Hdd password can i get some help on finding out master password for a 80GB ST980811AS hard drive
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 52 Answers
Give this a try....
-> Is there power to the hard drive? -> Is there a pop up stating that new hardware is found, but cannot open the hard drive?
Lets try something: Ok, there are a few steps that I need you to do...
with your Hard drive plugged into the computer, goto:
-> DESKTOP (front page of the computer)
-> right click on MY COMPUTER
-> left click on MAP NETWORK DRIVE
-> left click on the DRIVE Z:
-> now that this is open, look for an open drive (ex:O,P,Q - do not pick A,C or Z drive), so we won't wreck another drive when creating a spot for your Hard drive and remember the open drive letter, and close off this page.
Now that you have the drive letter:
-> Right click on MY COMPUTER
-> left click on MANAGE
-> look for DISK MANAGEMENT and left click on it
-> you should see Volume for SYSTEM and UNKNOWN or REMOVABLE
-> right click on unknown/removable and assign/change to the drive letter from the previous task
-> press ok to save
Posted on Feb 14, 2012
msuhelk
  • 106 Answers
SOURCE: usb 3.5" 80Gb portable HDD problem
FIRST SCAN IT WITH ANTIVIRUS AND LATER CHECK IT AGAIN . MOST LIKELY THIS IS A VIRUS ACTIVITY
Posted on Apr 03, 2008
SOURCE: Hitachi HDD unlock
use hddunlock.com
Posted on Apr 20, 2008
preachw996
  • 1179 Answers
SOURCE: HDD is cactus, what are replacement alternatives for the OEM?
You can use any 2.5 inch ATA/IDE drive as a replacement. Notebook hdd's are a smaller size than regular desktop hdd's. You can find a good idea online at stores like tigerdirect.com or newegg.com. Hope this helps & please rate this answer fixya. Thanks.
Posted on Feb 04, 2009
DJGray
  • 56 Answers
SOURCE: Computer won't detect new HDD as master when booting
You can do this!
1. Connect your 500gig drive as the slave of your smaller boot drive.
2. Go to http://freewareapp.com/western-digital-data-lifeguard-tools_download/ and get the Western Digital Lifeguard tools.
3. Run the executable to install WD tools.
4. Run that application.
You'll notice there is a Drive to Drive Copy utility. This will clone your new 500gig drive from the smaller drive. When the utility finishes copying the drive, shut down. Remove the smaller drive, and set your 500 gig drive as master/single. Reboot, and you should be running off the new drive.
It is possible that your old drive was an IDE drive and your new one is SATA. If so, you may need to enter Setup on the reboot, go to the Boot menu, and set the boot device to the new drive type.
Posted on Mar 02, 2009
SOURCE: where do I set the jumper hard drive on a maxtor
http://www.tacktech.com/display.cfm?ttid=379
Posted on Aug 12, 2010
My ST980811AS SEAGATE DRIVE IS PASSWORD PROTECTED, I CAN'T ACCESS DRIVE. HOW DO I UNLOCK THIS?
If its password protected then it was probably encrypted. If its encrypted then youll need the recovery key to get to the information. If you do not have this you will need to reformat the disk and reinstall OS.
Sep 21, 2012 | Seagate 80gb 2.5 sata hd brand new factory...
Can not detech
Good day!!!
please check the HDD itself if it is set on master?slave?
please change it to master..
if the problem persist just add a comment.
Jul 11, 2011 | Seagate Barracuda 80GB SATA 2MB HDD 80 GB...
I have a 250gb seagate sata but when i put my 80gb IDE hdd it only detects in booting and in bios but after that if i open my computer i cant see my 80gb IDE Hdd and even in device manager my hard disk was...
there was wrong in the set up of jumper in your 80gb hdd. Look closely to the 80gb harddrive, in between the ide cable terminal and the power supply connector you will see 8pin terminals paired together and a jumper use to short the paired terminals. It is most likely that the jumper was configure to detect your hdd as master. If the ide cable you use for the 80gb hdd was also use for the dvd/cdrom drive then it will conflict with it if both jumper setting was set to master. See the description of jumper settings in the sticker of the hdd. Position the jumper to slave.
Reboot your system again and see if the 80gb finally appear in your system. When system boot upon detection of hdd, the primary master should be 250gb while your primary/secondary slave will be read your 80gb hard disk.
Jan 24, 2011 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
My segate 80gb IDE harddisk Board power and header Problem. Please Help me How to recover my data in that hard disk.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Nov 18, 2010 | Seagate (ST980811AS) 80 GB IDE Hard Drive
I am connecting my 40gb PATA HDD, but my PC doesn't start. There is no problem when i connect my 80gb PATA HDD in same PC. My 40gb HDD had detected once but it gave symbol S@ in the BIOS setup. Can U...
You did not indicate that the 40 Gb hard drive had Windows installed on it and whether it was the original hard disk for this computer.
There is a possibility the 40Gb hard drive is faulty.
Try installing the 40Gb hard drive as a slave drive with the 80Gb drive as the master drive (don't forget to set the jumper on the 40Gb hard drive as Slave. Check the BIOS to see if it detects the 40Gb hard drive, and when the computer boots up, if it can see the 40Gb hard drive and opens the various folders and files, then the hard drive is OK.
Sep 19, 2010 | Computers & Internet
How to unlock the master password
This must be a drive from a laptop, and the Anti-theft feature is active, It must be returned to the laptop it came from, and then a Key must be obtained, from the manufacturer, contact, them, and for a fee, and with "Proof of ownership" they will sell you an unlock, code. Or there are places no questions asked, will also sell them.
Apr 08, 2010 | Hitachi 80GB IDE Hitechi DeskStar 7K160...
Compaq Presario will not format Samsung 80GB hard drive.
Sir,
you are required to follow these steps below.
1 turn on your computer with HDD in it
2 Enter in to the BIOS by pressing F2 button
3 there entering in BIOS look for "Drive Configuration" it might be writen in some other words
4 there you will find ..."Hard drive SMART capacity" as enabled in box above.
5 Enter that box and Disable it.
6 Push F10 and reboot the machien.
Now you will be able to format , install etc on your hard drive hopefully
Oct 21, 2009 | Samsung (MP0804H) 80 GB Hard Drive
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
Hard drive
hi dear
use a cd booting
in command prompt c:\
type c:\fdisk /mbr
to fix your master boot record\
fdisk
and make your partiiton active.
after that installing your windows XP
oke
cropp
Mar 15, 2008 | Maxtor Hard Drive
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
