Question about Hotpoint Refrigerators
Turns off in cold weather
Freezer started to defrost
3 Suggested Answers
  • 161 Answers
SOURCE: started defrosting in freezer. pulled out and
let compressor cool down,before plugging back in
Posted on Apr 16, 2010
  • 28 Answers
SOURCE: I moved my freezer to
Freezers & Fridges were not designed to operate in extreme cold conditions. They are designed to operate at room temp. It could be sending an inaccurate temp signal to the thermostat due to extreme low temp outside.
Posted on Nov 27, 2010
Hi We have a whirlpool side by side no ice maker in the past week the freezer is cold and frosty fridge is warm up to 15degrees at the top bottom of fridge is 5 degrees. Top vent from freezer is not in...
3 things
If you have ice on the freezer side.
1. defrost timer not working
2. blower fan failed, if it has one
3. defrost limit switch failed..
i dont think it is #2 but 1 or 3
last but not least your defrost heat coil has failed
Dec 18, 2010 | Refrigerators
Both fridge and freezer are turned up to maximum cooling but they just aren't cold enough even though the weather is mild. Icecream is very soft - barely frozen and fridge temp is about 8 degrees...
Sounds like a failure to defrost.
Look on the freezer rear wall inside the freezer for ice bukdup.
If there is ice the defrost components ,must be replaced.
Dec 01, 2010 | Fisher and Paykel Active SmartĀ® E522BR...
Freezer is working good but refridgertator is not cold
This problem could occur due to various reason.First you have to resolve for the cause of the issue.
First Check the back wall or floor of the freezer section for frost.The Freezer(evaporator) fan is running?.This fan problem is very hard to detect.
The DC motor for the fanwears out the RPM's are effected.It gives the illusion that it is running fine,but it doen't have enough force to supply air circulation for both the freezer
and the refrigerator See weather the condenser coil for
blockage from dust and the condenser fan is running.
If you have frost in the freezer there is a problem with the defrost systemand the freezer will start to warm eventually as well as the fresh food section.Defrost system consist of:
1)Defrost terminator.
2)Defrost heater/s.
3)Defrost timer.
4)Ddaptive defrost control.
Any one of this part may be defctive.So we have to replace or repair accordingly.
Defrost timer:
Try turning the screw with screw driver in clock wise direction or anticlockwise direction and wait for 35 min to check Defrost timer has any problem.
Solution for If you have frost in the freezer and make the fridge work:
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with both Doors
wide open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Sep 02, 2010 | Whirlpool Refrigerators
Self defrosting fridge/freezer
Good day,
That is normal if the room or area is too cold. If the room temperature drops below 55 degrees Fahrenheit then that problem will start to show up.
All manufacturers state the machine will start to unbalance below that temperature.
Mar 13, 2010 | Bosch Refrigerators
Fridge not getting cold enough. the temp in the fridge is 66.6! help please! less then a yr. ago i replaced the gasket, so i know it's not that. i also have it on the coldest setting. i wasn't having...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 14, 2009 | Refrigerators
Freezer not freezing
It sound like you may be having defrost issues,Check to see if you have a build up of ice on the inside rear wall of the freezer.If so,You will need to have the defrost timer,defrost element,and the defrost thermostat checked.
Please rate this.
Dec 27, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Freezer won't work in garage in cold weather
Modern fridge/freezers are built to automatically defrost themselves. To do this they require that the room temperature is well above freezing to allow the defrost to take place. If you site the freezer in too cold an environment it is unable to defrost itself and will eventually stop working. It sounds strange but if it is too cold the freezer cannot work. The solution is to buy and fridge/freezer that does not automatically defrost itself if you want it to work in a cold environment.
Dec 06, 2008 | Refrigerators
Need a freezer for garage in the Dakotas
Refrigeration units don't care for the most part how cold it gets with exceptions. The oil is not a concern, neither is manual or auto defrost. Refrigeration units that are required to operate in cold temperatures, say below 30 degrees F. have crankcase heaters on them to heat the oil which keeps freon moving out of the oil and the bottom of the compressor. Otherwise when the compressor starts the cold freon will we sucked out of the bottom of the compress with a large quantity of oil which can destroy the compressor. Another item used for cold weather application is a fan control sensor which keeps the condensing temperature up or the unit will again remove the oil from the crankcase. It may work fine for a quite a while, but it will fail in continuously cold temperatures.
Nov 22, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire Freezer Runs Warm in Cold Weather
hi there the problem you have is that the temp in the garage is to low, the fridge part of your fridge freezer has priority and will only activate the compressor when req'd ie. in cold weather the fridge may not need to switch on the compressor for days at a time this is when the freezer will defrost.
All you can try doing is having some very low heating in your garage in the cold weather
hope this is of help.
Dec 11, 2007 | Refrigerators
Refrigerators Logo
15 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
