Question about Radio Communications
My bluetooth jabra 0te2 is not working - Radio Communications
  • cool Feb 13, 2012
    my jabra ote2 is not pairing with any phone
  • cool Feb 13, 2012
    my jabra 0te2 is not pairing with my nokia handset
Is the rechargeable battery in the Jabra BT500 replaceable?
  • jabra headset battery swap - YouTube www.youtube.com/watch?v=MMLocSWjq8Q
    • BY THEDIECLAN2004
    • 3 MIN
    • 24K VIEWS
    • ADDED 2011-12-10
    Video embedded · jabra headset battery swap theDIEclan2004. Subscribe Subscribed Unsubscribe 15 15. Loading ... Plantronics Pro battery replacement - Duration: 9:15.
  • Jabra BT500 Bluetooth Headset - Newegg.com www.newegg.com/Product/Product.aspx?Item=N82E16826552001
    • 4/5
    • 69 REVIEWS
    Buy Jabra BT500 Bluetooth Headset with fast shipping and top-rated customer service.Once you know, you Newegg!
  • Jabra SPORT Bluetooth Battery Replacement - YouTube www.youtube.com/watch?v=Sm8cSkyTmfA
    • BY GREG PAJAK
    • 2 MIN
    • 27K VIEWS
    • ADDED 2013-09-23
    Video embedded · A quick video showing the ease of replacing the battery in the Jabra Sport bluetooth headphones. Jabra says when it it out of warranty they cannot be ...
  • Jabra BT-350 Disassembly and Repair - Instructables www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair Intro: Jabra BT-350 Disassembly and Repair. I wooted a few of these dandy devices a while back and they work great but the volume buttons are weak and the solder ...
  • Jan 26, 2016 | Jabra BT500 Wireless Headset
    Tip
    How do I pair a Bluetooth headset Jabra?
    <p>Jabra is the name of a company that was acquired by GN Corporation in 2000. The acquisition of GN strengthened position as a global supplier of equipment for hands-free communication environment. The name Jabra products to raise awareness and respect for the merger of corporations. In 2005, CN created the first Jabra headset that would work with Bluetooth technology for hands-free communication. Jabra is currently considered the first and leading provider of hands-free communication. Learn to use a Bluetooth headset Jabra Bluetooth is based on having in his pocket computer. <br /> <p><br /> <p>1. Turn your Bluetooth device to your computer. <br /> <p><br /> <p>2. Click Start and select Control Panel. <br /> <p><br /> <p>3. Double-click the Bluetooth icon and go to "Setup" option. It opens a wizard. <br /> <p><br /> <p>4. Step through the wizard. He should see your Jabra Bluetooth headset in place a discovery / sending mode. You hold the button on the Jabra headset it flashes green. <br /> <p><br /> <p>5. Click "Next" when it's time to find a nearby Bluetooth device. This, then, find your Jabra headset, because it was created in the previous step. <br /> <p><br /> <p>6. Click "Next" once the devices are paired and the headset at any time. <br />
    on Jun 26, 2011 | Computers & Internet
    Hi I have an iPhone 4 and jabra bt3030 worked perfect on my iPhone but in my iPhone I tap forget this device and the device was gone! now I can't find it again! what should I do?
      • 1. Hold the "Answer/End" button on your Jabra Bluetooth headset down until the LED light on the headset turns solid blue. It is the button that has an image of a telephone on it.
      • 2. Click on the "Settings" icon from the main screen of your iPhone.
      • 3. Click on "General" in your iPhone's "Settings" menu.
      • 4. Click on "Bluetooth" to access your iPhone's Bluetooth menu and then click the option to turn on your iPhone's Bluetooth connection. Once your iPhone's Bluetooth is turned on, it will search for available Bluetooth devices.
      • 5. Select your Jabra headset by clicking on the icon that appears on your iPhone's screen.
      • 6. Enter the passkey for your Jabra Bluetooth headset. The default passkey on Jabra headsets is "0000."
      • 7. Click on OK on your iPhone
    Sep 13, 2011 | Jabra BT3030 Wireless Headset
    Can't connect
    In your Jabra bluetooth headset, press and hold the button in the headset until you see BLUE flashing light. Once the light is flashing in the Jabra, go to your Motorola phone and search for any Bluetooth device in range. when the Jabra shows up, select the Jabra and put in the pin code for the headset "its either 0000 or 1234)
    Cheers!
    Jun 10, 2009 | Jabra Bluetooth Headset with Adjustable...
    Setting up Jabra VBT2050 Bluetooth
    I took my husband's suggestion and used 0000 and it worked. My husband claims it is the factory default for all bluetooth headsets. Try it and let us know if it works.
    Dec 26, 2008 | Jabra BT350 Bluetooth Headset Headset
    Jabra bluetooth adapter A210
    hi,
    you have to connect the jabra audio jack to the audio source, to the speaker output of your receiver for example. If jabra detects the source it will work. If you cut the connection, jabra watch for a while if something happend and than stops the transmittion. Hope that helps
    Oct 26, 2008 | LG Jabra A210 Bluetooth Adapter for...
    How to hook up a Jabra BT350 bluetooth
    Make sure your cell phone's bluetooth is activated. Once you do that, you should be able to hold down the main button on the Jabra and once it turns on, it will connect with your phone.
    Also, go to this site for Jabra. It links directly to the manual.
    Jun 22, 2008 | Jabra BT350 Bluetooth Headset Headset
    Jabra BT2010 Bluetooth Headset help
    Hey guys, hold the button pressed for 6 sec. until led is solid. then search bluetooth devices on phone click on Bluetooth headset insert '0000' press OK now it should work, or check http://jabra.com for compatibility. Best wishes, htmlfreak.
    Jan 03, 2008 | Radio Communications
    Radio Communications Logo
    57 people viewed this question
    Top Radio Communications Experts
    eradiostore
    eradiostore
    Mike Charette
    Are you a Radio Communication Expert? Answer questions, earn points and help others
