Question about Juki Sewing Machines
Juki 1541 Tension Mystery
"I have a JUKI 1541S and I use thread 69, I only get a balance stitch when the top tension is so tight that it eventually breaks. I have exhausted looseing the top and bottom tension and nothing
3 Suggested Answers
SOURCE: question==>JUKI dnu 1541 or ddl 8300n
Might I be so bold as to disagree with Allmakes.
Why would a manufacturer build different models of industrial. They are designed for differnt jobs. The 8300 is a high speed garment machine, the 1541 is a compund feed upholstery machine. The motor is the same HP and does not affect the ability to sew heavy. The garment machine will sew garment weight leather just fine but you will have problems getting the fabric to feed properly particularly over seams. The other issure you may find with a garment machine is it's ability to handle heavier threads. I suggest that the 1541 would be a better choice for making bags and purses.
Posted on Feb 19, 2008
  • 48 Answers
SOURCE: Tension settings juki mo-644d
-If the machine is threaded correctly and the thread is flossed into the tension discs,
-if the thread is high quality and not cheap thred
the top tensions should be at 5-6 and the looper tensions should be at 4-5
Be sure it is threaded correctly (follow the threading map on the inside of the front cover of machine
Also be sure you are using a size 14 or size 90 standard Schmetz needle do not use Klasse needles
as these are to short and affecdt the timing.
drtension
Posted on May 02, 2010
When stitching on my Juki 1541 the top stitching is perfect but the stitching from the bobbin is loose. how to fix, I did try sighing the screw on the bobbing , did not work please help!!!!!!!
When the bobbin stitching is off the problem is usually with the top thread. Unthread and rethread the machine making sure it is threaded correctly and is securely in the tension disk. If you still have trouble try using a new needle.
Jun 01, 2017 | Juki Sewing Machines
I have juki 1541industrial machine . It started sewing upside down . Instead of nice stiching on top show side it on bottom. Any ideas
This is caused by the tension between the bobbin and needle threads being out of balance. If the knots between the stitches are on the bottom side, then you need to tighten your needle thread tension a little at a time until the knot is in middle of fabric. The reverse of this is if the knots are on the top, then either your bobbin tension is too loose or your needle thread tension is too tight. If this occurs, then loosen your needle thread a little at a time to see if knot goes down in middle of fabric. If it does not, then you need to increase the tension on your bobbin thread. This done by taking bobbin case out and tighten the small screw located in the middle of the spring on the side of the case. You only need a slight, steady pull on the bobbin thread - the more you put on the bobbin, the more you are going to have to put on the needle thread.
Feb 13, 2015 | Juki Sewing Machines
Why my juki 1541S is puckering
What kind of material are you using and what kind of thread? I have this machine and it is wonderful. If the needle and the thread are too big for the material being sewn, the material will pucker.
Go to a smaller stitch, thread or needle one at a time and see what works. It's possible that either the top or bottom tension is set too tight but if it wasn't doing it before, I would try these other things before I changed my tensions.
Also sometimes I completely unthread my upper thread and rethread my machine, in case some lint has gotten caught in a tension or a thread has kinked around one of the places I am not looking.
Lastly, take the two screws out of your needle plate and take it off and either blow the lint out of the feed dogs or use your vacuum to vacuum the lint out. While you have your plate off, check the needle hole that is in the plate to make sure it is smooth. If you have broken a needle or something, it can make a groove in the side of the needle hole and it will catch your thread on each stitch and make it gather up. If there is a groove, you will need to buy a piece of emery tape and file it till it is smooth again. Then reassemble your machine and hopefully you won't have the problem anymore!
Jun 25, 2014 | Juki DNU-1541 Mechanical Sewing Machine
Stitching is loose
thread tension too loose or bobbin tension to tight or take up spring too loose. u did not state on which side the stitch is out of balance.
Dec 31, 2013 | Juki Sewing Machines
I would like instructions on how to set different stitch lengths on my Juki 1541-S.
Puckering is typically NOT a tension problem. But rather a bad needle or not the right needle for the project and thread. Sometimes it's uneven feed but since your 1541 is a walking foot you might have to get the feed timed. I know little about that.
I would first look at the recommended needle thread combo for the fabric. Then the presser foot tension.
Good luck.
Sep 21, 2012 | Juki DNU-1541 Mechanical Sewing Machine
How to adjust tension on a Juki 1541s machine
If you have loops on the bottom of the seam it's your top tension giving you problems.
Sep 01, 2012 | Sewing Machines
Sewing 1/4" leather. Bottom thread
You did it backwards!!! Reset the bottom tension to the default position, with heavy threads its touchy to get back to normal. Turn the upper tension about 1 turn clockwise (tighter) and try. No luck, try a turn then test, then a turn, test.....The size of the thread can cause issues as well. We mostly use #69 nylon threads, but the 1541 can use # 69 to 192 without to many problems. look in the book for how to reset the bobbin case tensions. The 1541 is a wonderful machine, much better quality than the chinese junk being sold nowadays.
Derek
Jan 15, 2011 | Juki DNU-1541 Mechanical Sewing Machine
I bought a second hand Juki industrial machine , model DDL 5550-7, but struggle to get the tension of the stitches right. where do you set the lower stitches tension
upper tension sets the lower thread tension (upper thread is what you see on the underside of the fabric). Bobbin tension is for the thread you see on the top of the fabric
Jul 01, 2009 | Juki MO-644D Mechanical Sewing Machine
Sewing Machines Logo
48 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
SewTechWayne
SewTechWayne
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
