Hi today i fine a asus laptop motherboard f5Rl, top side mother board,dc jack connoctor side there have something it is fire. any one can tell me what is that?and what i put here.
jgwhomeequip
  • 1902 Answers
SOURCE: my laptop does not turn on
No idea why they fixed the problem then said it is the motherboard. There are times though when the motherboard is actually bad and it does need to be replaced even with replacing the jack. With a motherboard it has to convernt electricity and sometimes the wiring is fried or bad. But if it works then let it run, if not, I would take it some where else and have another company check to make sure that they did not melt the board causing it to be a board problem
Posted on Feb 20, 2009
rtrahan
  • 741 Answers
SOURCE: Hallo, where i could find my ASUS F5RL MOTHERBOARD
If you are using Windows XP, click on start>program>accessories>system tools>system information. The motherboard model number is on the list.
Good luck, let me know if you have any questions.
Rate with 4 diamonds before logging off.
Posted on Mar 07, 2009
  • 211 Answers
SOURCE: Intermittent dc jack connection for Gateway mx3215
Here is how to disassemble Gateway laptop,
Here is replacement DC socket (needs soldering),
Here is DC board (no need soldering, but expensive).
Hope this helps.
Posted on Mar 17, 2009
pumpkinman
  • 1165 Answers
SOURCE: Acer 5610 DC jack problem - need to dismantle laptop
The solider tends to loseen up on the power connection.Make sure all screws are removed some are under the covers on bottom of laptop slightly pry the top up where ever it seems to be holding look for a screw underneath where its holding.if all screws are out it should come off fairly easy.
Posted on Oct 05, 2009
  • 106 Answers
SOURCE: i need hp pavilion dv7
I am not exactly sure what is the problem. Are you certain it is a power problem with the mother board? It could also be damaged or non functional.
Here's a troubleshooting guide from HP that might help you.
and the product's manual:
Posted on May 22, 2011
I can not identify where to silder wires connecting to my mother board
And you expect by this one lone statement, that someone else can?
A) Lenovo laptop? Good. Now POST the model number.
It's on the Bottom of the laptop.
B) Solder wires connecting your motherboard to WHAT?
Passing airplanes?
State what you are trying to connect to.
DC Power Jack to motherboard?
Is the DC Power Jack a DC Power Harness?
The DC Power Jack has wires coming off of it, that end in a plug connector.
The jack plugs into the motherboard.
Did the plug connector come off the wires?
Post back in a Comment.
Regards,
joecoolvette
Jan 31, 2013 | Lenovo 3000 Computers & Internet
I have XPS M1530 DELL Laptop. DC JACK(power charging port has broken from mother with a very small piece of mother board)....I had tried to call customer care ..he told you should change the motherboard...
If this motherboard is a multi-layer motherboard then it is impossible to repair.
You can try to repair the motherboard by glueing the broken piece onto the motherboard with epoxy glue. Then identify the broken power circuit tracks between both parts of the circuit board, and then solder wires across these tracks or to the closest solder connections to re-establish the electrical connections on the motherboard.
If this does not fix the problem then most likely it is a multi-layer motherboard and you cannot bridge the internal connection inside the motherboard.
Jun 22, 2011 | Dell XPS M1530 Laptop
I replaced the DC jack on the laptops motherboard because my Charger Fried and also melted the inside of the DC Jack, But not That I have installed a new on the power doesn't seem to come on at all, The...
There is. It would appear that the DC jack was not the only thing that was fried. If all your solder connections are correct, the mother board may have been damaged be the shorting of some part on the board, and burned open. Look for fuses, and "resistors that are have a "0" on them. they should read a short. if you find nothing. the board is damaged beyond repair.
Apr 18, 2011 | Samsung V25 XVC 2800 Notebook
My laptop will not turn on the power supply is is fine gateway m6880
If laptop will not turn on and the power-supply is fine then it will be the computer itself and the only way to fix that would be a new motherboard due to the everyting oinside the laptop is pretty much connected to the mother board and not able to replace it without replacing the motherboard
Mar 28, 2011 | Computers & Internet
Hi,my notebook is not turning on .Charging is good .When i press switch button charging process is stopping to 1-2 seconds then continues .Maybe problems in motherboard?Product Details for ASUS F5RL-X1...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Sep 16, 2010 | ASUS F5RL-X1 Notebook
Where to buy a F5RL motherboard in Australia
Did you do a Google or eBay search for the motherboard.
Fellow oz in QLD (not so sunny at the moment).
Feb 10, 2010 | ASUS F5RL-X2 Notebook
Hope this helps.
Mar 17, 2009 | Gateway MX3215 Notebook
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
Broken DC in Jack
I agree, the best option is most likely a motherboard replacement.
You can search Ebay, there are several places that advertise DC power jack repair, But from my experience, repair is an iffy proposition.
Jul 07, 2008 | Twinhead SlimNote N12PI Notebook PC
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
