Question about Whirlpool GHW9150 Duet Washer
Whirlpool duet front load washer banging Loudly during spin cycle as if off balance
  • 3 Answers
Just wanted to add that our GHW9250MP0 suffered a similar problem. Using the disassembly procedure above we discovered that the basket support spider had completely corroded away from the spindle while the bearing was still in fine shape. At just under 10 yrs of age and thus still under warranty, Whirlpool sent the replacement basket and outer tub half, complete with gasket, free of charge. The above procedure was indispensable for a DIY job. Thank you blue extc322.
Posted on Sep 19, 2013
  • IndyJeff Sep 23, 2013
    ALERT! The warranty replacement spin basket has a shorter shaft than the original, which means the original shaft nut will not work. You must get the new nut: part number W10283361, which Whirlpool would NOT send me. I bought it at RepairClinic.com for $23.45 plus shipping.
  • IndyJeff Oct 07, 2013
    ALERT#2! When rehanging the tub assembly to the frame, make certain the springs use the same mounting hole as the old tub. There are two sets, and hanging the assembly from the wrong set will cause door seal failure.
    Top Expert:
  • Whirlpool Master
  • 76,673 Answers
More than likely the washer tub bearing is worn out, this happens due to seal failure and soapy water getting into the bearing, the soap is very corrosive and the bearing fails quickly, this in turn destroys the drum vibration dampers and makes it much worse. The cost to repair this is about $400
Posted on Feb 13, 2012
Coldcut
  • 1554 Answers
SOURCE: Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Posted on Mar 04, 2008
  • 240 Answers
SOURCE: washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Posted on Mar 14, 2009
  • 353 Answers
SOURCE: Whirlpool Duet GHW9150P Front Load Washer is
BEARINGS
Posted on Dec 15, 2009
techbuster
  • 5081 Answers
SOURCE: whirlpool duet washer makes banging noise during
Sounds like the rear tub bearing has gone bad. Remove the rear panel and belt. Grab the drum drive pulley and check how it's moving up & down and side to side.
Posted on Sep 18, 2010
blueextc3221
  • 15935 Answers
SOURCE: whirlpool duet washer went out of balance during
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 27, 2010
Washer balancing load, during spin cycle wasker shakes and walks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Mar 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
During the final spin cycle, our front loading whirlpool is making a really loud noise - it sounds like a train is going through the house. It is in the basement on a concrete floor.
If the washer is brand new, look on the back panel and make sure the 4 transportation bolts have been removed. The bolts should be roemoved completely - they are only necessary to protect the washer during transportation.
If the bolts are removed, adjust the front two legs to be 1/4 inch higher than the back two. That 1/4 inch will balance the washer during the spin cycle, perfectly.
Apr 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer sounds like off balance during spin
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer vibrates during spin cycle
Front loaders have to be situated on solid flooring such as a basement or they will vibrate.
http://tclaundryrepair.com/
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Loud Noise during spin cycle
drum bearings are gone,it would cost too much to repair,the drum shaft would to be repalced as well.Sorry
Dec 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
790 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
