Question about Mordaunt Short 309W Subwoofer
No Power - LED not lit.
My MS 309 Sub has suddenly stopped working. There is now power getting to it, have done the obvious and changed the plug fuse, does it have an internal fuse or is it likely to be something more serious? Appreciate any help you van give. Cheers Andy
  • RonE1211 Jun 01, 2008
    I have the same problem. All of the sudden, no LED light for power, have tried several plugs and made sure connections are tight inside but still no light or power getting to it.
  • Anonymous Dec 06, 2008
    Atlantic Technology 422Sb subwoofer suddenly stopped working. Operator's manual is of no use. I'm hoping it simply needs a new fuse, but there are no instructions.
Open up the back of your gale 3080 and check the 2 fuses situated near the transformer.They look like 2 silver cylindrical shapes.Check that they have not blown if they have the will cost you around £2 to replace.Better than the 50 quid you will pay when you take it to your hi fi dealer to open up the back of it.
Posted on Aug 21, 2008
  • 3 Answers
If your control center is damaged then your sub will not function.
Posted on Aug 08, 2007
    Novelist:
    Champion:
  • 275 Answers
The Mordaunt Short 309W Sum woofer is an Active Sub woofer, which means it has an internal Amplifier Circuit. In all likelihood some component insude this Amplifier circuitry is faulty. Get a professional Technician to have look. should not really cost you much, unless the Techie knows the cost of Morduant short Speakers and charges you based on this. Cost of Oil change in Ferrari or Beetle is the same, unless the guy tells you that ferraris are costlier, so Oil change is also costlier!
Posted on Aug 12, 2006
Change main fuse but still not working right
First of all, nothing wrong with the fuse. A fuse is nothing but a short piece of wire with a resistance value. If the unit turns on, fuse is fine. The fact that the headphones you plugged in are working tells you that the music is finding it's way up to that point. You must realize that the speakers themselves have additional circuitry that the headphones don't use. If you could obtain a diagram for the circuitry you might find that a capacitor or a diode or a transistor got "zapped" when the high voltage was applied.
If you have this diagram and you don't know what component is defective, can you post that diagram and I would be glad to help!
Mar 02, 2014 | Bose Audio Players & Recorders
LED Panel now working
same problem on mine - suddenly no light at all on the touchpad, fridge getting power, haven't heard compressor come on yet but just noted the problem in the last hour. Did you find your problem yet/??
Jan 21, 2014 | KitchenAid Refrigerators
Planet Audio PX1500M Amplifier Problem
Check the FUSE to ensure that current is not cut off.
Jul 16, 2013 | Planet Audio PX1500M - 1500W MOSFET...
Altec lansing ada885
All of your speakers get power from your sub. The volume control may have failed or the connection to the sub may be loose or broken. The power light indicates only that primary power is getting to the sub; the amplifier ICs may have failed. It will be necessary to open up the sub (if possible) to find out what failed.
Nov 12, 2012 | Altec Lansing Audio Players & Recorders
Unit will not turn on
did you turn it off or unplug it? not to sound too obvious, but make sure it's still plugged in properly and the switch is on. if the led is lit on the top, it's getting power, so it's not the fuse. if not, the fuse is located on the power supply board inside the projector. if the led is lit and the fans don't turn on, it still may be a power supply problem. if the fans go on and not the lamp, could be the lamp, ballast, or main board. if you need to send it in for repair, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 28, 2009 | InFocus ScreenPlay 4805 Multimedia...
Active sub has stopped working
I have 2 12" kenwood speakers on a 1000 watt amp ... the other day they cut off but the speakers arent blown, i replaced every fuse in the amp and the amp still cuts on when i turn the car on, yet the amp seems to not be pushing the speakers ...i also looked at the main fuse under the hood of my car but i cant tell whether its blown or not, why is my amp not pushing out any power?
Mar 31, 2009 | Audio Players & Recorders
Sub has died overnight
Change the fuse - located at the 220V input. Use a knife ti release it. Then the system will work again.
Oct 08, 2008 | Creative Labs Gigaworks S750 Computer...
Power LED lit, Servo LED lit as well, no output
check the power cables on the amp and the inputs.isome time when ground cable disconnect the lioghts will light up any way. depending on the way ur vehicle is ground ed .toyota chssis r usually posite un like the norm which is neg.rating please
Jan 21, 2008 | Infinity BASSLINK Car Subwoofer
Jensen JS1000-A sub stopped working, why?
Is is possible that the receiver's subwoofer configuration turned off? double check your speakers setup in the receiver...Just an idea.
Jun 30, 2007 | Jensen JS1000-A Subwoofer
Intermittent power on problem, monitor now completely dead
See other post regarding IC901 Please feel free to RATE me if it helps
Aug 27, 2006 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Mordaunt Short 309W Subwoofer Logo
1,743 people viewed this question
Top Mordaunt Short Audio Players & Recorders Experts
Steve Allison
Steve Allison
 Grubhead
Grubhead
Tom Chichester
Are you a Mordaunt Short Audio Player and Recorder Expert? Answer questions, earn points and help others
