THE MACHINE IN USE LIGHT WILL COME ON AND THE LIGHT SHOWING THE DOOR IS LOCKED, IT WILL THEN PROCEED TO FILL WITH WATER, BUT THEN STOPS, THE LIGHT STAYS ON BUT THE WASHER STOPS DOING ANYTHING, IVE UN-PLUGGED IT AND LET IT SET AND PLUGGED IT BACK UP AND STARTED AGAIN AND IT DOES THE SAME THING
PLEASE HELP.
SOURCE: Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
SOURCE: Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
SOURCE: SpeedQueen washer trouble
You could have a couple problems, it could be the timer, motor or Transmission.
Start by removing unplugging the washer,
Now remove the front panel, two 5/16" screws at the bottom of the front panel. the front panel will either drop off or you have to turn it up to remove it
In the front on the bottom is the motor, on the bottom of the motor is the belt. This belt drives the pulley on the bottom of the transmission. It should turn both directions. in one direction the transmission will ramp up and unlock the brakes letting the unit spin. The other direction the transmission will cause the agitator to turn back and forth. you may need two people one to watcht the agitator and one to turn the belt, Now if the transmission does not turn at all you have what is known as a locked transmission. This is a major expense. Look for a new machine.
If the machine does actually agitate and spin when you move the pulley it could be as simple as a motor or timer. Please let me know what you find and we can go further.
T
SOURCE: just gota new ewf1495 front
Peace Friend,
ngfam1 At your service!
With an error code Flashes the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
YOU HAVE A ONE YEAR WARRANTY LET SERVICE RAN THEIR KEEP AT NO COST TO YOU!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
SOURCE: Water runnning out from bottom of washing machine
Barbarahaps,
I had a similiar problem with a Brand X washer. the problem may be your water pump. if so, it is an easy fix for someone who is mechanically inclined. you first must see where the water is leaking from. when i did this, i securly placed my washer on cinder blocks so that i could see underneath it, and let it fill with a little bit of water, then i could clearly see the water leaking out of the water pump. the key concern here is safety, make sure that the machine fills with only a little bit of water, and then cut the power off to the machine to ensure it doesn't start going through its cycle while up on the blocks, creating a potential hazard. If it is the waterpump, find a washer repair store, tell them the year and model machine you have, and get a water pump on order. the water pump is a pretty straight foward repair--you disconnect power from the machine, turn off and disconnect the water supply, disconnect the drain pipe, and tip over the washer to expose its under side. you disconnect the hoses going to the water pump, remove the attaching bolts, and install the new pump. then you hook everything back up and you should be good to go. hope this helps.
Open the front door and load the clothing into the washing machine. Check the owner's manual for the maximum load size. Overloading the washing machine may interfere with its ability to spin the clothes and rinse them clean.
I have the same problem. I've noticed that when it stops the buzzer goes off too.
Only fills. No spinning? What age is washer...first four of serial numbers will help.
