Question about Toshiba Satellite A300-ST6511 Notebook
Toshiba satellite a300 powering on but still toshiba screen
When power is on then the toshiba screen displayed but not move to booting section, so i think it's hang
harrykang007
  • 22 Answers
SOURCE: when i turn on my Toshiba Satellite A300 the
we need to restart the computer in safe mode( press f8 keys a few times right after restarting the computer). log on to the admin account...on desktop screen click start button > click run > type msconfig > click ok > you will get system configuration utility screen on the top right of that window there is a tab start up > click it and click disable all click apply and ok..restart the comp..
if it works well and good otherwise after clicking on disable all under start up tab > there is a diff tab next to it called services > click that on bottom left you will get a check box that says hide all microsoft services > check that box and click disable all> apply> ok> then restart the computer it will work
if not > then you need to re install the operating system
Posted on Dec 15, 2009
  • 20 Answers
SOURCE: Toshiba Satellite A210 will not boot
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
kapena8
Posted on Jan 03, 2010
  • 11800 Answers
SOURCE: how to remove Toshiba satellite a300-146 bios password?
On Toshiba laptops this can be done only by a hard BIOS reset, and this can be done only by the dealer, by rewriting the BIOS with a special device. Time to take it there, luckily it will be cheap, less than $40.
Posted on Jul 18, 2010
portland1970
  • 145 Answers
SOURCE: how to reset bios password
http://www.tech-faq.com/reset-bios-password.html this should help...there are a number of programs out there to reset the password. if you need further assistance you can contact me at maranathaenterprises@live.com
Posted on Jan 28, 2011
pctech1
  • 1940 Answers
SOURCE: toshiba satellite a300 laptop display
You laptop either needs a new Cable from the Motherboard to the Screen, a new power inverter, or a new screen. Most commonly, I have seen the video cable get smashed between the hinges/plastic case, and this causes the wires to break apart, leading to a black screen.
Here is the power inverter for your laptop: http://www.sparepartswarehouse.com/Toshiba,Satellite,A300,PSAG0U-0CF035,Laptop,Inverters.aspx
Here is the video cable for your laptop: http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=3392&zenid=7903c7a1a62c4c2cbfef6ea30865373c
Here is the LCD screen for your laptop: http://www.sparepartswarehouse.com/Toshiba,Satellite,A300,PSAG0U-0CF035,Laptop,LCDs-Displays.aspx
If the display comes back, slightly, when you lift the display lid up and down, this would be a sign that your cable is bad. If you get no reaction from opening and closing the lid, you may have a bad inverter or screen. It is most commonly the inverter or the cable.
If you have a spare monitor, you could plug it into the VGA connector on your Laptop as a temporary solution. If after plugging the monitor in, you get no display, try pressing Fn + F5.
Posted on Mar 09, 2011
My laptop toshiba a300 going to sudenly reset& sometimes power off
First, Is the laptop fan, heatsink, vents clean free of dust. If it's overheating it will shut down to save components for overheating. The Graphic Adapter is a big heat producer. As to the processor running at 100%, It's also a big heat producer, shut down some of the running processes that are not needed. At startup their many programs that are not needed. Use this freeware program, it has many useful tools. Download CCLEANER at : http://www.filehippo.com/download_ccleaner/ This freeware program will remove the junk from your machine, in the TOOLS section, STARTUP section, disable ALL unnessary startup programs. Here are some tips on speed : http://www.pcworld.com/article/143538/windows_vista.html
Jan 31, 2013 | Toshiba Satellite Pro A300 Notebook
Toshiba satellite a300 laptop display problem screen black, no display at all.
Mar 09, 2011 | Toshiba Satellite A300-0CF035 Notebook
Iv got a toshiba satellite A300 and i was wondering how can i speed my my graphics card ( in any way ) whenever i try to install games and play they there is always a fault of some sort one fault that...
When you will increase the ram your laptop will be fast soon.
You can increase 4 GB maximum.
For dissemble follow bellow the link
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A355-A355D/laptop-disassembly-1.htm
Maximize your Toshiba Satellite A300-ST6511 mobile computing power and add more memory. Trust PRO Memory Upgrade to provide dependable expansion options for your laptop or notebook with a Toshiba Satellite Small Outline DIMM RAM upgrade.
  • Your Toshiba Satellite maximum RAM capacity: 4GB
  • The Satellite A300-ST6511 has 2 memory slots or sockets
  • This Satellite module upgrade PIN count is: 200-PIN
  • The memory speed is: DDR2 800MHz, PC2-6400
  • The DIMM type for your Satellite A300-ST6511 is: SODIMM, SO-DIMM, Small Outline DIMM
  • For4 diassamble the
Hope it help you.
Jan 08, 2011 | Toshiba Satellite A300-ST6511 Notebook
I have a Toshiba satellite pro A300 which when it is powered up shows the 1st screen with options for setup etc using F2 and F12. The laptop responds to neither and goes to blank black screen with a white...
Hello,this is a common problem that is caused regularly from a virus or a software/driver that you have recently added and caused this.The first you must do is to try to boot from safe mode(pressing F5,F8) while you booting and enter safe mode and remove anything you installed recently.Also you can try to select Last Know Good Configuration.If non of this helped you must reinstall or repair the operating system.Am waiting for your reply.Good luck
Feb 04, 2010 | Toshiba Satellite A300-0CF035 Notebook
Toshiba a300 does not charge new battery and wont boot up now
Power supply cord is faulty. You can get another from newegg.com or amazon.com or ebay.
Sep 16, 2009 | Toshiba Satellite A300-0CF035 Notebook
Toshiba A300 not booting.
plz take out the battery and try if the problem is not solved then try by resiting the ram. if you are not familiar with the computer terms and parts you plz ask some professional to help you from your area
Feb 22, 2009 | Toshiba Satellite A300-0CF035 Notebook
Toshiba Satellite A300-ST6511 Notebook Logo
100 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
