Question about HP L1706 17" LCD Monitor
My computer will read my USB stick but won't let me access it
Tevion Dvd player won't read burned cd's or dvd's.
Transfer your .avi movie files onto a USB stick & simply plug them into the Tevion DVD player.
Select the usb button on the remote to activate & choose which film to play from the menu that pops up.
Mar 10, 2013 | Televison & Video
Won't access computor
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jun 24, 2012 | Panasonic Lumix DMC-TZ15 Digital Camera
Can I import camera pics to a Dobly Home Theater laptop, by Acer?
First a nitpick: your memory card is Memory Stick Pro Duo, it's not an SD card. Secure Digital is one specific type of memory card, distinct from xD, CF, Memory Sticks, and other memory card types.
Okay, not that I've got that off my chest, yes you can import pics to your laptop. Just connect a card reader to the USB port and then put your Memory Stick into the reader. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files.
Card readers should be available at just about any department, electronics, or office-supply store. One important point to remember is to make sure you get a card reader that can read Memory Stick Pro Duos. If you get, for example, an SD card reader, it won't do you any good.
Jun 11, 2012 | Sony Cybershot DSC-T200 Digital Camera
My canon 40D won't read the CF card anymore and says "CF CARD FULL"
check for bent CF pins. make sure there is room on the CF card.
busy is normal
Jun 02, 2012 | Canon EOS 40D Digital Camera
Sylvania SDVD6660 usb won't read portable hard drive
your hard drive must be formatted for FAT32 and NOT NTFS.
May 08, 2012 | Televison & Video
Computer won't read my memory stick pro duo. Computer won't read my Droid SD card and I am using the adapter.
is it possible that the auto play window just isnt poping up. go to the start menu > my computer> the look to see if it shows up there. have a great dat
Aug 25, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
Non system disc or disc error fix
Hi, do you have a floppy disk, cd or usb stick inserted in your computer? Try removing such items and reboot as it may be trying to read these before the hard drive.
Check the boot order, when you first turn on your computer, access the BIOS menu (may need to push Delete, or one of the function keys eg F2, F8, F12 etc).
Check the boot order to ensure the correct hard drive it listed. Try moving the hard drive to the first option and reboot.
If removing any cd, usb stick etc doesn't help, try removing the hard drive and see if you can access it from another computer. If you can't access it, your operating system nay be corrupt and you may need to reformat.
Jul 28, 2011 | Intel Motherboard
Computer isn't recognizing my Samsung PL120- Instructions have read that if you connect the camera via USB the program should automatically install. It doesn't. If i look under removable devices...
Use a card reader. Since your computer has a USB port, you can get a card reader that reads SDHC cards. This is exactly how I do it on my computer.
Jul 07, 2011 | Samsung PL120 Digital Camera
Cannot download pics off camera. Computer not recognizing camera Cannot find software to re-install
If your computer does not recognize the camera when you plug it in to the computer and you do not have access to the software needed, you will need to find another way to get the pictures onto the computer straight from the memory card. If your computer has a memory card reader, use that because that's the easiest way to access pictures on a memory card. If your computer does not have a memory card reader, you can buy a USB adapter that your memory card can fit into and your computer can read through USB. They are cheap and useful. Here's a good one for 12.40 from amazon.com that reads many types of memory cards including:
MMCmobile, SD, SDHC, MMC, MMCplus, RS-MMC; MiniSD,miniSDHC; microSD, microSDHC; MMCmicro; CF Type I and II, Microdrive; MemoryStick, Memory Stick Pro, Memory Stick Duo, Memory Stick Pro Duo; MemoryStick Micro (M2)
http://www.amazon.com/Kingston-Flash-Memory-Reader-FCR-HS219/dp/B00109Y2DQ/ref=sr_1_1?s=electronics&ie=UTF8&qid=1309913206&sr=1-1
Jul 06, 2011 | Nikon COOLPIX L18 Digital Camera
Cant download from camara to pc need to dpwnload program dont have disc
If your computer does not recognize the camera when you plug it in to the computer and you do not have access to the software needed, you will need to find another way to get the pictures onto the computer straight from the memory card. If your computer has a memory card reader, use that because that's the easiest way to access pictures on a memory card. If your computer does not have a memory card reader, you can buy a USB adapter that your memory card can fit into and your computer can read through USB. They are cheap and useful. Here's a good one for 12.99 from amazon.com that reads many types of memory cards including:
  • CompactFlash Type
  • CompactFlash Type II
  • Memory Stick
  • Memory Stick PRO
  • SmartMedia
  • xD Picture Card
  • SD
  • MultiMediaCard
http://www.amazon.com/SanDisk-SDDR-88-A15-Hi-speed-Reader-Package/dp/B0000AKVHF
Jul 03, 2011 | Cameras
HP L1706 17" LCD Monitor Logo
112 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
