Question about Refrigerators
Hotpoint ff200dp when fridge door is opened and then fully closed the warning light beeps and I have to forcibly press door to get it to stop. The temp dial also defaults on the fridge.
The warning light has always been very sensitive but yesterday the fridge stopped cooling. Switched off and re-started and it came back on but every time I now open the fridge door and then close it, the temp setting on the fridge de-faults and warning light beeps. To get this to stop I have to very forcibly press the door for about a minute before it restarts. Any advice would be welcome as I am on the verge of replacing a two year old F/Freezer that does still work!!!
  • 531 Answers
SOURCE: Fridge worked perfect for 3yrs, one day i took
you may have a big problem not sopose have the door open so long better you call service
Posted on Apr 02, 2009
diodeic
  • 1622 Answers
SOURCE: The alarm beep which tells you to close
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
Good luck......
Posted on Aug 15, 2010
heatman101
  • 43501 Answers
SOURCE: Hi, My fridge ( 420 ltrs)
The noise is the fan hitting ice build up on the coils... it is no defrosting properly...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 14, 2010
  • 117 Answers
SOURCE: motor noisy, stops when open refrigerator door
you may want to check out
samsung fridge freezer diy help
this is a common fault on some samsung models , defrosting it doesnt usually solve the underlying fault , normaly fault will re-occur ...
check these videos out
Posted on Oct 18, 2010
  • 2187 Answers
SOURCE: F15 fault. RF610A F&Paykel fridge.
Check the FAN of the unit. IT may have started to go bad (weaken) or have gone bad or some wiring is loose which may cause it to go out.
Posted on May 30, 2011
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
My fisher paykel model number# rf170adx4, serial # rhg755331 fridge beeps every time we open the door (not leaving it open)! It's a brand new fridge.
It is probably just a warning beep to let you know the door is open. It should stop when the door is closed. There may be an override setting to cancel this. Have a look in the Owners book to see if you can reset this or check with your F and P Customer service centre and ask.
Nov 19, 2016 | Fisher Refrigerators
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Jul 27, 2014 | Hotpoint Refrigerators
Dishwasher
It could be you opened the door before it had fully completed a program, and then turned it off. My Hotpoint machine has to be reset in these circumstances otherwise the next time it is turned on, it appears to let you select a different program but when you close the door resumes the program it was running when it was interrupted.
You don't say which model you have, so I cant give you a definitive answer, but you could try the following sequence which works on my Hotpoint:
1. Open door and switch machine on.2. Press and hold down the P button for several seconds until it gives a series of beeps (mine = 3 beeps).3. Release P button.4. Select the program you want in the usual way using the P button.5. Close door, and the machine should then run the selected program.
Hope this helps.
Sep 18, 2012 | Hotpoint Dishwashers
Whenever I open the door the beeper starts beeping and continues for 19 beeps regardless of whether I leave the door open or close it again. The beeps are at approx 1 second intervels
Whenever the fridge is open it gives 19 beeps actually.In your case even when it is closed it is giving 19 beeps.This is the problem with control board.The control receives the signal when closing the door and stops the sound.Check the wiring connection to and fro the control board to the door.Control board costs high.This is small problem you can just unplug the wiring connection to the door to the board instead of spending more.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Feb 01, 2011 | Refrigerators
The alarm beep which tells you to close refrigerator or freezer door now beeps even after either door has been closed. It beeps three times at approx twenty second intervals, then beeps continuously for...
Good luck......
Aug 15, 2010 | Fisher and Paykel Active Smart® E522BR...
Samsung RB1855SW won't stop beeping and fridge malfunctioning
Thanks so much for the advice. I just gently pried the door sensor switch on my Samsung RB1855SL out with a butter knife and then pulled out the electrical connection and it fired up right away. It looks like some orange juice seeped in and corroded it. What a relief to have the fridge working again, not to mention to not have to listen to the beeping.
Apr 01, 2009 | Refrigerators
Fridge/freezer beeping
There is a lever switch usually above the door (when door is in open position) on the fridge cabinet. Not on the actual door. The beeping should stop if this lever is pressed. If the door is positioned correctly it would depress this lever when closed. It may be that the door adjustment is slightly out. If the beeping does not stop when depressed, then your printed circuit board (located usually above the door) is faulty and needs to be replaced.
Mar 04, 2009 | Refrigerators
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
