Question about Hitachi 70VS810 70" Rear Projection HDTV
Tv won't cut on red lamp light stays on when cut on red/blue lights flash.
  • 927 Answers
SOURCE: Hitachi Ultravision Digital 55" hdtv
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
Posted on Sep 09, 2008
  • 5 Answers
SOURCE: tv no picture 50vf820 red blue lights on?
Yes you should order a new lamp and replace it. if you are not real handy with tideous electronic tasks, consider buying the lamp in am enclosure for an additional $30
Posted on Jul 16, 2009
johnnydiode
  • 647 Answers
SOURCE: tv will not power up blue power light flashing,red
The lamp is likely blown - it is loacated behind the front panel and can be pulled out to check - unplug set and do not touch front of lamp.
Posted on Oct 11, 2009
ericvb2005
  • 194 Answers
SOURCE: When I turn the Hitachi tv on there are three
no..thats hard one to fix it...
go to the expert technician so that they know what the real problem about
Posted on Oct 19, 2009
  • 8457 Answers
SOURCE: tv not turning on
Ur tv,projection lamp been use alot about 2 years or more?The lamp must replaced the lamp life span it over.
Posted on Apr 05, 2010
Mitsubishi dlp tv model wd-62627 wont power on when i plug tv in green light flas then will stop then i try to power on tv after after green light stops flashiing after oabout 30 sec red lamp light co
Inspect the lamp first to see if shattered--set has a self check feature also:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
May 30, 2012 | Mitsubishi WD Televison & Video
Our tv won't turn on light blinks a couple minuate and then turns read again and lamp light flashes red
A possible bad lamp if not replaced recently or removed and at least examined. What is model number and what have you tried so far?
Apr 19, 2012 | Sony Televison & Video
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
TV won't turn on - the front blue power light and red lamp light blink. Does this mean the lamp needs to be replaced?
Yes.The tv projection lamp inside the tv right now it is been inside the tv like a 1 1/2 or 2 years already.The tv been on daily and in used like 4 or 5 hrs tv watching daily?Yes,than the tv projection lamp life are ending and the causes.
May 08, 2011 | JVC HD-52G886 52" Rear Projection HDTV
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Televison & Video
TV WILL NOT TURN OFF
Greeting inmiltown,
It sounds like your approaching the end of your lamp's life. Most projection televisions have internal lamp timers. These lamp timers usually give you time to buy a new bulb before it needs to be replaced.
I hope this helps.
Jon
Go Ahead. Use Us.
Apr 24, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
Open Questions:
See all Hitachi 70VS810 70" Rear Projection HDTV Questions
Hitachi 70VS810 70" Rear Projection HDTV Logo
48 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
