Question about Apple iPad 32 GB 3G Tablet PC
I dont remeber my prepaid telstra number for ipad
Ave a lock screen on my Ipad and cant remeber my apple ID
If your iPad is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPad unless you use the correct passcode or you erase it. And the following guidance will show you how to unlock a disabled iPad with iTunes.
Step 1. Connect your iPad to the computer with via a USB cable that your iPad has trusted.
Step 2. Launch iTunes. If you've synced your iPad with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPad and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPad". Click it to reset your iPad. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Step 5. Select "Restore from iTunes backup" during the setup process. This will load the backup that you created so that all of your data is restored.
http://www.leawo.org/tutorial/how-to-unlock-a-disabled-iphone-with-without-itunes.html
Dec 04, 2016 | Apple iPad Tablets & eReaders
How do I find the IMEI code for a mini iPad?
Find iPad Mini IMEI number:
Navigate to settings-general-about, and scroll down to view your device's IMEI number and other details.
Device body and packaging
Check the back case of your iPad, and you'll find the IMEI number printed near the bottom. If you have the packaging too, look for the IMEI number on the barcode label.
ITunes
Connect your device to your Max or PC, fire up iTunes and click on your device name to open the summary. You'll see your devices name and capacity listed alongside an image of your model - simply click the field below the Capacity field once or twice, till it shows you the IMEI number. You can also right click the number to copy it.
How to find your iPhone or Cellular iPad IMEI number
Nov 21, 2015 | Apple iPad Mini
Do iPad have an IMEI code?
ITunes
Nov 21, 2015 | Apple iPad (16 GB) WiFi Tablet PC
Which ipad has this serial #,Is this for ipad 1,2,or3? DN6FXJPYDKPH
Serial Number: DN6FXJPYDKPH
Model:- iPad 2 (WiFi)
Codename:- No codename assigned.
Build Country:- We don't know where this unit was built.
Build Year:- This unit was built in the first half of 2011.
Build Week- Week 26 (June)
Production Nr.:- This unit was number 2038 to be built that week.Serial Number: DN6FXJPYDKPH
http://www.appleserialnumberinfo.com/Desktop/index.php
Jun 16, 2015 | Apple iPad (16 GB) WiFi Tablet PC
I have purchased the iPad Air 2 and I have the Net Gear A6300 plus
The process is fairly simple.
  • Choose the setting app on your iPad (the one with the gear icon).
  • Choose Wi-Fi
  • Make sure the Wi-Fi setting slider is green (on).
  • click on your network name under "CHOOSE A NETWORK"
  • enter your password (if necessary) for that network
Your network information will be saved and you will never have to enter that information again.
If you don't see your network, check to see if your router is working, and move closer to your wireless router to complete the settings
If you don't receive a wifi signal where you use your iPad, you might reposition your router, or move your iPad closer, or get a wifi repeater (like an Apple Airport Express) to extend your signal.
Mar 27, 2015 | Apple - iPad Air 2 Wi-Fi 64GB
MY DEVICE IS AN APPLE IPAD.I FORGOT TO MENTION IT..... SORRY
Check out this guide on how to setup an email account, and you may discover why you can't get mail. I would have to see your mail settings to know why, and that is not advisable or practical anyway.
Add an email account on your iPhone iPad or iPod touch
Dec 15, 2014 | Apple iPad 32 GB 3G Tablet PC
How do I retrieve my screen lock password
first, back up the iPad to a computer (macs are awesome) with a usb charger and save everything incase u have to restore to factory settings. then.....im not sure. call apple
Nov 12, 2014 | Apple Sony Ericsson XPERIA X10 Unlocked...
How do I determine what generation is my iPad?
on the backside of the iPad is a model number: determine-generation-ipad-jq4dbyibaqf10wv4m2e43laj-1-0.jpg determine-generation-ipad-jq4dbyibaqf10wv4m2e43laj-1-2.jpg
Model iPad (1st generation) iPad 2 iPad (3rd generation) iPad (4th generation) iPad Air iPad Air 2 Picture 200px-ipad_1_psd_mockup.png 200px-ipad_3.png 200px-ipad_3.png 200px-ipad_3.png 170px-ipad_air.png 170px-ipad_air_2.png Model Number[99] A1219 (Wi-Fi)
A1337 (Wi-Fi + 3G) A1395 (Wi-Fi)
A1396 (GSM model)
A1397 (CDMA model) A1416 (Wi-Fi)
A1403 (Wi-Fi + Cellular (VZ))
A1430 (Wi-Fi + Cellular) A1458 (Wi-Fi)
A1460 (Wi-Fi + Cellular (MM))
A1459 (Wi-Fi + Cellular) A1474 (Wi-Fi)
A1475 (Wi-Fi + Cellular) A1566 (Wi-Fi)
A1567 (Wi-Fi + Cellular How to find iPad IMEI ICCID serial number
http://en.wikipedia.org/wiki/List_of_iOS_devices#iPad
Sep 21, 2014 | Apple iPad Tablets & eReaders
How do i unlock a proscan plt8816k if i dont remeber the email and password?
Your problem doesn't make sense. You cannot try the password too often. Try a factory/hard reset.
Google search "reset android tablet"
May 10, 2014 | Proscan Recertified - PLT7035 4GB NAND...
How can I tell if I have an iPad 1 or 2
Here's info from: http://support.apple.com/kb/ht5452
The (original) IPad ...
  • The model number on the back cover is:
    • A1337 on the iPad (Wi-Fi + 3G)
    • A1219 on the iPad (Wi-Fi)
  • Black front bezel
  • 30-pin connector
  • Standard SIM tray on the iPad (Wi-Fi + 3G)
  • The IPad 2 ...
    • A1397 on the iPad 2 (CDMA model)
    • A1396 on the iPad 2 (GSM model)
    • A1395 on the iPad 2 (Wi-Fi)
  • White or black front bezel
  • 30-pin connector
  • The micro-SIM tray is on the right side on iPad (GSM model only)
  • FaceTime and rear cameras
  • Nov 23, 2013 | Apple iPad 64 GB WiFi
    Apple iPad 32 GB 3G Tablet PC Logo
    61 people viewed this question
    Top Apple Tablets & eReaders Experts
    Virgil Wolter
    Level 1 Expert
    Aaron Galvan
    Level 1 Expert
    Yoav Shilon
    Yoav Shilon
    Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
