect it to your laptop, make sure that you have the latest iTunes loaded on your laptop.
Hold the menu and middle buttons until the screen goes black and then quickly hold the middle and play/pause button until you see a checkmark and the words disk mode. Now connect it to your computer and do a restore.
If it doesn't check the connector at the bottom. You may have some bent pins in the connector at the bottom. Unfortunately, that will cause communication problems with the computer and ipod. Hope that helps.
Oct 28, 2008 | Apple iPod nano
Apple ipod hang
Try resetting it by toggling the hold switch and putting it back in the off position. Then press and hold the center button and the menu button for about 6 seconds until the ipod goes off and the Apple logo appears. After that, it should work like new. Hope this helps.
Oct 06, 2008 | Apple iPod nano
Phone hang
try a master reset of the phone , see if that helps the issue....if not take it to a mobile repair center and have them check it out further.
Apr 08, 2008 | Motorola Mobility RAZR V3
19 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
