Pc recognizes insignia mp3 player but dont have the software to get it to charge
SOURCE: Insignia NS-DV4G video player Cant connect via USB, pc does not recognize, no cd!! help plz
What operating system do you use?  If you have Windows XP all you need to do is connect it and windows should detect it.  If it doesn't connect it activate the hold switch and connect it to your computer.  It should show up as a USB removable drive.  If that still doesn't work try a different USB cable.  After that I stuck.  As for the software I don't know where you can get a copy.  I looked at the insignia web site and it isn't available for download.  Since it is basically a modified version of Rhapsody you may try downloading the regular version of it and see if it works.  I use MediaMonkey and it works well.
Posted on Oct 26, 2007
  • 4 Answers
SOURCE: Samsung YP-K3 MP3 Player won't start
Simalar problem to all above plus PC would not recognise the unit when connected. Solved however by going into Device Manager on PC, uninstalling it and then plugging back into PC. As it is all plug and play it took it as a new device and everything working perfectly again.
Posted on Aug 24, 2008
iixtreme
  • 7 Answers
SOURCE: RCA M4208RD-B MP3 Easy Rip software issues
Try updating the Easy Rip software before connecting the player.
Posted on Dec 27, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: My Sansa Clip (4 GB) is not detected in pc but it get charged.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
  • 10 Answers
SOURCE: My computer dont recognized my mp3 m-230 what can i do ???
mostly, mp3 devices comes with a software.
if u have the software, and the usb dont recognize your mp3 device. most probably the problem is in you usb drive or usb connector.
Posted on Feb 27, 2009
Firmware problem with insignia pilot 4GB mp3 player
Please contact the manufacturer's support site, if any firmware updates are available they will be there with instructions on how to install them. I really don't think you have a firmware problem here, but it is worth a try.
Mar 30, 2017 | Insignia Pilot MP3 Player
Mp3 insignia sport
is the battery in correctly and is the usb cable fully inserted on the computer end if your going throug a usb multi-port hub make sure its not over loaded with too many devices
if no hub try a different usb port or a different cable
Aug 10, 2008 | Insignia NS-DV2G MP3 Player
My insignia
Try reformatting the unit using your PC as a FAT formatting. Don't use "quick format" so you can completely erase any glitchy memory points.
Also, press and hold the Reset button (little hole on the bottom right of the player) to reset the software.
Jul 20, 2008 | Insignia NS-DV2G MP3 Player
Problem with my Insignia Pilot 4GB Video MP3
the same thing happend to mine i just left it alone the battery eventually went dead when i conneted it to my computer it charged and has worked ever since
Jun 13, 2008 | Insignia Pilot MP3 Player
Need manual for Insignia NS-4V24 MP3 player
pull switch on right top to the right until it comes on. same to shut off.
Jun 11, 2008 | Audio Players & Recorders
Trying to Load Video from Amazon Unbox - Help
The file extension is usually *.avi on Insignia players. So try renaming the file.
Jun 02, 2008 | Insignia Sport MP3 Player
My insignia pilot 8GB !!!! HEEEEEEEEELP!!!!!!
my screen is not working it all black . the screen is broke
May 11, 2008 | Insignia Pilot MP3 Player
Lost cd to insignia player 1gb
There shouldn't be any driver software on a CD for this player. If you need the Digital Music Store, go here:
http://rhapsody-usa.com/best-buy/
If your computer is still able to recognize the player, you can still manually place music files on the player by switching the player to File&Folder mode.
Mar 24, 2008 | Insignia NS-DV2G MP3 Player
Will not charge
i cant get music to go to my mp3, its hooked up to the scomputer, and i dont know how to transfer music
Jan 15, 2008 | Insignia NS-DA2G MP3 Player
16 people viewed this question
 Grubhead
Grubhead
