Question about Saitek Pro Flight Yoke System Flight Simulator
Saitek pro flight yoke not working
After 5 or 6 successed attempts to fly, I have a problem with it.The quadrant is on and the time runs but the controls receive no commands. I tried to reinstall the drivers for windows 7 64 bit but nothing.Do you have any suggestions? Thanks!
Editor925
  • 285 Answers
SOURCE: MS FSX -view keeps switching from cockpit to spot view
The most likely problem here is that you have multiple assignments for the view change command set to multiple controllers hooked up to the system. They are conflicting with each other causing random view changes.
Firstly, go into Windows Control Panel and to Game Controllers. Remove any controllers listed in that box that are not currently connected or being used in your flight simulator.
Next, go into FSX, into the control assignments section...
Go through each controller in the drop down box (in the button/keys tab) and ensure only one controller has the assignment for view changes assigned.
Posted on Mar 16, 2009
luckyluke78
  • 333 Answers
SOURCE: Saitek yoke's accuracy prroblem.
Try uninstall and reinstall software,
if that doesn't solve then try on different pc
still not working repair/replace unit.
Try Microsoft unit with force feedback or you can buy without FFB for less than £10
Posted on Aug 02, 2009
rh10
  • 122 Answers
SOURCE: saitek pro flight yoke problem
This is a know fault on Saitek yokes that is now cured. take it back and explain that it is suffering from "Ghost button pushing" and they should change it for a unit that has been updated. This problem is well documented on the web.
Posted on Jul 12, 2010
rh10
  • 122 Answers
SOURCE: I have two saitek pro flight throttle quadrants
To get the quadrants to operate four throttles, you need to assign AXIS not buttons, then you will be able to set them up.
rh10
  • 122 Answers
SOURCE: on saitek yoke system it wont work on fsx *flight
Ensure you have installed the drivers for it. If you don't have them, go to Saitek web site, download and install the correct one's for your operating system. Also ensure that the yoke is plugged into the USB port on the rear of the PC as these USB sockets give the most power. Additionally, you have to set the yoke up in FSX\Settings so it knows what to do with it with regard to calibrating it and assigning what buttons do what.
Posted on Jul 13, 2010
I have a simple problem with the SAITEK pro flight yoke. The LCD display is backlit, but BLANK. The usb is plugged correctly and the yoke functions correctly. All is working properly but the LCD DISPL
If the LCD is not working then it is likely that required drivers are either not working or missing. Try downloading updated drivers from the Saitek website.
Nov 08, 2012 | Saitek Pro Flight Yoke System Flight...
Saitek pro flight yoke problem
Jun 05, 2010 | Saitek Pro Flight Yoke System Flight...
Aug 02, 2009 | Saitek Pro Flight Yoke System Flight...
Hi, I contacted Saitek approximately 2weeks ago regarding the blueand purple backlight failure on my Eclipse II keyboard. I am awaiting your reply. I now have, what I feel to be a more serious failure on...
Hi Chris
Ensure that you have the usb lead from the yoke plugged into the rear of the PC as these give the most current. Ensure the drivers for the yoke are installed properly and they are the latest for your operating system. If this still does not work, then the yoke is faulty. Good luck!
Jul 23, 2009 | Saitek Pro Flight Yoke System Flight...
Saitek Throttle Quadrant wont go idle and full power
I had a similiar problem and after spending hours researching and looking at forums I figured out the a solution. Plug in the quadrant directly into your computer and then configure it. At that time make your necessary tweaks, i.e. null zones and sensitivity adjustments. After you get it to work properly there, then you should plug it into your yoke and everything should work fine.
Best regards,
Gary
Jun 14, 2009 | Saitek Pro Flight Yoke System Flight...
Reprograming the Pro Yoke Hatswitch
Go here --
http://www.fixya.com/support/p921647-saitek_pro_flight_yoke_system_flight_sim/manual-27479
Hope this helps..
Mar 24, 2009 | Saitek Pro Flight Yoke System Flight...
Saitek X52 Flight Control Problem
Remove the X52 and drivers from your system. You have to install them in a certain order, so look in the documentation for the correct way to install and you will be okay. Good luck
Feb 02, 2009 | Saitek Pro Flight Yoke System Flight...
Saitek Pro Flight Yoke System Flight Simulator Logo
234 people viewed this question
Top Saitek Video Game Consoles & Games Experts
Hjalmer Lamminen
Hjalmer Lamminen
Rob Emerson
Rob Emerson
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
