Question about Lands Phones
My BT Quartet 1500 (silver handset) beeps twice when I press the talk button, I de-registered it from the answer machine base unit ok. It is only when you come re-register it - after holding down the intercom button on the base unit, you hear the tone - indicator say -In use, you press the talk on the handset, but because it beeps twice and doesn't switch on phone (instead of beeping once and activating phone)the registration is incomplete. Any guidance will much appreciated. SH
5 Suggested Answers
  • 146 Answers
SOURCE: no intercom connection between handsets
Here is a link to the uniden manual link and an excerpt from the manual section which deals with your problem :
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
The handset doesn't
communicate with other
handsets.
• De-register the handset (see "De-register the Handset" on page 32) and register the handset
(see "Register the Handset" on page 68).
• Make sure that you have registered all handsets.
An extra handset can't join
the conversation.
• Make sure there are not 2 handsets already using the 3-way conference feature.
The handset or the base can't
join the conversation
• Make sure that another handset or base is in privacy mode.
To register a TCX805 handset, simply place it in the main base.
While the handset is registering, H a n d s e t R e g i s t e r i n g will appear in the LCD.
When R e g i s t r a t i o n c o m p l e t e . is displayed, the handset has been registered to
the base. If R e g i s t r a t i o n f a i l e d . appears, please try these steps again.
To register a ELX500, TCX440, or TCX400 handset, follow the steps below:
1) Disconnect the AC adapter from the main base.
2) While pressing down flash/find hs, reconnect the AC adapter.
3) On the handset, press and hold # until you hear a beep.
While the handset is registering, H a n d s e t R e g i s t e r i n g will appear in the LCD. When
R e g i s t r a t i o n c o m p l e t e . is displayed, the handset has been registered to the base. If
Posted on Jan 16, 2008
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
Posted on Apr 13, 2008
SOURCE: Re-registering the Handset is not working
The solution is this - unplug the base unit then plug it back in. After that it worked fine.
Posted on Jun 23, 2008
  • 79 Answers
SOURCE: how to use intercom between two handsets
For models with 2 or more
handsets included
Making an intercom call
1 Press {INTERCOM}
2 To page the base unit, press {0}.
To page another handset, enter its
extension number ({1} – {4}).
The destination unit beeps for up to 1
minute. Someone else can answer the other unit and talk to you.
3 To end the intercom call, press {OFF}.
Posted on Aug 24, 2008
  • 3 Answers
SOURCE: cdp24201 base handset wont work
If your interested folks I sell these phones and have small inventory left as well as the impossible to find blue tooth installation CD.
jeremyslilver@shaw.ca
Posted on Sep 25, 2008
Can not register handset
The handset must be de-registered before it can be registered.
Try this:
1. To de-register the handset from another base:
When the orphaned handset says "Connecting..." or
"Out of Range..."
enter *331734 [menu]
and it will soon beep and display "Not registered"
2. To register the new handset to your base:
press the "Handset Locator" button on the base and hold
it until the "in use" light comes on ( ~ 4 seconds ),
then release the button and set the new handset into
the base phone cradle. After ~ 30 seconds it will beep
and display "Handset #" (next in sequence).
3: Note: the base handles a maximum of 12 handsets.
If your system was fully populated ( ie, a handset is
already # 12 ) you will have to clear all the handsets
from the base and re-register them all in sequence.
( it is the only way to 'rescue' the places occupied
by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button
until the "in use" light lights and then starts to blink
( ~ 10 seconds ), release the button --
then press it again briefly while the "in use" light
is still blinking.
2. The base will beep and all handsets that were registered
will display "Not Registered"
3. Follow the instructions above for each handset
in turn to re-register them:
press "Handset Locator" ~ 4sec ( in-use light on ),
set handset into the base cradle, etc.
The manual is available from: www.manualslib.com
but does not fully describe these procedures.
Good luck !
Nov 22, 2015 | Vtech AT&T CL83213 2 handset cordless...
At&T EL52300--one phone reads 'out of range-move closer to base.' I did--it doesn't help. Battery OK---What do I do?
It appears that the one handset has become orphaned and
must be de-registered and then re-registered.
1. To de-register the orphaned handset from the old base:
When the orphaned handset says "Connecting..." or "Out of..."
is still blinking.
Good luck !
Oct 17, 2014 | AT&T El52300 Cordless Phone
My uniden DSS7855 with 1 base station and 3 handsets wont connect when i dial a number and hit the talk button it tries to connect and then comes up "'out of range" much appreciated for any help...
Clear the Handset's Base Data
  1. To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.
  2. It will now be de-registered from the base.
Note: This requires that the base and handset can communicate with each other.
Clear the Base Handset Data
  1. To de-register all handsets from the base, remove power to the base, and remove the handset from the base.
  2. Press and hold the 'flash/find hs' button while applying power.
  3. Wait for the beep and release the button.
  4. The charge light will now flash.
  5. Sit any handset in the cradle.
  6. When the flashing stops, re-register the handsets to the base.
Re-Register a Handset to the Base
1. Remove Handset Battery.
2. Reconnect battery while holding down "*" and "#" key.
3. Then press the right upper key under the LCD.
4. Press the "End" key.
5. Wait a few seconds and then the phone will be ready to register to the base.
Nov 12, 2010 | Uniden Lands Phones
My vtech cordless reads out of range or no power at base, what is wrong?
Official solution to this issue:
Make sure base station serial number matches all handsets serial numbers.
If they don't match you will have to de-register the units.
De-register the base station by holding the find handset button for 10 secs or until the In Use light illuminates, release the button and then tap it once more. You should hear a short beep followed by a longer beep.
Press Menu Select and the press the following without pause - *7890#
You should now see Test Base at the top of the screen press the Vol up button until Test Handset is present.
Press Menu/Select and you should see SW Version displayed. Press Vol up button until you see regstr clear, then press Menu Select and then Menu Select again.
At the handset remove the battery for 15 secs and then place the battery back into the handset. You should see 1. Place handset ... 2. press # on the handset screen. DO NOT FOLLOW THE ON SCREEN DIRECTIONS.
Next place the Handset on the base station and press the find handset button for 4 secs until the In Use light shows up. Remove the handset and press the # button.
Your handset should now display Handset 1. You can do all the other handsets the same way.
Hope this helps!
Jul 25, 2010 | Vtech 9009111 Cordless Phone
Wharfedale DECT TAM telephone/answer machine is flashing CL on the main answer machine base unit. This message is not indicated in the user manual can you please advise? Many Thanks Steven Clifford
This is due to the base unit losing power and needs the clock resetting.
The handsets retain their clocks under battery power so this is a little misleading.
To reset the base unit clock:
- press the OK key
- press the 'down' arrow twice until "DATE/TIME" is displayed.
- press the OK key again, this will display the year. Enter the correct year on the handset numeric keypad and then press OK. (Only the last two digits of the year need to be entered).
- The date is then displayed in MM/YY format, enter the correct date on the handset numeric keypad and then press OK.
- The time is then displayed, enter rhe correct time on the handset numeric keypad and press OK.
- The handset then beeps and displays "SAVED".
- Press the "C" button and replace the handset on the base unit.
The base unit should now stop flashing "CL".
Aug 28, 2008 | Emerson EM-CKT9087 Corded Phone
Uniden Cordless Phone Model DSS7855. frequently fails to connect to an incoming call, with 'out of range' indication. The phone is less than 1 meter from the base station.
The handset/base keeps a record of who it’s registered to. The base also keeps a record of how many handsets are registered to it.
Using the de-register function on the handset deletes the handset from the base (decrements the count) and deletes the base info from the handset. All this requires that the base and handset can communicate with each other.
To remove the base data from a handset when out of range of the base, press and hold the ‘end’ button and the ‘#’ button simultaneously until the phone beeps. It will now be de-registered from the base.
However, the base will still have this handset in it’s record.
To de-register all handsets from the base, remove power and the base handset. Press and hold the ‘flash/find hs’ button while applying power. Wait for the beep and release the button. The charge light will now flash. Sit any handset in the cradle. When the flashing stops, all handsets are inhibited from connecting.
However, the handset still appears to be connected to the base unit. Pressing talk will give an ‘Unable to connect’ message. To re-register the handsets to the base, you have to de-register the handset first with the two button method.
Of interest, pressing ‘*’ and ‘#’ on the handset while reconnecting the battery is suppose to reset the handset. Doing the same on the base unit puts you in some sort of diagnostic mode. Press speaker to exit.
Aug 21, 2008 | Lands Phones
BT XD5500 manual
BT Freelance XD 5500
Resetting the base & handset/s on a BT Freelance XD5500:
Hold the Find button on the base unit until you get a double beep then
tap the Find button 7 times.
On the handset:
remove a battery
hold the menu key and refit the battery
screen says SW VERSION
press up arrow key until screen shows REGISTER CLEAR
press menu
press menu again and wait for OK to appear
remove a battery and refit
Registering the XD5500 handset.
Then register the handset to the base as follows:
Hold Find button on base unit until you get two beeps
On handset:
Press menu
Scroll to register
Press menu
Scroll to Register Base
Press menu
Press 1
Wait
When it says PIN ? Enter 0 0 0 0 (four zeros) and press menu.
Note:
If you have more than one handset then repeat registering the handset to the base for each subsequent handset/phone.
If this procedure fails to solve the issue, then you have a unit with a
fault and if it is less than a year since purchase the retailer should
change it for you.
Aug 03, 2008 | Lands Phones
ATT 5840 Base reset code/procedure
document.write(parent.prscreen) Try this to get it working. Relocate the handset(s) closer to the main base.
Check for any lights on the base including charge, intercom, and channel lights (if applicable to the model).
Re-cradle the handset on the base for 15 seconds. Lift the handset and press PHONE.
Unplug the AC adapter from the main base unit and take out the battery from the handset. Leave it unplugged for 15 seconds. Plug the handset battery in and re-cradle the handset. Plug back the AC adapter in and wait for 15 seconds.
Try to de-register the handsets by following the steps below:
1. Using the soft keys on the base located below the base screen, press MENU
2. Press the down arrow once until BASE SETTINGS is highlighted.
3. Press the OK soft key.
4. On the base, press MUTE 3 times and FLASH twice. This will
deregister the unit.
Below are steps on how to re-register the handsets:
1. Make sure to charge the handset battery pack at least 12 hours.
2. Using the soft keys on the base located below the base screen, press MENU.
3. Use the up or down arrow keys to select DISPLAY BASE ID.
4. Press OK. The base screen will display the 15-digit Base ID
code for about 30 seconds, then the unit returns to the idle
screen. Write down the Base ID code on a piece of paper.
5. At the cordless handset, use the soft key to select NEW.
6. Enter the 15-digit Base ID code using the number keypad.
7. Use the soft key to select OK. The screen displays PLEASE
WAIT!.
8. After about 45 seconds, the screen displays FOUND BASE. If the handset displays BASE BUSY TRY LATER, the base is in
use.
Other products that use the 5.8GHz band can interfere with the use of this phone. These products or equipments include: radio towers, page towers, cellular Phones, other 5.8GHz cordless phones, intercoms, or monitors. If any of these are in the area, they may interfere with the performance of the phone. Try relocating the phone.
Video displays, Televisions or Personal Computers can cause
interference on the phone if it is plugged in electrically with one of this equipment (typically on a power strip or extension cord). Please relocate the phone to an AC outlet without any other major appliance plugged in.
You can also relocate the base to another room.
Relocate the phone out of the kitchen area. Appliances may cause interference.
If the charge light does not remain on, clean the handset and base charging contacts using a pencil eraser. If it comes on after cleaning the contacts, you may need to charge the unit for 10 hours.
Make sure that the AC power cord is securely plugged into the base. If unsuccessful, plug the unit into a different known working outlet or turn on the switch on the power strip.
Dec 19, 2007 | AT&T 5840 5.8GHz...
DeRegistering a Damaged Cordless Phone???!!!!
I have a Panasonic KX-TG6700 base unit and KX-TGA670B handsets. We had a similar problem where we were no longer able to deregister the handset using the handset itself. We wanted to be able to use that slot that the broken phone was still occupyng. The solution that we found in the manual online was to hold down the intercom button for 3 seconds until the "in use" light turned on. Then press and hold the number of the extension you want to deregister until it beeps. At this point the base unit has freed that extension.
Nov 05, 2007 | Panasonic KX-TGA600B Cordless Expansion...
BT Freestyle 2200 I am having problems obtaining a dialing tone on both of my handsets. When I press the green button for a line out it just beeps 3 times and cuts off. There is charge in both the...
hi just want to help others as desciption aint complete above
Registering a BT Freestyle 2200 handset
1. If there is a handset in the base remove it whilst you are registering the new handset.
2. Press and hold the PAGE button on the base for about 10 seconds until you hear a beep and the In Use light starts flashing.
3. On the handset to be registered, press and hold redial & CALLSd buttons together until display shows 65-.
4. Enter the base number. If this is a new handset then the base number is 1, the display shows 65-1 then PIN. which is normally 0000
5. Enter and registration starts. When the handset beeps and returns to standby registration is complete.
Nov 08, 2006 | British Telecom Freestyle 2200 Trio...
Lands Phones Logo
56 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
