Question about Badger Basket Starter Spray Gun Hobby Set
How to put airbrush together
The small bit next to the trigger dont know wich way it goes
Starter relay wiring for a 1999 chev cav
Skychief2001 is correct.
There should be one wire with a small connector on it that goes to the "s" terminal on the starter (this is the trigger wire that activates the starter solenoid). All the other wires hook up with the large one. The large wire goes directly to the battery, the smaller wires are used to power various other circuits of the car and have nothing to do with the starter itself. It is just an access point for battery power.
Feb 07, 2013 | 1999 Chevrolet Cavalier
Does anybody know how the spring catch in nds lite goes back together?
sry didnt quite understand your question but what i can get... its the trigger?? if it is the little spring with a loop of wire goes into the hole with 1 end of the wire going into the trigger then you drop the pin through and then put in the trigger slot then take a small flat screwdriver is what i use and push the wire into the slot that holds it...hope this helps
Mar 18, 2012 | Nintendo DS Lite Console
Erorr E000019-0000
the waist toner bottle is full or the waist toner bottle sensor has become blocked. if you know where the bottle is remove it, empty it and then clean off the outside bottle with a paper towel. becareful as the toner has a tendency to make a big mess.
Jun 18, 2010 | Canon IMAGERUNNER 2230 Copier
Part fell out of gun dont know where it goes
is it the carrier support spring or the trigger spring?
go to www.winchester.com look for owners manual for model 94 come times the site dont work well.you may have to call them and ask for a schematic parts break down they will send it to you or e-mail it.
Oct 28, 2009 | Sport & Outdoor - Others
How far do you put a bit in to know it's placed correctly. I'm trying to surprise my husband by removing some kitchen cabinets, but I'm not sure I put the bit in right and I don't know how to make the...
Find the reverse switch near the trigger. Press one direction for forward, in the middle is a trigger lock and the other direction is reverse. Dont surprize yourself and have the cabinet fall on you.
If you have short bits, put about 1/2 of it into the chuck. If you have long bits (about 2 inches long), put about 1/2 inch of it into the chuck.
Be aware that when the drill runs in reverse, the chuck tends to loosen and when that happens, your bit will fall out.
If Hubby has a bit holder, I'd suggest you use that and place the bit into the bit holder. Makes for a better reach.
Good luck on your project.
Oct 18, 2009 | kawasaki 19.2v 20 Pc Cordless Drill Set
Can't pull the trigger
Probably the paint and texture have clogged the orifice as well as the feed tube up. Hope the paint was water based. If so, set the gun down in a bucket of very hot water with the trigger tied open.
It may take several soaks. Each time you check it put the air on and pull the trigger a few times. Eventually it will unclog. By the way, you should take the orifice completely off so there is no restriction.
If it was solvent based you are pretty much out of luck.
May 25, 2009 | Wagner Power Tex Texture Sprayer #0520000
Ds lite left trigger broken..
yes your ds lite is repair able if you can,,,,,open up your ds lite and get a soldering iron and touch the 4 points with it, then put it back together.
I can give you step by step information if you email me at ndsrepairservice@gmail.com
Jan 26, 2009 | Nintendo DS Lite Console
Never have used a keyless chuck b4- need to change bit, how do I do this? thanks
hi this should be reletively easy hold the end black bit with the sivler bit holde coming out not the black bit next to the yellow case on drill you hold the black part thats at end of drill by where the bit goes into not the black bit near the trigger hope i explain this ok.
Hold this bit tight then put drill in reverse then press trigger a couple of times it might be tight but shouldnt be that tight it wont undo.
1 put in reverse
2 hold black plastic piece near where drill bit goes into
3 press trigger few times
4 this should undo it allowing you to put a bit in
make sure its in reverse else you will just tighten it up more let me know if you need further assistance ok
Mar 05, 2008 | Dewalt 18 Volt Compact Drill Kit
Badger Basket Starter Spray Gun Hobby Set Logo
Top Badger Basket Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Badger Basket Air Tool and Compressor Expert? Answer questions, earn points and help others
