Question about Saws
Nutool MS201 I am unable to lift the saw to start cutting
    Genius:
  • 1,212 Answers
There should be a lock, either a pin through the hinge portion or a locking tab. Either one should be a bright color.
Posted on Feb 15, 2012
Can I purchase eye piece for nutool NTG6L grinder/sander
says not to Canada. May be good for you?
Nutool (2) - Nutool
nutool.pl/gb/1_nutool?&p=2List of products by manufacturer Nutool ... Dust collection bag , easy sanding belt replacement , continuous running ... Bench Grinder NUTOOL 150W/150mm.
other suppliers
nutool NTG6L spares Google Search
Apr 23, 2017 | Tools & Hardware - Others
The Bush on my Nutool mitre saw ms250p can you get a spare I was informed that they are not made please help
Boa noite!!! Preciso de saber se me conseguem arrancar aquela pe?a carreto onde engata o disco... Modelo nu tool power ms250p
Aug 07, 2012 | Saws
Not cutting in straight line
Normally blade overheating. Improper blade or too few teeth for material, teeth not sharp and/or offset enough for proper width of cut. Teeth must cut wider than blade. Inexpensive blades tend to do this quickly. Other possibility: Bad bearing, check for play with saw unplugged. Blade should have little wobble. Other possibility: Saw body cracked/damaged(allowing shaft to skew) or very cheap saw unable to handle material
Sep 25, 2009 | Saws
Unable to lift the saw blade Makita Miter Saw
Look at the pivot point on the rear of the miter saw for the push/pull locking pin. The pin is there so you can lock the saw in the down position for easier carrying. To unlock the saw, simply pull the locking pin out (Makita calls this the "stopper pin"). Then you can use the saw and easily raise and lower it for cutting.
As you might find it helpful to have, I have included a link from the Makita web site for a free copy of the owners manual that you can print or save for future use and reference. It has some handy info on use and care of your saw.
http://makita.com/en-us/Assets/images/Products/LS1030N/owners_manuals/LS1030N.pdf
Hope you find this Very Helpful and best regards!
Sep 20, 2009 | Makita 10" Miter Saw LS1030N
Cutting stair stringers with circular saw
the start of the cut is starting to close up and pinch the back of the blade once you have gone past centre,if the blade is past the starting edge you can tap a small wedge into the start of the cut and that will stop it .I AM AN EXP SAW PERSON TO PROVE IT I ONLY HAVE A THUMB, AND ONE REATTATCHED FINGER ON ONE HAND .that happened on a bench saw only the back of the saw blade lifts the wood and for some reason i pushed it back down,DUMB ..Be careful and think before you do , But a wedge will solve your problem
Aug 19, 2009 | Saws
I HAVE THE JET 414458 HVBS SAW.THE SAW CUTS ROUND STOCK CROOKED.IT LOOKS LIKE THEBLADE IS IN CONTACT WITH THE STOCK AT THE START OF THE CUT AND ABOUT .250 AT THE END OF THE CUT THE STOCK IS 1" IN DIAMETER
There are two possible reasons for your band saw to cut crooked.
1 is the set on one side of the saw blade has worn down and you need to change your blade, or
2 your band saw blade is not square to the bed of your band saw.
If the blade is brand new and it still cuts crooked then you need to square the blade to the bed. To check if the blade is square to the bed, lift the head of the saw up a couple of inches and take a square and set it on the bed. Slide the square up to the blade and to see if there is a gap between the edge of the square and the blade. Try to pick a spot on the blade where the tooth is straight or bent away from the square. If there is a gap you'll need to move both blade supports in or out until there is no gap between the edge of the square and the blade.
If you are unable get it squared yourself, contact the place you bought the saw from. They maybe willing to send a service tech out to do it for you. Some band saw blade makers are also willing to send a service tech out to correct any problems that you may have. Lennox is one such company that may send a service tech if you are using their blades.
Hope this helps you,
Hatter1
Mar 06, 2009 | Jet 414458 HVBS - 56M Horizontal/Vertical...
Wiring information Re: Yamaha Computer speaker model # YST-MS201
Hi Robert,
Try to locate your manufacturer's websites or surf to google, this might help. You can ask what you need , or maybe they will ask you for a price or fee. You may request free download in google.......good luck..
Mar 23, 2008 | Yamaha YST-MS201 Computer Speakers
Saws Logo
99 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
