Question about Toshiba Satellite Computers & Internet
No hdmi port
My laptop (Toshiba Satellite L305-S5907 15.4) does not have an hdmi port and I want to connect it to Samsung HDTV with has an hdmi port...what do i need to do in that case?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 52 Answers
U can buy USB to HDMI converter cable...just check the manual for ur TV if it supports it also can try AV to HDMI converter cable
Posted on Feb 13, 2012
romsky79
  • 822 Answers
SOURCE: Dont know how to access bios on my toshiba laptop
just press f1 at startup booting.
Posted on May 24, 2009
Geekman
  • 32281 Answers
SOURCE: drivers of toshiba l305-s5907 64bit
You can download any/all the Windows XP or Vista device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Use this link :-. http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Posted on Jun 29, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Toshiba Satellite L305-S5907 won't charge battery.
Sadly, it sounds like you need a new system board for this. Something's wrong in the charging circuitry so that the battery never gets charged. But the power jack and other power circuits are OK since the unit comes on with the adapter connected.
It's possible that there are just some bad solder connections at the contacts (not uncommon) or a fuse has opened, but it's nearly impossible to get electronic repairs done on laptops. Most service shops won't attempt to troubleshoot and repair this sort of problem to component level because of the lack of service literature and time involved. They'll just want to switch out main boards. Even under warranty this is all they'd do.
If the thing is really "just" out of warranty you may have some luck if you call the manufacturer's customer service line at (800) 457-7777. If you're outside the US you can look up the appropriate number at their website.
Posted on Jan 28, 2010
  • 24 Answers
SOURCE: satellite l305-s5907 is plugged in but there is no
This sounds like it may be a DC power jack or the AC adapter. Did this happen suddenly or did it occur over a period of time? Have you had to jiggle the AC plug to get power? Look to see if the pin is broken off of the jack inside the plug hole or if it is loose when you plug it in. Or was the cord yanked on? If it did happen suddenly it could still be the DC power jack. They can go out by an arc of power and melt a nearby chip etc. or the jack plastic itself. If you can get intermittent power by moving the tip then it is almost surely the jack. I don't suggest continuing to do this as it will just make an inevitable repair worse and maybe even ruin your MB. You can also look at the AC adapter (unplugged to be safe). Check where it connects to the tip and goes straight to the plug. There is a flexible part there. The check the flexible parts of the cable near the adapter brick on both ends. If no luck it will need to be opened and have the jack looked at first then if that isn't it the MB. Make sure if you bring it somewhere they don't tell you it is a bad MB when it is a jack. One important note. This model has a DC harnessed jack meaning the DC jack isn't soldered to the MB but rather sits in a bracket and has wires that are soldered to the back that then go to a clip that connects to the MB. Often these wires break loose from the jack and just need to be soldered back on. Toshiba is sneaky with some by making the wires hidden inside a "secret trap door" so you can't see where they are soldered or if they broke loose. You can pop this plastic off the back and check the connections and often re-solder them back on. Use heat shrink over the exposed wire if you have it and put some epoxy over the connections and you should be good. Even better than new often.
Posted on Feb 24, 2010
Testimonial: "Great information. Helped me decide on a course of repair and saved me a lot of time. Thanks for the help."
ADebelius
  • 72 Answers
SOURCE: Toshiba Satellite L305-S5907 15.4" Widescreen Can
With the Toshiba Satellite L305-S5907 Laptop, you can put a 500GB hard drive and up to 2 TB hard drive. The only requirements are to make sure it has a SATA connector and is 2.5" Size. These are very common and easily found online. For example, here a 500GB one that is compatible that I found: Click Here.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
Posted on May 24, 2011
Why won't my Toshiba Satellite L655 laptop connect trough HDMI anymore?
Try pressing the appropriate function button to change the screen from internal to external. Possibly F4?
May 15, 2014 | Toshiba Satellite L655-S5101 Laptop
Laptop to HDTV
... you can probably buy a usb adapter for your computer... might try ebay
Oct 13, 2013 | Toshiba Satellite L655d-s5050 2.1ghz 3gb...
Does toshiba satellite m505-s4940 come with hdmi port
Quoted from CNET review:
"A full-size ExpressCard slot and a memory-card slot are all welcome features, but HDMI has been dropped in the S4940--a plugged-up port is all that remains. "
Sorry...
Nov 21, 2012 | Toshiba Computers & Internet
Toshiba satellite L305-s5955 will not power up
If there is no power light and it can't charge your laptop, it is likely that the charger is dead. You need a new laptop charger. So try a new adapter to confirm the real issue.
There are two kinds of ac adapters for your toshiba l305-s5955
Toshiba Satellite L305 AC Adapter 75Watt 19V 3.95A
Toshiba Satellite L305 AC Adapter 90Watt 19V 4.74A
You should choose the right charger depending on your original adapter's specification. If the original one need 90w, you won't buy 75w that will bring damage to your laptop. If it needs 75w you can use 90w too.
Oct 14, 2012 | Toshiba Satellite L305-S5955, L305-S5956,...
I NEED A Toshiba Satellite L305-S5946 Laptop HDMI CABLE AND DONT KNOW WHICH ONE TO GET.
as far as I knew, that laptop didn't have hdmi out. if it does, you should be able to use ANY hdmi although you made need a specific cable with either a full size male hdmi on both ends or an hdmi with a full size male on one end and a mini male on the other. if it doesn't have an hdmi out port though, you will need something like a VGA to hdmi or DVI converter box (depending on what you are connecting the laptop to). a simple cable with VGA on one end and a hdmi on the other wont work either as it wont convert the signal properly. you need an electronic box(could cost more than $50) to convert the signal similar to this for an example...
hope this helps
Apr 17, 2011 | Computers & Internet
What do I need and how do I connect my Toshiba L305 model PSLB8 050302f to my hdtv to view online tv?
I dont believe that laptop has an HDMI port on it. If you have an LCD TV then your TV may have a VGA or DVI input on it. You can connect your laptop to the TV by using a VGA to VGA or VGA to DVI cable. If you your TV doesn't have one of these input ports, then you're not going to get your laptop connected to your TV.
Mar 03, 2011 | Toshiba Satellite Pro L300 Notebook
I don't know what kind of cable i need to connect my Toshiba satellite L305D laptop to my hdtv
depending on how old you laptop is because the L300 range has been going for a while will be either a HDMI cable or a VGA to HDMI cable but if you require sound and you have to use the latter you will need a headphone jack to auxhilary lead to go from the headphone port of your laptop to the line in on your tv
Jan 19, 2011 | Toshiba Satellite Pro L300 Notebook
How do i connect my Toshiba Satellite U505-S2950 to my hd tv ? I have an HDMI cable but my lap top has no port for it.
Your laptop has a vga port, use an vga male to HDMI female adapter to connect the two with an HDMI cable. There are adapters available at a company called "Cables to Go" below is their web site.
https://www.cablestogo.com/categories.asp?cat_id=100
Jan 13, 2010 | Toshiba Satellite U505-S2940 Notebook
How do you connect a toshiba laptop to a hd tv
Most new TV's have a port that looks the same as he moniter connection.
Dec 31, 2009 | Computers & Internet
Juatin: toshiba satellite L305 has some problem
It seems this is a windows problem. Try reinstalling windows, or repair it within the boot cd
Jul 29, 2009 | Toshiba Satellite L305-S5907 Laptop
Computers & Internet Logo
464 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
