Question about Dishwashers
Hi i have a baumatic bdw45.1 dish washer that has come ipod with code e6. I have Googled this and told its a thermistor problem. anyone got any idea where this is located and if it is likely to be this as i know these codes arena 100% accurate
  • 126 Answers
SOURCE: my dish washer has a f1 code i put to much
f1 code indicates a leak.open bottom drawer,find the spring clips on side of tub where tub meets the front panel.push the clip and you will be able to slide the track back and remove tub. put tub on floor to left you should see a puddle,dry it up should be ok. Sensor is sensitive to moisture allow 24 hrs to reset if all visible water has been dried up. hope this helps ,please rate my solution :)
Posted on Jun 25, 2009
  • 7 Answers
SOURCE: Need code for RCA L32HD41 HDTV
I have the same TV. I called RCA and they said the remote is not 'code compatible' and that I should check back with the website in the future. I think a learning remote is the only option at this point. Maybe a Logitech Harmony?
Posted on Jul 22, 2009
  • 1416 Answers
SOURCE: Baumatic WQP12-9213 - Error Code 004?
hello
The "004" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
mean while 004 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
however,what you need to do tp fix up the problem is to unscrew the washer then clean up all forms of dry and water you can seen in it with this the problem of the 004 error code is solve .
please make sure that all form of power supply is put OFF before you can do this
thank you and thanks for using fixya.
Posted on Jun 03, 2010
Testimonial: "Thank you for your help."
  • 3 Answers
SOURCE: Samsung P801DWNXRC Frontload washer displays E6 error code
I had the same problem. I ended up paying $300 ($100 part $200 labour) for an authorized technician to replace the control board and that fixed the problem.
Posted on Sep 22, 2010
SOURCE: lg arena km900 security code.
lg km900 ect ........ press emeg call ... press 1809#x900# ... select factory reset in menue and wait ...... ALL DONE .. UNLOCKED SEC .... that x is the star by the way .. derrrrrr ....
Posted on Apr 17, 2011
Hi. We have a baumatic bdw13 built in dishwasher, which is showing error code E6 (thermistor fault). Please could you tell me where the thermistor is located a whether it is easy to replace? Thanks
Hello Kristy!
A thermistor is a temperature sensitive resistor that "opens" (opposite of short) when it reaches a certain temperature and is installed to protect electrical equipment down stream. Why not just a fuse?, you may ask. Good question. A thermistor can tolerate a brief current overload that would blow a fuse, allowing continued operation following transient high-current events like motor start up.
While thermistors sometimes simply decide it's time to join their relatives in thermistor heaven, or wherever dead thermistors go, it usually means there is a steady, excessive load (failing motor?) in the circuit requiring attention.
Where yours is located is a mystery but I would guess it's under the machine near the motor. While I have attacked these issues myself, this sounds like a job for the big kids, especially since thermistors seldom just die.
All the best.
Nov 23, 2014 | Dishwashers
What does E6 mean on a baumatic bwm70
E6 on the bwm70 means that there is a water sensor level error. You can try resetting the error code to see if it comes back on by pressing and holding the the power on, start/stop button, or unplug the washer, wait 30 seconds and try again. If you still get the E6 code, your washer will need to be serviced
Jun 18, 2014 | Washing Machines
Code e6 samsung B1215J
Hiya,
E6 is listed by Samsung as :- Water temperature rising/falling too quickly. Check thermistor.
The thermistor is the temperature sensor, normally a probe located in the heater.
Unplug the appliance, take the rear panel off and the heater is at the bottom rear of the tub. Check the wiring to it and check the heater for continuity.
Apart from these checks you're left with replacing parts on a "fit and see what happens" basis. I'd try the heater and thermistor first.
Hope this helps.
Thanks
Mar 30, 2014 | Kenmore Elite 45986 Front Load Washer
Lg top load washer e6
Oct 21, 2012 | LG WFT1071TP Top Load Washer
Error code E6
Machine displays E6. Contact your local Hobart Service Office.
Jan 11, 2012 | Baumatic Dishwashers
I've got a Baumatic Mini4 table top dishwasher: what is err6 and what do I do?
Hi and wlecome to FixYa, I am Kelly.
Your table top dishwasher has an open circuit in the thermostat.
'E6' OPEN CIRCUIT THERMOSTAT.
Technical / Advice Telephone. +44 118 933 6933
SPARES
TEL: 0118 933 6922
FAX: 0118 933 6942
UNITED KINGDOM
T: +44 (0) 118 9336 900
F: +44 (0) 118 9310 035
info@baumatic.co.uk
I do not have the parts list for this unit. You wil have to contact Baumatic to order parts.
To correct the E6 code you will have to have the thermostat replaced or wiring to the thermostat repaired that is causing the open circuit.
Thanks for choosing FixYa,
Kelly
Jan 25, 2011 | Dishwashers
F02 Baumatic error not cleared Even when filter cleaned...?
Perhaps you need to check the outlet hose from the pump for a blockage, and of course, make sure the pump itself is working.
Jan 17, 2010 | Baumatic BTWM4 Front Load Washer
No manual
The light bulb is the oven light.
The snowflake with 3 raindrops is Defrost Mode (fan runs with no heat to reduce defrost time)
The 2 lines up top & down bottom is Traditional Cooking (heat from top & bottom elements)
The big circle with a fan is the Fan forced Oven
The small line at top only is the Grill Mode
The larger line at top only is the Double Grill Mode
The line up top with the fan underneath is Double Grill with Fan mode
The line on the bottom with fan on top uses the lower element with the fan for delicate dishes
The manual can be found on the Baumatic website - www.baumatic.com.au - select your product which takes you into another page & you will see on the left hand side a link to "View User Manual"
Nov 11, 2008 | Baumatic B187 Stainless Steel Electric...
Dishwashers Logo
24 people viewed this question
Top Dishwashers Experts
Owen Barnes
