Question about Samson Technology Zoom R24 24Track Recorder Interface Controller Sampler
Getting a 'NO CARD' error on my ZOOM R24, with SD card in unit. Please help!!!
3 Suggested Answers
  • 5603 Answers
SOURCE: I just bought a Zoom
OK... first thing is to make sure the SD card is 2 Gb or less as larger won't work.
Many of the SD card has a protect switch that prevents writing to the card... it is a real tiny littl thing to move with your fingernail. You might need a magnifier to see it.
Posted on Apr 01, 2011
  • 367 Answers
SOURCE: I HAVE A ZOOM R24
So I assume when you say you downloaded the latest drivers, you are talking about the version 1.3.0 from this source: http://www.zoom.co.jp/downloads/r24/
Ok so to configure Apple Logic Pro to use this control surface follow these instructions:
CONTROL SURFACE SETUP
1. Select "Preferences" > "Control surfaces" > "Setup..." from the "Logic Pro" menu. This opens the "Setup" window.
2. Click on the top left "New" and select "Install" from the pull-down menu.
3. Select "Mackie Designs/Mackie Control/Logic Control" from the list in the "Install" window and click the "Add" button.
"Mackie Control" will be added to the setup window.
4. Click the "Mackie Control" icon. Then, from the top of the list at the left set "Out Port" and "Input" to "ZOOM R16_R24" using their pull down menus.
FUNCTION KEY SETUP
1. Select "Preferences" > "Control surface" > "Controller Assignments..." from the "Logic Pro" menu. This opens the "Controller Assignments" window.
2. From the "Zone" column select "Control Surface: Mackie Control." Change the functions as you like.
3. Controls F1~F5 correspond to the F1~F5 keys on the R24.
The above procedures are for Logic Pro 9. The names of the menus, for example, might be different in a different version of Logic.
Make sure you have run all the MAC OSX updates from your System Menu > Check for updates.
This device needs full USB power so don't run it off a USB hub unless its a powered one.
Posted on Sep 09, 2011
Zoom h1 handy recorder
Have you tested the Micro SD card? Check it with your computer and load an MP3 to it. Play the recording in the Zoom to check the Zoom
May 27, 2014 | Music
H4n zoom wont record says card protected
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 23, 2013 | Samson Technology Zoom H1 Recording Bundle...
SEtting tempo on metronome Zoom R24
The metronome speed is controlled by the Tempo setting. The metronome controls only adjust the volume of the metronome and if the metronome is heard on the input or output recording. The R24 manual is available here: http://www.zoom.co.jp/downloads/r24/manual/ . See page 20 for setting the Tempo. The Tempo button is below the Tempo label to the left of the LCD display on the right side of the Zoom R24.
I hope this helps.
Jun 01, 2012 | Samson Technology Zoom R24 Multitrack SD...
The booting up screen says card protect. I don't know where the sd card lock switch is to release this.
The small SD cards have a tiny slide switch on the side of the card... it is TINY !!!
Jul 14, 2011 | Zoom H4 Handy Recorder
I just bought a Zoom H1 and the SD card won't format. What should I do?
Apr 01, 2011 | Samson Technology Zoom H1 Recording Bundle...
I am not able to use 4GB Sony SD card in my CTK 5000 Keyboard. It is sensing but I am not able to format the SD Card and flashing 'Card R/W Error'.
It appears that a LOT of devices cannot use cards greater than 2Gb. You will find on page E72 of your user manual that the SD card must be 2Gb or less for this unit.
Mar 29, 2011 | Casio CTK5000 (61Key Portable Keyboard)
Will i need to buy a midi controller to record with my zoom r24
no, but if you want to control anything remotely you would need one
Mar 19, 2011 | Samson Technology Zoom R24 24Track...
I have the a Casio Keyboard that has an SD slot, but whenever i put songs on my SD card & then plug it into the keyboard, it says that there is an ERROR . What am i supposed to do . Step by Step . to...
Does it say ERR NO FILE? If so, then read on. The reason you have this error is because you don't have a folder on your sd card named MUSICDAT. Solution:
  1. Insert your sd card into computer
  2. Make folder called MUSICDAT.
  3. Then, transfer all files inside the folder (make sure your songs are in MIDI format).
  4. Safely remove your sd card.
  5. You're ready to put it in you Casio Keyboard!
If you still get the error, take time to read you manual. Read the "using the sd card" part. The folder name might be different for your Casio Keyboard (because mine's a CTK-5000).
...and IF you still get the error, perhaps the songs you meant in your question are MP3 songs (like the ones you play on the iPod)? Then, that's a different topic... :)
Well then, good luck!
Feb 28, 2011 | Casio Lighted Keyboard LK90STADMC
When I turn on my Zoom H4n, it says "no card" even though I have a card in it. Why is this? How can I fix this problem?
My zoom h4 will not turn on at all....not with new batteries or the AC adapter.....any suggestions? Worked fine last time used.
Feb 13, 2010 | Zoom H4 Handy Recorder
I think my Micro BR is broken
It is either that you put an incompatible SD card in it. (Believe it or not, many devices will not work with certain SD cards), or the card reader has failed. Try a Scandisk SD card or other popular brand and see if there is any difference in the messages. Otherwise I would say the card reader is faulty.
Aug 06, 2008 | Boss Micro BR Digital Recorder
Samson Technology Zoom R24 24Track Recorder Interface Controller Sampler Logo
167 people viewed this question
Top Samson Technology Music Experts
Michial Gueffroy
Chris Larocque
DROPNDEAL
DROPNDEAL
Are you a Samson Technology Music Expert? Answer questions, earn points and help others
