Question about Nova Development Photo Explosion Deluxe for PC
Memories on tv3
I just bought a new pc and loaded my Photo Explosion Deluxe on it. I can ad my photos, music, and set effects but when I go to burn it does not recognize my cd burner. The pc came with the Cyberlink Dvd Suite Deluxe, but I can only generate new video not burn unless I can figure out how to get this program to recognize my burning program. Can someone please help me with this.
  • Anonymous Apr 26, 2009
    I have the same problem...
    I just bought a new pc and loaded my Photo Explosion version 3 on it. I can ad my photos, music, and set effects but when I go to burn it does not recognize my cd burner. The pc came with the windows DVD maker but I can only generate new video not burn it to a DVD unless I can figure out how to get this program to recognize my burning program. Can someone please help me with this.
5 Suggested Answers
SOURCE: Nova Photo explosion Deluxe
Hi there, This fix worked for me and I was having the same problem. Hope it works for you. If you are on Windows XP, this can normally be resolved by setting the compatibility mode for Photo Explosion to Windows 98. You can do this by following these steps:
1) Click on the Start button.
2) Click on the My Computer. This should open a window titled My Computer.
3) Double-click on the C: drive.
4) If the information is hidden, there is normally an option to show the hidden files/folders. You will need to select this option.
5) Double-click on the Program Files folder.
6) If the information is hidden, there is normally an option to show the hidden files/folders. You will need to select this option.
7) Double-click on the Nova Development folder.
8) Double-click on the Photo Explosion folder.
9) Right-click on IPE40 icon, which looks like a camera.
10) Select the Properties option from the bottom of the pop-up menu.
11) Click on the Compatibility tab.
12) Put a check in the check-box next to "Run this program in compatibility mode for".
13) From the drop-down list, chose "Windows 98 / Windows Me".
14) Click on the OK button.
15) Reboot your computer.
Posted on Jan 12, 2008
djnick989
  • 1067 Answers
SOURCE: photo explosion deluxe 3.0 -memories on tv
use nero 7 i have full verison if u have yahoo msg works way bbeter slide shows dvd menus videos u did if your talking about burning dvdv u rent u need dvd fab i have that also for 10 bucks
Posted on Jan 24, 2008
  • 3 Answers
SOURCE: Photo Explosion Deluxe
Thank you for contacting customer service. The MPEG-2 Plugin for Memories on TV allows you to burn discs in SVCD format on a CD-ROM. This is a superior quality to the standard VCD option which is included in your software. The MPEG-2 will also let you burn in MPEG status, which permits you to burn your files to a DVD-ROM. Not all players support the video formats so please be sure to check your reference material to see what your player can support.
The price for the MPEG-2 Plugin is $12.95. To download, please go to http://www.novadevelopment.com/products/us/mtw/default.aspx You will receive your code via email shortly after purchase. . Please allow up to 24 business hours for your order to be processed.
Posted on Feb 06, 2008
SOURCE: Ulead Photo Express has stopped working
pour a very hot water on your syetem and then let it cool, after half an hour it will be okay
Posted on Sep 01, 2008
SOURCE: Burning movie using memories on TV3
If you burnt a DVD + , try getting a DVD - and burn to that or vice versa. Some DVD players play both the DVD + and the DVD -. Other DVD players will only play one of the two types of discsl
I burn all mine to a DVD +.
Posted on Oct 22, 2008
Photo explosion deluxe 5 has stopped running in windows 8
try running the program in compatiblity mode. Set it to run with earlier versions of windows, say XP. If it does not run then the software vendor is obligated to upgrade it for free.
Jun 12, 2014 | Nova Development Photo Explosion Deluxe...
Problem loading photo explosion delux version 3 disc 1
You can right-click on the program's setup.exe, select properties, then compatibility and set it to windows XP
then try to install it again
Dec 15, 2007 | Nova Development Photo Explosion Deluxe...
Unable to use unlock code
Well I suggest typing in the Letters in UPPER CASE and do not use the letter "O" if you see this it is a ZERO the Number 0
Apr 14, 2009 | Nova Development Photo Explosion Deluxe...
My photo explosion deluxe in windows xp does not run on vista
According to their website: http://www.novadevelopment.com/Products/us/prw/sys_req.aspx, pdw works with vista. Can you tell me what exact error you are getting?
Jan 02, 2009 | Nova Development Photo Explosion Deluxe...
Microsoft visual c ++ runtime error PEX.exe
My problem was I had to many pictures in my C/ pictures folder. It couldn,t load before it timed out. I moved those pictures to my C/photo folder, worked great! no more problem. I have win xp home ed sp 2. The Lord Jesus help me after month of prayer and not finding any solution on the web, Last night the answer just popped in my head, I'm not smart on pc, so I know I had help.Thank Jesus if this helps you. I did!
Linda
Sep 15, 2008 | Nova Development Photo Explosion Deluxe...
Jul 23, 2008 | Nova Development Photo Explosion Deluxe...
Photo explosion deluxe 3.0 -memories on tv
Jan 24, 2008 | Nova Development Photo Explosion Deluxe...
Convert files to cd
It seems you need the DELUXE version to burn to CD slideshow: “This deluxe edition lets you burn photo slide shows onto CDs that you can watch on TV with family and friends using most DVD players.”
Nov 09, 2007 | Novatel Photo Explosion Deluxe 2.0...
Nova Development Photo Explosion Deluxe for PC Logo
82 people viewed this question
Top Nova Development Computers & Internet Experts
David Payne
David Payne
Clive Gray
Are you a Nova Development Computer and Internet Expert? Answer questions, earn points and help others
