Question about Gb Electrical 100 Amp GE Load Center
My Baldor motor is not working, its CAT#10142 and SPEC# 33-1197-1190. The three windings impedance results are 71ohm, 70ohm and 1ohm. Please help
HP: 0.17 Volts: 208-230/460 Amps: 0.66-0.60/0.30 R.P.M.: 3450//2850
3 Suggested Answers
  • 20 Answers
SOURCE: I need a wire diagram for a high voltage Baldor
Normal wiring for this type of 9 lead motor to 440VAC is
Connect #4 to #7 Connect #5 to #8 Connect #6 to #9
Connect supply phase A to #1 Connect supply phase B to #2 Connect supply phase C to #3
Can you confirm the CAT and SPEC numbers? They do not show up on the Baldor site. If they are correct as listed, you need to call the Baldor help line and find out if this is a special motor.
Posted on Aug 05, 2010
  • 3287 Answers
SOURCE: I need to wire up a baldor 3 phase motor 208-230/480 15hp and dont have the wiring diagram to know what wire is what or where to hook it to?
Hi Casey, I'm an electrician and can help you with this problem.
First, a disclaimer. Without the catalog number of the motor you have, or a wiring diagram for it, no one can tell you how to wire this motor with any certainty. With that said...
Nearly all single speed 3 phase motors have 9 leads (numbered 1 thru 9) and can be wired for either "high" or "low" voltage. Most of the time, high is 480 volts and low is 208/240 volts. Given that you posted the amperage as "41-38 / 19", I am 99% confident that 41 amps is at 208 volts, 38 amps is at 240 volts and 19 amps is 480 volts. Further below is the way to wire unless the motor manufacturer or name plate indicates differently. You will need to determine the voltage of the appliance this is going to be installed into. You should be able to find this on a name plate of the appliance - but it may provide a dual voltage spec here, too. If this is the case, you will need to *carefully* measure the voltage with a meter, or find out the voltage of the electric panel that feeds the appliance.
Once you have learned the incoming voltage, you will connect the motor as such when L1, L2 and L3 are the line voltage supply wires and wires 1 thru 9 match the numbers on the nine wires from the motor.
208/240 or "Low" volts:
Motor leads 4, 5 & 6 connected together and wirenut.
Motor leads 1 & 7 to L1 and wirenut.;
Motor leads 2 & 8 to L2 and and wirenut and lastly,
Motor leads 3 & 9 to L3 and wirenut.
480 or "High" volts:
Motor lead 1 to L1 and wirenut,
Motor lead 2 to L2 and wirenut,
Motor lead 3 to L3 and wirenut,
Motor leads 4 to 7 and wirenut,
Motor leads 5 to 8 and wirenut and lastly,
Motor leads 6 to 9 and wirenut.
The motor should be operated briefly or "jogged" to determine the direction the motor turns. If the motor rotation needs to be changed, simply swap any two "L" wires (swap L1 and L2, or L1 and L3, or L2 and L3). Test once more to verify rotation and when correct close the wiring compartment and complete the installation. Swapping the L wires will likely be much quicker and easier to do at the magnetic contactor instead of the the motor's wiring compartment. Either location is acceptable.
You should try to obtain the name plate data for this motor - if at all possible to to make sure of the voltage and wiring method. I hope this helps & good luck!
Posted on May 14, 2012
Blower motor audi a8 2004 dont work
A three phase motor in an Audi? Really? Try Cars and Trucks.
Aug 09, 2012 | Baldor RM3120 HVAC Fan and Blower Motor,...
Where are the brushes located on a Baldor 7306D grinder
there are no brushes for this type of motor, it has centrifugal switches and starter windings/run windings.
Apr 02, 2011 | Baldor 7306d 7" Deluxe Grinder, 1,800 Rpm
I have a 1022w bench grinder with a missing capacitor. The baldor catalog doesn't list the part number or spec for the cap. Nor is there a wiring diagram that shows the connections to the cap. Anyone...
OC3012F12SPCYL OIL CAP 12MFD/370V
Thats number the neccesary part for your grinder 12 mfd think about a fitting size of the capacitor and model if you will know for sure here is the information to get .
http://www.baldor.com/brands/baldor-dodge/contact-us/contact
https://www.baldorvip.com/servlet/productInfoPacket/1022W.pdf
Jun 15, 2017 | Baldor 1022w 10" Bench Grinder, 1 Hp,...
I need a wire diagram for a high voltage Baldor motor CAT # 054180 79151 connect to 440VAC it's a 40HP, RPM 3525 , 3PH and it's SPEC# 40F97Z22 please help
Aug 05, 2010 | Gb Electrical 100 Amp GE Load Center
How to wire a 3 phace 5 hp baldor motor
the neutral or white is not used. if the fourth wire is a ground then it goes to the motor frame. if it is a dual voltage motor then here is the wiring: for 240 volt 3 phase connect 4-5-6 together and tape, 3-9 goes on L1, 2-8 together goes on L2, 1-7 together goes on L3. To reverse direction swap any two line wires. For 480 volts 3 phase: L1 goes on T1, L2 goes on T2, L3 goes on T3. Connect together T6-T9 and tape, connect T5-T8 and tape, connect T4-T7 and tape. again to reverse direction swap two line wires.
Oct 14, 2009 | Baldor 115v,1ph, 3,600rpm 7" 1/2hpbnch...
Wireing diagrams
Hello stingerman20,
Your Directed D2400 amp is CEA2006 Compliant. It is stable at 1ohm and will produce 1,200 watts into that load. So you want your subs wired as close to 1 ohm as possible.
The only 3500 watt Pioneer Premier series subs I could find were the models number TS-W3002D2 and TS-W3002D4 with dual 2ohm and dual 4ohm voice coils respectively. The wiring options for the D2's result in 0.5ohm (too low), 2 ohms, and 8ohms. Your best option would be the 2ohm configuration which would be voice coils in series and subs in parallel. Options for the D4's result in a 1ohm load and a 4ohm load. Your best option would be the 1ohm configuration which would be voice coils and subs parallel.
To see the wiring options, try Rockford-Fosgate's "wiring wizard".
Select 2 woofers and the appropriate voice coil impedance and quantity and click "search". It'll bring up all of the possible wiring configurations along with the final impedance load.
Hope this helps.
May 11, 2009 | Directed 2400d Car Audio Amplifier
Gb Electrical 100 Amp GE Load Center Logo
102 people viewed this question
Top Gb Electrical Electrical Supplies Experts
ken skalski
Are you a Gb Electrical Electrical Supply Expert? Answer questions, earn points and help others
