Question about Dell Dimension 4600 PC Desktop
Error message on startup
I receive the following error message on startup:
This application has failed to start because SSLEAY32.dll was not found. Reinstalling the application may fix this problem.
I also receive the following error: PRISMSVR.EXE unable to locate component
Not sure if this is related. Any help is much appreciated.
Tom
  • 1 more comment
  • tlfdoc Oct 27, 2008
    No, I haven't uninstalled any program or deleted any program files folders that I am aware of.
    Is there a reliable way to determine what is causing this error message?
  • velut_umbra May 11, 2010
    Have you uninstalled any program recently, or deleted any folder inside Program Files?
    Scholar:
  • 136 Answers
PRISMSVR.EXE is a process related to the PRISM Wireless lan hardware.. Reinstallig the lan cards software should solve it )though you might have to configure it all over again - take note of your current settings).
As for SSLEYA32.dll, if it was the spyware version of this file, it was problably deleted by your antivirus, but the registry call to startup is still there. In MSCONFIG you should be able to take care of that.
On the other hand, this file might be related to OpenSSL Toolkit from The OpenSSL Project. If you are not using this, then be glad it disappeared.
Posted on Oct 27, 2008
Mass effect loads but won't play displays missing required file "ssleay32.dll".
If you have gotten the game from The Pirate Bay, then no one is going to help you, if you have gotten it legally, then try running it with compatibilty settings or reinstalling it.
Feb 11, 2013 | Microsoft Windows 7 Home Premium 64BIT...
I have this error message that pops up when I start my computer "There was a problem starting c:\users\focusconstruction\appdata\roaming\qufvc.dll the specified module could not be found
Go to Search and type MSConfig. At the startup tab uncheck anything relating back to that application. Not to worry if you are not sure. You can uncheck till you find it, or all.
Feb 06, 2013 | Dell Computers & Internet
IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
Mar 21, 2012 | Toshiba Satellite L35-S2194...
Error message
hi,
You can go to this site ..
http://www.fix-all-dll-errors.com/ltkrn70n.dll/
as I registered few dll's from this site... pretty helpful...worked in my case :)
Jun 07, 2009 | Office Equipment & Supplies
Application Error
How to Repair this SVCHOST.EXE error
After some investigating into the 0X745f2780 SVCHOST error, it became apparent the problem is a corrupted Windows Update in Windows XP. Follow the steps below to fix this error.
Verify Windows Update Service Settings
  • Click on Start, Run and type the following command in the open box and click OK
    services.msc
  • Find the Automatic Updates service and double-click on it.
  • Click on the Log On Tab and make sure the "Local System Account" is selected as the logon account and the box for "allow service to interact with desktop" is UNCHECKED.
  • Under the Hardware Profile section in the Log On Tab, make sure the service is enabled.
  • On the General Tab, the Startup Type should be Automatic, if not, drop the box down and select Automatic.
  • Under "Service Status" on the General tab, the service should be Started, click the Start button enable it.
  • Repeat the steps above for the service "Background Intelligent Transfer Service (BITS)"
Re-Register Windows Update DLLs
  • Click on Start, Run, and type CMD and click ok
  • In the black command window type the following command and press Enter
    REGSVR32 WUAPI.DLL
  • Wait until you receive the "DllRegisterServer in WUAPI.DLL succeeded" message and click OK
  • Repeat the last two steps above for each of the following commands:
    REGSVR32 WUAUENG.DLL
    REGSVR32 WUAUENG1.DLL
    REGSVR32 ATL.DLL
    REGSVR32 WUCLTUI.DLL
    REGSVR32 WUPS.DLL
    REGSVR32 WUPS2.DLL
    REGSVR32 WUWEB.DLL
Mar 30, 2009 | Microsoft Windows XP Professional
AegisE5.dll was not found.
hi,
http://www.fix-all-dll-errors.com/aegise5.dll/
u can go to this site...
as I registered few dll's from this site...worked in my case :)
Jan 03, 2009 | Televison & Video
EA Sports Tiger Woods PGA Tour 08 Game won't run on PC
http://www.fix-all-dll-errors.com/d3dx9_32.dll/
You can get it from the above link.
Once you go to the above link click "Fix dll errors now" button and it will fix the problem.
Dec 28, 2008 | EA Sports Tiger Woods PGA Tour 07 for...
The file bcmwltry.exe is the tray bar process for the Broadcom Corporation Wireless Network software.
You can try eliminating the program from start up.
Click on Start >>Run, type "msconfig" (without the quotes), then click on OK.
When the System Configuration Utility loads, click on the "Start Up" tab, then scroll down to the "bcmwlt.exe" entry and UNCHECK the box next to it.
Click on Apply, then OK, and the computer will need to be restarted. Do it. Upon restart, you'll see a System Configuration Utility warning. Simply choose the option to stop it from repeatedly opening.
This will be fixing your problem
Have a great day!
Pablo :-)
Oct 22, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Error loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll
I followed these steps and haven't had any issues since:
1. Go to START menu
2. Select RUN
3. Type MSCONFIG and click OK (or press ENTER)
This will bring up your System Configuration Utility window.
4. Select the STARTUP tab.
5. Find M3PLUGIN, untick it, select APPLY and then OK
This will bring a popup dialogue box stating the following:
"You must restart your computer for some of the changes
made by System Configuration to take effect."
6. Select RESTART.
When your computer restarts, you should no longer receive that message.
Jun 30, 2008 | Intel Motherboard
Dsound.dll
http://www.fix-all-dll-errors.com/dsound.dll/
Jan 26, 2008 | Microsoft Windows XP Home Edition
Dell Dimension 4600 PC Desktop Logo
135 people viewed this question
Alun Cox
