I have an old wall mounted heater when I go to bed I cant breeth but if its not runing am ok what do I do
Remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Sep 08, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
It startedwith no heat fans were runing no fluid comming out of top house with eng runing
Remove both heater core hoses and try to back-flush unit. If you can't get good clean flow, replace heater core.
Feb 27, 2015 | Cars & Trucks
I have a wall mount 25000 btu empire. It keeps clicking on and off trying to light up. after about 4 or five tryes it starts, runes for a short time and shuts off. A funny noise comes from the burner area....
You're heading in the right direction. Especially, with a 10 year old heater that's never been cleaned.
Using a vacuum (a shop vac is great for this) that has a hose and brush attachment will do the job. Also, canned compressed air with a straw nozzle (like you clean your computer with) can be used to blow out the pilot tip and reach areas the vacuum can't.
After you've cleaned the heater, check for wear and damage to any of the internal parts. Especially, any wiring that may look burned or frayed. Also, be sure that the exhaust vent damper is working properly and the exhaust vent piping is free from obstructions. The clicking you heard may have been from the automatic safety damper switch.
If after 10 years you can't find your Owners Manual, here's a link to it. It will assist you any cleaning the unit and spot any problems.
http://www.empirecomfort.com/EMPIRECOMFORT/pdf2009/manuals/12425-1008GWT.pdf
Good luck and remember to clean the wall heater annually.
Rich
Feb 11, 2011 | Empire GWT-25 Wall Mounted Panel Heater
I have an older rental home that has a wall heater, house built in 1960 and I need to purchase a cover, the dimensions are 18 1/2 x 70 inches HELP.
im sorry but you cant get a new cover for a unit that old the best you can do is try to find a used one mabey put a ade in the paper someone might have an old williams heater that dosint work inymore and might sell a cover to you.
Jan 21, 2011 | Williams (5009622) Ceramic Gas Wall...
How do i remove the stand/base off a panasonic viera TX37LZD70 37" flat screen tv so I can wall mount it?
Place the TV on a flat bed preferably your mattress and look for the base mountings. The lock and base mount can be slid off and you can use a good wall mount that will support the weight to be fitted.
Please find the link below for help:
Wall mounting flat TV
Jan 07, 2011 | Panasonic Televison & Video
The heater pilot goes out when the wind blows outside of the wall where the heater is installed. The heater is only six months old, so the thermo-couple is OK.
You mention that the thermocouple is OK, has it been changed or tested? This $4 part is usually the first thing to fail and I have found bad parts right out of the package. If I were you and I would contact the installing contractor to have them check out the following: Is the vent termination located as per manufacturing instructions (away from interior adjoining walls), Are the vent parts installed correctly, replace the thermocouple under the warranty, and check to make sure the pilot is both good and strong and it is hitting the thermocouple where it should. I have these heater installed on the top of Mount Washington where the wind blows at over 60 miles an hour and do not experience a pilot outage due to wind. The interior design of the venting system combats the wind effects. Good luck to you.
May 06, 2010 | Cozy (W352E) Heater
Need heat element for fasco wall mounted bathroom heater, the element is M shaped
try to found a local manufacture for heating elements, like http://rezistoterm.xhost.ro/ , give them the old heat element and the power of the bathroom heater (ex: 3000W and 220v, or 2000W and 110V) and they wil macke new oane and much chep like an original one.
Feb 14, 2010 | Fasco Heating & Cooling
I am needing to to buy a thermal coupler for a dyna glo wall mount heater model #RMC50NGT where do I find one???
Almost any hardware store carries thermocouples and thermopiles. Take your old one with you so you get the right length.
Jan 28, 2010 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Heater wont work on high setting
Clean the burner with a wire brush and vacuum the ceramic. Blow out the heater, remove dust, cobwebs, and lint from it.
Oct 19, 2008 | Desa International GWP20T GLOWARM Wall...
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
