Question about Philips Audio Players & Recorders
Philips rth 718-98 blowing fuses
My system keeps blowing t6.3al250v fuses
Philips LX700 fuse blowing on powerup
Philips LX3000D - Fuses blowing on powerup. Help.
Jan 23, 2014 | Philips LX700 System
Magnavox 37MF437B/37 keeps blowing fuses
Either a short somewhere---which fuse? The one at the power cord or what?
Other possible reason is wrong fuse----many of the fuses in these sets are special-----if you go and buy some Generic ones--hardware store or Radio Shack the fuse even with same amperage/voltage rating may blow at turn on instantly for no reason------
Dec 08, 2012 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Fuse keeps blowing on my Philips 32pw8608/12
Please, never try to replace a fuse, without checking for any short circuit inside. You will only increase the damage inside. It is advisable to call in a qualified service technician as opening back cover by unqualified personnel is hazardous.
Aug 15, 2012 | Philips Televison & Video
No power or light, plus power supply keeps blowing fuse
you have a short most likely on the power supply but could be on the mainboard, inverter board, av/input board. The T-con board is fused and should blow its fuse before blowing the fuse on the power supply. I'm going with a faulty power supply, most likely a shorted Mosfet.
Sep 24, 2011 | Philips Magnavox 42MF521D/37 Television
I replaced the thermostat with a new Honewell RTH 2510B model. Before I replace the thermostat, the AC repairman added the booster to the compression since he said that was the problem why it does'nt...
Check at the furnace there is a 3 amp fuse on the circuit board you might have blown it when you installed the t-stat without shutting power off to the furnace. Also make sure RH and RC are jumpered together Y= cool G=fan W= heat R=power. let me know ok
Jul 25, 2011 | Honeywell Heating & Cooling
Shortage problem
So stop feeding it fuses and get it fixed. Internet isn't a good medium for hands-on repair.
Jun 06, 2010 | Philips HTS3544/37 Theater System
I just purchased a honewell RTH 221 thermostat. I
Typically the four thermostat wires are:
R = power (or common)
G= FAN
W = Heat
Y = Cool
Assuming that you have a normal electric or gas furnace and air conditioning, if the heat really is coming on, then just switch the position of the the Yellow and White wires.
Nov 02, 2009 | Honeywell Programmable Thermostat Heater
Fuse keeps blowing in the subwoofer on my Philips hts-3450
Replace the capacitors with ones of the correct v. Download latest manual from Philips website to verify if the capacity value is not a typing error.
Jan 03, 2009 | Philips HTS3450 System
Keeps blowing fuses
When a fuse keeps blowing, that is an indication that some component has failed and the circuit is drawing too much current. Most likely it is a problem in the power supply section or high voltage / flyback section.
Sorry to say, you will need to take it to be serviced.
Please let me know if I can be of further assistance to you.
- Jim
Feb 09, 2008 | Philips Magnavox 20MC4304 20 in....
77 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
