Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
1995 rca 52 inch tv...
My problem is the tv started turning itself off,but if i waited a few minutes i could get it back on it gradually got worse and worse.once i got it on id leave it on be fine the picture has no problems.my son turned it off the other day and i havent been able to get it back on since.the green light will flash three times then stop.each time it flashes it will try to work but wont.please help.
  • tonypruitt19 Oct 24, 2008
    my model # is p52754a2...thanks so much for your time and help.
  • RCA Master
  • 8,617 Answers
Please post the model number of your RCA as usually its a bad flyback and start up capacitor when you get a 3 blink error code . But I can help you better if I have the model number of your set.
Posted on Oct 24, 2008
Our RCA high-def 52 inch TV is shutting off on
It has you Posted as a projection TV and Not DLP, if Fan to Lamp stops running set will shut off to protect Lamp,I had a DLP that would play sometimes 30 mins then shut off drove me crazy trying to firgure it out and it turn out to be Fan would stop running I replaced Fan TV working fine . When you remove back engage toggler switch to up position put a piece of tape on it to hold it is a safty switch ,then turn tv on watch to see if all fans are running also if when tv trys to come on is there a spark coming from Ballast Board if so your new Lamp is defective it does happen if not your ballast board maybe Bad it is what turns on Lamp.If all fans are running Ballast Board.
Sep 22, 2009 | RCA HD52W56 52" Rear Projection HDTV
52 inch RCA Home theater-Sound is distorted/scratchy
I unplugged the tv for 5 minutes. When I turned it back on, I had sound!
Aug 01, 2009 | RCA 32V420T 32" TV
52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
My 52 inch RCA HD/TV Does not turn on
Replace CP150 on the deflection board and that should take care of the problem since it starts once in a wnile if it didnt start ever then you would need the 259296 flyback and the CP150 Capacitor.
May 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA SRS Focus turning on and off
the best thing you can do is take it to a shop and have it repaired as the problem has gotten worse..
Jan 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 INCH D52W20B WON'T COME ON
A 1995 60 inch rca good picture and sound. Then it started a cracking noise and a hissing sound, then the picture went blurry. then it was nice picture and sound, then it died. took the back off and turned out the lights. Plugged the tv in and out from the wall socket and there was a sparking noise and a small arc when i plugged it in and out a few times ,at the part that the power plug plugs into.The white part that is beside the white power plug part has thick red wire coming out of it and goes into another plug that has more red wires in it. but the big white part beside the power plug part looks burnt and has black powder on it. that part is probably the problem but maybe not, what it the name of that part and how much would it cost and is it plugged in or soldered.
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
My rca 52 inch hdtv turns itself off after a few minutes
Sounds like the green tube shorting intermittantly. Have a qualified tech use a tube restorer to check for shorts, or the loss of the 300v line to the green tube.
Aug 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52" RCA d52w19
About middle of the board you removed the flyback,there is a u shaped heat sink this is in the middle of the board,behind the heat sink is a blue cap 2200 uf ,if the top is pushed up the cap is bad.
Mar 11, 2008 | RCA D52W19 52" Rear Projection Television
Light
My RCA 52 inch was doing the same thing.  TV guy had me use a regular hair blower blowing very hot on the power supply board ( bottom left in back). After a few minutes the tv would come on.  He replaced 2 capacitors, charged me $100.00, plus the $95.00 service call, and is working fine now.  This was a month ago.  So far so good.  He only took the board to the shop, not the entire tv.  Hope this helps.
Oct 04, 2007 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
210 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
