Des my washing machine need hot water
I have a combi boiler which has broken can i still use my washing machinedoes it require hot water from the boiler or will it heat the cold supply up many thanks Donna
SOURCE: no hot water help
have a ariston euro combi boiler ,the problem to get hot water i have to turn the heating on to get hot water. but now it only run for a few min then run cold please help
Posted on Feb 28, 2008
gittos73
  • 244 Answers
SOURCE: not heating cold water
this could be 2 possible symptoms 1 the thermostat which gets the heater element to work. 2 it is the heating element that is faulty if the element has gone then this is about £15 to buy which u get both thermostats which u might has well replace both at the same time now if its the heater element then this will be around £20-25 to replace now my best suggestion is call out an engineer that doesnt charge any call out fee this will tell u exactly which if these it is if its thermostat then do it yourself easy job which will only take u around 30 minutes to do from start to finish if its the heater element then get them to do it which should cost around £65 to do this is because it needs to be sealed properly otherwise it will leak and cause more problems in the long run
Posted on Jul 21, 2008
  • 86 Answers
SOURCE: relocation of hotpoint aquarius 1000 washing machine
You don't need hot and cold connected to your machine you can use just cold, but you DO need a supply of some kind to both valves, or your machine will stop when it comes to the rinse cycle and it won't distribute fabric conditioner. Ask for a cold fill adaptor from any plumbers merchants. It looks like a plastic Y the single stem connects onto your cold supply tap and the two hoses from the machine connect onto the top of the Y. The machine will take longer to do a wash but it will work perfectly.
Posted on Jun 21, 2009
SOURCE: whirlpool washing machine...only uses hot water
Make sure the hoses are connected correctly to the water valve on the machine. The connections will be marked with an "H" and a "C".
Given they are correct, most current washing machines have and auto temp feature on the water fill. It allows even cold water settings to bring in some hot water to make sure the water temp is hot enough to efficiently disolve your laundry detergant. The preset temps are usually around 75* for cold, and 105* for warm. Hot water comes in at whatever temp your household water temp is.
Posted on Sep 12, 2009
jmeredith
  • 417 Answers
SOURCE: My washing machine (dwd-wd32ws) only uses hot water to wash!
hi,
try and switch your hot and cold water hoses around the other way. it should start the cycle with hot and rinse cold.. If it still does it you may have to have it serviced..
jm
Posted on Nov 27, 2009
We changed boilers to a combi boiler but kept the cylinder which is heated electrically for the shower. Can we heat the water in it from the combi boiler
You would have to have a indirect cylinder and motorized valves ,clyinder stat . It could be done you would need a heating company to check it all out .
Mar 22, 2018 | Water Water Heaters
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
I have an Alpha 240E combi boiler; if two taps are turned on at the same time or say the washing machine is running and someone fills the kettle it trips. Why please? The water pressure is slightly above...
Water flow combi will only pass so much , unless there is a blockage in the water section on your boiler, or water inlet tap is not fully open .
But some combis do have poor flow through the heat exchanger .
Jan 28, 2013 | Desa International GWP20T GLOWARM Wall...
We have no hot water boiler kaput - will washing machine heat water (hot wash) if only cold water is going into inlets.
Yes. The washing machine contains heating element and a thermostat. It will try to get water from both hot and cold sources and will heat the water to the required temp.
Mar 07, 2011 | Hotpoint Washing Machines
Hi! My hot water taps from the wash hand basin and mixer bath has low pressure. I`ve got a combi boiler in the first floor. Can I install a single impeller pump connected from the hot water outlet from the...
In a word no. Combi boilers work on balanced pressure.ie the mains cold supply to the boiler should be around 1 bar minimum which would give a hot water pressure of the same 1 bar. Assuming the cold water pressure is fine, it sounds like you have a restricted flow on the hot side. If you live in an area with water problems the hot water systems pipework calcify over time effectively reducing water flow. Unless any flexi hoses are kinked, check if there are any filters in the appliances that may be blocked.Also check all valves are fully open and if possible check if there are any restrictions at the valves. Failing all that and the taps are in good order it is possible to fit a pump before the boiler but this may only be a temporary fix overall.
Apr 04, 2010 | Plumbing
Combi boiler hot water far to hot.
Yes the temp can be adjusted, the dial is behind the cover. Turn off power before removing cover.
Sep 11, 2009 | Water Heaters
Hot water
there are two main faults with combi boilers not giving hot water. one is a faulty flow sensor, the other is the most common which is a blocked heat exchanger caused by debris and scale in the system. this needs to be flushed out or may require a new heat exchanger depending on the age and condition of the boiler some plumbers may suggest a new boiler.
Mar 02, 2009 | Water Heaters
No hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Jan 03, 2009 | Combi Centre DX - Mango
Baxi/Potterton wall hung fan assisted combi boiler
does the boiler come on when the hot water tap is run if not change the hot water flow switch or the diaphram in the hot water flow valve it may be split
Nov 02, 2008 | Combi Centre DX - Mango
No hot water help
Feb 18, 2008 | Washing Machines
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
