When setting up a list of programmes after adding one programme the box jams,to continue I have to restart the box why?
hotuna
  • 288 Answers
SOURCE: honeywell st7000
what type of system do you have? cool/gas heat, heat pump, electric cool & heat. split system or package unit?
Posted on Mar 14, 2008
IrishDruid
  • 2712 Answers
SOURCE: remote control codes list for a sagem settop digi box
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
SOURCE: Camera is NOT communicating with computer
If your computer came with Vista preloaded, please try this:
From Control Panel, create a new user with admin priviledges
Log off. Log on as that new user.
Reinstall the program as the new user
This works with some programs, and not with others. I'd be interested to see if this is one of the programs that won't work under a manufacturer's tweaked OEM install, since there are some programs that won't. It may explain why some Vista users can get it working and some can't - those with the full retail or self-upgraded upgrade version won't have the problem since they won't be using specially "tweaked" profiles created by their machine's manufacturer to bypass Windows Vista restrictions on driver updates.
Good luck, and if it works - please post back and let people know.
Posted on May 26, 2008
SOURCE: Wharfedale DVDR24HD250 DVD Recorder When set
Products such as this will use an internal tuner to tune channels, this tuner will not detect your televisions freeview stations, to record from your television, connect scart out from tv to the scart in on the recorder, then select the scart A/V channel, use the television to select the channel you want to record, you will not be able to record 1 freeview channel and watch another freeview chanel as you only have 1 digital tuner (in the television) the recorder does not have freeview built in.. hope that helps
Posted on Oct 10, 2008
  • 45 Answers
SOURCE: Thompson recordable freeview box
It's probably a corrupt file. Probably the first one in your library.
What you need to do is go into the library and quickly delete that file.
You need to press delete and confirm before it has had time to notice the file is corrupt.
I think it's green then blue, might be blue then green. I forget.
BTW, If anyone out there knows how to make use of the USB port on these things, can you let me know?
Posted on Dec 23, 2008
The tv listing Is not working
contact your service provider. the problem is in the setup box
Nov 11, 2013 | Televison & Video
Fisher & Paykel dryer DE60F60EW1 has suddenly stopped working when I tried to change the program. How do I reset the machine
Here are a couple of possible reasons it stopped and solutions from the manual.
Adding/removing laundry in standby mode
If you want to add or remove laundry into/from your machine after the drying programme has
started, put the machine into Pause mode by pressing the START/PAUSE/CANCEL button. The
drying process will stop. Open the door at Pause position and close it again after adding or
removing laundry. Press START/PAUSE/CANCEL button to start the programme.
Any laundry added after the drying process was started may cause the already dried clothes in
the machine to intermingle with wet clothes and the result will be wet laundry after the drying
process is over.
It is not recommended to add laundry after the programme is started as it will increase the
programme time and energy consumption.
Childproof lock
There is a childproof lock to prevent any programme interruption due to the pressing of keys
while the programme is on. The loading door and all keys except the ON/OFF key on the panel are
deactivated when the childproof lock is active.
In order to activate the childproof lock, press on the StARt/PAUSe/CANCel and BUzzeR CANCel
buttons simultaneously for 3 seconds.
Fig.6 Using the
childproof lock
To start a new programme after the programme is over or to interrupt the
programme, the childproof lock should be deactivated.
To deactivate the childproof lock, press the same buttons for 3 seconds.
Two beeps will sound when the childproof lock is activated. A single beep
will sound when the lock is deactivated.
I was able to view the manual by a Google search and the third item on the Google search list was the manual, but it would only come up by selecting "quick view", otherwise it would crash the Acrobat reader plugin.
Jun 03, 2012 | Toys
OLDER WHITE ROGERS PROGRAMMABLE THERMOSTAT. BATTERY INDICATOR WILL NOT GO OUT AFTER REPLACING BATTERIES. CANNOT SET UP PROGRAM. BATTERY INDICATOR REMAINS ON.PUT IN THREE SETS OF BATTERIES, STILL THE SAME.
Try removing the battery and disconnecting the "R" wire for approx 10 minutes, then reconnect and reinstall good battery........sort of like restarting a computer.......we're hoping this will reset something. If you continue to have problems and are certain without a doubt that the battery is good, then the problem is in your thermostat.
Apr 02, 2010 | Honeywell Electronic Programmable...
How can i stop programmes starting at start-up
go to start then run type cmd (enter) this will bring up the command box type msconfig (enter) the ua box will come up just hit continue and a box will come up go to the start up tab un check the items you don't want to start on start up the restart your system. you may get a message when you reboot that the system has changed just allow it because you made the changes and you are set to go.
Apr 12, 2009 | Toshiba Satellite A200-0ET00X Notebook
Query about listening to radio stations
I created a 'favourites' list of programmes and added the radio channels. Then I could select them in the same way as I did my favourite TV programmes.
Dec 29, 2008 | Televison & Video
I have a Lexmark x5470 and evertime i start my computer now i get an error message which says im32fax.dil not found. How do i stop this from occuring.
Please follow the instructions below.
Step 1: Start the System Configuration Utility
Click Start menu, click Run, type msconfig, and then click OK.
The System Configuration Utility dialog box appears.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Load Startup Items check box.
3 When you are prompted, click Restart to restart the computer.
After restarting system.
1. Log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK:
Note: Doing this startup programmes will not run in the background however you can start the programmes later from start all programmes.
Please feel free to get back to me If you need any further assistance.
Regards,
Mohammed.
Aug 05, 2008 | Computers & Internet
BUS DEVICE RESET FUNCTION
the bus settings may be the settings that have been changed by roxio, if you havent uninstalled the previous burning programme. Try uninstalling any burning programme you have, restart the pc and install the programme you require. If it continues you may need to uninstall the drive, by way of :- my computer>properties>hardware tab>device manager and look down list to dvd/cdrom drives and click '+' sign to your dvd line and right click and uninstall. Restart pc and it will automaticaly install again, ready for use.
May 11, 2007 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
Cant find how to get picture out over air and also how to get pictures in my cam gallery out to others or use my self as id on im
you do not need to open the camera up to use it in your IM programme. The programme itself will need to be set up so that it knows you have a camera, so in the optins or settings or preferences menu the cam will need to be set up and also need to enable in the menu somewhere something similair to 'show others I have a web cam'. When you click open a video call the camera will automatically turn on and you can adjust the size and volume to suit. As for pictures, you use the camera software to do this and in options or preferences there will be a default place where the pictures will be stored, eg my pictures. To send a picture within the IM programme you use 'send a file' and it will ask you then to browse for the file or photo, click open and it will load ready for your IM recipient to accept and download it, if you are sent one then it will probably go to 'my downloads' folder or 'my received files' folder. in your firewall or security programme in the allowed programmes or allowed settings make sure Yahoo messenger is in the allowed list, if not add it in whatever way your programme works. If you have to pay your ISP more money to add to the allowed list, then cancel the security software, and use a freeware one. Paying for added security, when it needs to be allowed and not stopped, it's a rip off, you do not need to pay for any added security, in fact you can readily download more than adequate programmes for free on the net, namely 'Zone alarm', and most of these ISP security programmes are no better than a reputable free one.
May 09, 2007 | Logitech QuickCam Communicate STX Personal...
Bauknecht GSX4756 dishwasher
I have this problem frequetly - it's an easy one to fix! Just press the programme button which changes the programme setting you want (on my built-in GSX4756 it's the last button on the right) and keep it pressed in until the beeping stops. Then start it again (will probably be on the rinse programme if it's like mine).
Feb 08, 2007 | Bauknecht 24 in. GSFP3988 Built-in...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
