Question about Toyota Hilux
Caution light comes on in 2001 toyota hilux - Toyota Hilux
3 Suggested Answers
  • 104 Answers
SOURCE: my batery light nd yellow light think it is oil
check to see if alternator is working usually when light comes on alt has failed check oil level if level okay poss bad oil level sensor or wiring
Posted on Oct 20, 2009
Testimonial: "it was t altinator nd t yellow light was water in t fuel filter problem solved by changing t altinator yellow light went out 2 thanks"
  • 57 Answers
SOURCE: 2002 Toyota Camry . .
posible short or bad earth see auto electrition
Posted on Aug 06, 2011
How to find and change fuel pump Toyota hilux 2001 model
Should be inside the fuel tank. Drop the tank or lift the bed to gain access.
Jul 26, 2016 | 2007 Toyota Hilux 2.7
Toyota immobiliser
When a battery is replace there is a possibility that certain elements of the CPU program become corrupted. Try using a scanner to reset the CPU program in the ECM to see if that turns on the immobiliser section.
Oct 06, 2014 | 2006 Toyota Hilux 2.0
How do you unlock toyota hilux immobiliser
please give me your immobiliser or alarm system info .if is immo system problem when you turn on switch meter will no come out check engine light ,please check it.
Aug 25, 2014 | 2007 Toyota Hilux 2.7
How to reset toyota hiluxe airbag lighet
Because there is a;ways an explosion danger, I would not go there. Just ask a Toyota certified repair centre to solve the problem. You never know what is wrong.
Check your manual, if the airbag can be switched off, when you have a baby on the passengers seat. Perhaps that is the problem.
Jul 16, 2014 | 2007 Toyota Hilux 2.7
Code p1220
2001 tubo deisel hilux loss off power and check engine light
Dec 05, 2012 | Toyota Hilux
Toyota hillux vigo
Click the help link below,in related to toyota Hilux.
Toyota Hilux Surf Fuse Box Diagram? http://technoanswers.blogspot.in/2012/06/toyota-hilux-surf-fuse-box-diagram.html
How to lower fuel pressure on Toyota Hilux? http://schematicsdiagram.blogspot.in/2012/02/how-to-lower-fuel-pressure-on-toyota.html
2012 Toyota Hilux SR5: Immobilizer override and bypass? http://whatisbyme.blogspot.in/2012/05/2012-toyota-hilux-sr5-immobilizer.html
2006 Toyota Hilux: Programming New Key? http://technoanswers.blogspot.in/2012/04/2006-toyota-hilux-programming-new-key.html
These details should help.
for more help.
keep updated with more details.
Thanks.
Oct 15, 2012 | Toyota Hilux Cars & Trucks
Hi there. i have a 1986 toyota hilux 3.0l turbo(knocking)
I have a Toyota Hilux 3.0 KZ-TE fitted with a intercooler and on Saterday on a 4x4 outing the engine light on the dashboard came on and the motor started spluttering and excessive white smoke came out of the exhaust. The problem persisted for several minutes and then went away. The verdict from other 4x4 owners was that the turbo needs an overall, I cannot understand this as it is fine again with no mechanical interferance.
Mar 02, 2009 | 1986 Toyota Pickup 4WD
2001 toyota hilux deisel car wont go over 1500 rpm
this is called an idiot light in the trade, it is telling you that you have a major engine problem and your engine is going into "limp home mode" get your dealer to check it out
Feb 25, 2009 | 2001 Toyota Land Cruiser
Taillights not working on hilux
try the pressure switch on the brake pedal itself sometimes they get stuck in if so wd40 it or at times the wires come off or the switch itself needs replacing you can test if the switch is faulty by touching the two wires together the lights will come on if they dont its not the switch
Nov 03, 2008 | 1994 Toyota Camry
Toyota Hilux Logo
24 people viewed this question
Top Toyota Toys Experts
Thomas Perkins
Thomas Perkins
Rabbit Brains
Rabbit Brains
Stan Ford
Are you a Toyota Toy Expert? Answer questions, earn points and help others
