Question about Toshiba Satellite L645DS4040 Laptop
Computer keeps shutting down due to fan not working on toshiba satellite L645D
Got a warning saying Warning: A problem with the cooling system has been detected. Please turn off the computer immdiately, and return it for service........fan stopped working and now computer only stays on for 5 minutes then shuts down, PLZ HELP
  • 7 Answers
SOURCE: Toshiba Satellite touchpad sensitivity
if you go to :
  1. control panel
  2. hardware and sound
  3. mouse
  4. device settings
  5. click the "setings" button
  6. then go to sensitivity
i hope this works as i have a toshiba a200 laptop. while you're there you can toggle palm check in case you lean on the touchpad.
Posted on Aug 06, 2008
  • 17 Answers
SOURCE: my toshiba satellite a215-s7422 is
turn it off turn it over and clean the fan on the bottom. I use a Satellite a25. I have used air to blow out the cooling coils a nunber of times. Toshiba has picuten in the owners manual on how to remove the fan for cleaning. it picks up dust from the work area and does not blow it clear. this cause it to over heat most likely
Posted on Dec 21, 2008
Nic61
  • 1073 Answers
SOURCE: PLZ SEND ALL WINXP DRIVER FOR TOSHIBA SATELLITE
Hi!
There are 2 different models of that M200
Here is the M200-ST2001
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1792800&rpn=PSMC0U&modelFilter=M200-ST2001&selCategory=3&selFamily=1073768663&selModel=1792800%7CPSMC0U
And here is the M200-ST2002
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1792801&rpn=PSMC3U&modelFilter=M200-ST2002&selCategory=3&selFamily=1073768663&selModel=1792801%7CPSMC3U
Select the one you have and download all the drivers you need
Good luck to you
Please take a moment and rate my help for you
Nic
Posted on Feb 20, 2009
mariolands
  • 2296 Answers
SOURCE: Toshiba L450-11G Satellite keeps
To avoid laptop overheating, follow the information from this link.
Posted on Jan 01, 2011
  • 8909 Answers
SOURCE: Ubuntu 10.10 + toshiba L645d
I would take a look at www.toshiba.com to see if there is a driver for your machine. If there is one, it will be there.
Good luck.
Posted on Feb 21, 2011
Toshiba laptop satellite L645D-4040 keeps shutting down
does it shut down and then just start right back up? If it does then press and hold the power button and make sure it shuts down all the way. Then take the battery out and press and hold the power button after the battery is out for about 5 seconds. Then let it sit like 10 - 15 seconds. After that put your battery back in and turn it back on and see if this solved your problem. I think its in a loop to make it keep restarting. Let me know if this helped. Thanks, Herb Stacey
Oct 04, 2013 | Computers & Internet
TOSHIBA Satellite A665-S6065 fan issues
The fan is probably going bad and will stop one day. Once the fan stops your computer will shut down due to overheating. Keep an eye on it.
Mar 29, 2012 | Toshiba Satellite A665S6065 Notebook
I have bought a new toshiba A665 a week ago. I have a problem saying. ' A problem in the cooling system has been identified. Switch off ur computer and return it for service.' Cooling fan is working but...
At a week old, get a replacement or fix it right away. Fix should be free, but no computer during service.....
Toshibas run too hot, in my opinion.... so you have to keep after the fans and keep lint cleaned out of it....
Overheating will yield un stable system,
Feb 26, 2011 | Toshiba (K000831860) Cooling Fan
Warning your cooling system needs service shut down imediatly
That is rather over the top for an overheat problem. Maybe the heat transfer system has leaked and no longer works properly.
Cleaning the exhaust fan usually clears this error.
Feb 15, 2011 | Toshiba Satellite L500 Series Notebook
Toshiba Satellite Pro M10 - system cooling
Unfortunatly, it is time to replace the cooling fan. It is fairly easy to replace if you know your way around the pc. If not, a tech should be able to replace it in about 1 hour.
Good Luck
C2Solutions
Aug 19, 2009 | Computers & Internet
Toshiba p205-s6347 notebook pc shuts down without warning
Your laptop is probably overheating due to an obstructed airflow path or a failed fan. Get some canned air and thoroughly blow out any dust and debris that may be blocking airflow. Sometimes the heatsink cooling fins get matted over with fibers and a lint ball will form in the fan-cage obstructing the fan rotation. If this happens it is often necessary to remove it with tweezers which may require some dissassembly of the notebook.
Mar 19, 2009 | Toshiba Satellite P205-S6287 Notebook PC
Shuts down
thank you for your response....I'm using Vista and the power seems to be on but the screen is down. I have to hold the power button down for 10 seconds to shut down then turn it back on to restore the computer. It is a Toshiba A215-S5818
Jun 18, 2008 | Toshiba Satellite A215-S5822 Laptop
Cooling Warning Setting pop-up
Check Toshiba.com for an upgrade on the thermostat.
Does it feel too hot to you yet?
Jun 11, 2008 | Toshiba Satellite A15-S127 Notebook
Cooling system
Computer hardware related downloads Operating System:, Windows 95, Windows 98. Description:, CPUCooL is a multifunctional utility: 1) Cooling the CPU under Windows 95 / 98.
Read instructions, Good Luck, Please dont for get to Vote/Thank You.
Dec 23, 2007 | Toshiba Satellite A25-S3072 Notebook
Toshiba satellite p10-832 shutting down
Go to the following link... Best
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlView.jsp?soid=1931079&BV_SessionID=@@@@0393765923.1216012797@@@@&BV_EngineID=ccchadeeilhefeecgfkceghdgngdgmm.0
Nov 18, 2007 | Computers & Internet
Toshiba Satellite L645DS4040 Laptop Logo
918 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
