I can't get the digital display(clock,oven temp, ect.) to come on. when I push the bake button I hear a click and then another. is there a fuse to replace? Thanks.
-   I have the same exact problem. I looked up a diagram and figured it must be the "Control Unit", which the PP poster said she was told. Does anyone know if I can replace this myself?-   mars315
Nov 27, 2008
-   I have the same problem. I had a repair guy in and he told me it is the main control module-   Guest
Our digital display light is very dim. I called the parts line and they told me I would need to replace the whole display board which is 216.60 Part number 486752 No light bulb.
bottom oven heating element does not work top heating element works maximum oven temperatur is...
(More)
bottom oven heating element does not work top heating element works maximum oven temperatur is around 225, does not get up to 350 degrees as set
Our Thermador rdds30vrs oven suddenly stopped working. The whole electrical display is black, no...
(More)
Our Thermador rdds30vrs oven suddenly stopped working. The whole electrical display is black, no oven light, nothing. It is like someone pulled the plug. The circuit breaker is fine and the blower and fan work so power is getting to the unit. Any ideas?
Temperatur display on the control panel became dim, I cannot read it, repair is possible or I need...
(More)
Temperatur display on the control panel became dim, I cannot read it, repair is possible or I need to replace the control panel (almost $300.00 auch)
RDSS30 - Bottom heat element in oven will not heat up. Top element is working so there is electric...
(More)
RDSS30 - Bottom heat element in oven will not heat up. Top element is working so there is electric going to the oven.
oven cleaning does not work because oven door will not lock. Turned the clean cycle on and the door...
(More)
oven cleaning does not work because oven door will not lock. Turned the clean cycle on and the door alarm comes on since the locking mechanism does not trigger. Relay?? Control board?
