Question about Samson Technology Zoom R24 24Track Recorder Interface Controller Sampler
Invalid 'NO CARD' status. SD card in unit, was working fine. Have tried various cards.
SD Card reader not working?
Make sure that the SD slot is not dirty, check inside with a light and you may want to blow it out.
Apr 08, 2014 | Boss Micro BR Digital Recorder
Hi, I have a boss BR 600 and when i insert any card it checks the card and then says ' card not supported'. I t used o work fine. However i have noticed that 2 pins seem to be missing inside t
I have the exact same problem. All my flash cards worked fine, and all of the sudden, none work. Not even the one that came with it. I am still trying to fine the reason. I bought it eight years ago, that might be it.
Jan 30, 2013 | Roland BOSS BR 600 8 track portable...
Cannot format or reload factory presets after it stopped working
The card that you used to transfer the files HAS to be (1) FORMATTED by the ESX-1 unit FIRST, (2) then put the card into your computer's card reader and download the files. (3) Put the card BACK into the ESX-1 and try reloading the factory presets. Good luck!
Jan 11, 2013 | Korg ESX1 Electribe SX production station...
Unable to format sd card. Keeps saying protected when it's not.
1) Check to make sure the SD card itself does not have the protect switch in Locked position. There is a physical locator as you had with floppy disks to prevent erasure.
If they are not locked, the tab switch that contacts the tab when it is not locked may be dirty, bent or broken. A visual check in the slot can tell you if there is damage.
Mar 29, 2012 | Korg Kaossilator Pro Tabletop Synthesizer
The booting up screen says card protect. I don't know where the sd card lock switch is to release this.
The small SD cards have a tiny slide switch on the side of the card... it is TINY !!!
Jul 14, 2011 | Zoom H4 Handy Recorder
I am not able to use 4GB Sony SD card in my CTK 5000 Keyboard. It is sensing but I am not able to format the SD Card and flashing 'Card R/W Error'.
It appears that a LOT of devices cannot use cards greater than 2Gb. You will find on page E72 of your user manual that the SD card must be 2Gb or less for this unit.
Mar 29, 2011 | Casio CTK5000 (61Key Portable Keyboard)
I have the a Casio Keyboard that has an SD slot, but whenever i put songs on my SD card & then plug it into the keyboard, it says that there is an ERROR . What am i supposed to do . Step by Step . to...
Does it say ERR NO FILE? If so, then read on. The reason you have this error is because you don't have a folder on your sd card named MUSICDAT. Solution:
  1. Insert your sd card into computer
  2. Make folder called MUSICDAT.
  3. Then, transfer all files inside the folder (make sure your songs are in MIDI format).
  4. Safely remove your sd card.
  5. You're ready to put it in you Casio Keyboard!
If you still get the error, take time to read you manual. Read the "using the sd card" part. The folder name might be different for your Casio Keyboard (because mine's a CTK-5000).
...and IF you still get the error, perhaps the songs you meant in your question are MP3 songs (like the ones you play on the iPod)? Then, that's a different topic... :)
Well then, good luck!
Feb 28, 2011 | Casio Lighted Keyboard LK90STADMC
I think my Micro BR is broken
It is either that you put an incompatible SD card in it. (Believe it or not, many devices will not work with certain SD cards), or the card reader has failed. Try a Scandisk SD card or other popular brand and see if there is any difference in the messages. Otherwise I would say the card reader is faulty.
Aug 06, 2008 | Boss Micro BR Digital Recorder
Samson Technology Zoom R24 24Track Recorder Interface Controller Sampler Logo
37 people viewed this question
Top Samson Technology Music Experts
Michial Gueffroy
Chris Larocque
Are you a Samson Technology Music Expert? Answer questions, earn points and help others
