Question about Zanussi Washing Machines
Start light comes on but machine doesn't work no other lights come on
Model FLE 111w start light comes on but no other lights, machine does not turn on please help
4 Suggested Answers
  • 6277 Answers
SOURCE: I have a Frigidaire washer model ftf2140fs1, the
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Jul 09, 2011
  • 6277 Answers
SOURCE: I've used my machine twice
there is a problem either with the door lock or probably the 'door locked' sensor requiring a service call, sorry ;-0(
John C
Posted on Sep 04, 2011
  • 6277 Answers
SOURCE: i have a servis 1200rpm
Methinks you could do with a manual- for now and later!
TO OBTAIN ONE (FROM ANYWHERE) YOU WILL NEED TO KNOW/FIND THE MODEL NUMBER AS IT IS CRITICAL- IF NOT ON THE FRONT TRY THE MANUFACTURER'S PANEL WHICH IS PROBABLY AT THE BACK, SORRY!
Now- unfortunately FixYa cannot provide manuals direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
John C.
Posted on Sep 20, 2011
Frigidaire front load washer model LTF7000ES0 got out of balance with a heavy pillow and we had to stop it. Now it won't do anything. Everytime I start it, the door light comes on as usual, then a
Check to see if the door sags at all and doesn't line up correctly with the door latch. Then check to see if the drum wobbles when you rotate it yourself when not in use.
Jul 30, 2012 | Frigidaire ATF6000ES Front Load Washer
My kenmore front load washer doesn't want to start all lights are working but nothing happens even the door won't lock
your door switch is the problem,where the door latch goes into the machine a little switch sites behind this a safety feature and if this is broke the machine will still switch on but will not work it will need replaced they are cheap.adrianxxx
Jun 02, 2012 | Kenmore 44072 Front Load Washer
Zanussi 1116
I would call an appliance tech. This definately is an advanced issue required by a tech to diagnose.
May 06, 2012 | Washing Machines
Kenmore commericial washing machine model # 110.20172001 lites up but wouldn't advance
Have the timer tested. If that doesn't remedy the situation, have the wiring checked in the machine.
Apr 17, 2012 | Kenmore Washing Machines
I've used my machine twice this morning but now it clicks on to lock the door but the red light doesn't come on and machine doesn't start the cycle. Any ideas?
John C
Sep 04, 2011 | Candy CNW136 Front Load Washer/Dryer
Washer won't start. Power is on, pressed power, then pressed permanent press, then water temp, then start. There is a red light on spin cycle and it just beeps and doesn't start.
Hi - if that red led light comes on as you press start - then the display module is faulty - however it's not always the case - often its the motor controller module thats faulty..
Your call - display module first and hope it works or controller.
The manufacturers recommended procedure is to replace the display module (primary) if it still doesnt work then replace the control module (secondary).
Cheers
Jun 27, 2011 | Fisher and Paykel GWL11 Top Load Washer
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
Door light always on/start button flashing- machine not working
i have just fitted a new pump to my Zanussi FLE 1416w washer, the main power light is on but the start button does not light up.
Can you help.
Oct 14, 2009 | Zanussi FLE1416W Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
