Question about Nokia E75 Cell Phone
E75 got totally stuck
My E75 has got stuck! It switch on and afterwards I can not do anything! I want to restore but nothing is working what to do?
Error code E75 in al frigidair affinity FAFW3801Lw3. What I need to do? help please. Thanks!!!!
E75 has nothing to do with the spin cycle, pump, door switch, or anything like that. E75 means there is an issue with your temperature sensor circuit. That is part of your control board, which means that the control board will need to be ordered and replaced to fix the E75 error code.
Nov 21, 2015 | Televison & Video
E 75 code stop machine from spinning
E75 has nothing to do with the spin cycle, pump, door switch, or anything like that. E75 means there is an issue with your temperature sensor circuit. That is part of your control board, which means that the control board will need to be ordered and replaced to fix the E75 error code. Here is a link to the part you need to order.
Oct 30, 2012 | Frigidaire GLTF2940ES Front Load Washer
Hello, my e75 was working properly and i set a new alarm, but i realiazed afer that that it didnt ring. i looked at it it was back and no single light on it. what should i do? plz i have a great data on it...
Please try and reset the phone select the restore factory settings on the menu- phone settings and restore by typing 12345.
If this wont reset remove the battery and keep aside for a while before you set it back into the phone.
Final option check with Nokia care.
Mar 02, 2011 | Nokia E75 Cell Phone
I have a E75 handset since Oct 2009.I am facing aproblem since this morning that the phone is hanging ( screen not responding and does not take connection).I removed battery couple of times to check..still...
If your phone not responding, I think you should reset your phone. But before you do this, make sure you have put off your SIM and memory card from the phone, and make a back up of your data.
There are three steps of resetting the phone :
Nokia E75 Soft Reset:
This option restores the .ini files from the ROM.
Does not erase data (photos, videos, documents) nor applications from a third party. Key Code *#7780# (click this combination of keys on the keyboard in the mobile)
Nokia E75 Hard Reset:
This option restores the original operating system from the ROM.
Formats the C: partition and deletes all data including the memory card. Key Code *#7370# (click this combination of keys on the keyboard in the mobile)
You can also achieve Total Reset by pressing and holding down following keys: * + 3 + Green Button (call) immediately after turning the mobile on.
Note: To proceed to reset, the battery must be full and the
mobile device connected to the charger. If during the course of reset, the mobile stop receiving electricity it can ruin the internal flash memory of the mobile device and stop function.
Or you can check this sites :
http://anythingnokia.com/nokia-tips/nokia-e75-full-reset-soft-reset-and-hard-reset/
http://discussions.europe.nokia.com/t5/Eseries-and-Communicators/Reset-E75-using-7370/m-p/540002
Hope this help and be kind to rate this answer, thank you.
(^_^)
Jan 07, 2011 | Nokia E75 Cell Phone
I have a nokia E75 and i cannot hear anything through the earpiece but it works on loudspeaker
Full format solution for NOKIA
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Mar 10, 2010 | Nokia E75 Cell Phone
How do i transfer my contacts fr se k800i to nokia
mark all the contact then try copy or move
Oct 11, 2009 | Nokia E75 Cell Phone
Nokia E75 bluetooth disconnects and then reconnects
if your phone is under guarantee contact nokia care
atul jain
atuljain.webs.com
Oct 09, 2009 | Nokia E75 Cell Phone
Nokia E75 Cell Phone Logo
55 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
